[PATCH 5/9] posix: Convert to inline function
Thu Jul 18 16:47:57 UTC 2013
On Thu, Jul 18, 2013 at 12:43 PM, Ralf Corsepius
<ralf.corsepius at rtems.org> wrote:
> On 07/17/2013 04:18 PM, Sebastian Huber wrote:
>>   cpukit/posix/include/rtems/posix/muteximpl.h |   20 ++++++++++++++++----
>>   cpukit/posix/src/mutextranslatereturncode.c  |   22
>>   2 files changed, 17 insertions(+), 25 deletions(-)
>> diff --git a/cpukit/posix/include/rtems/posix/muteximpl.h
>> b/cpukit/posix/include/rtems/posix/muteximpl.h
>> index d4673aa..29e93c2 100644
>> --- a/cpukit/posix/include/rtems/posix/muteximpl.h
>> +++ b/cpukit/posix/include/rtems/posix/muteximpl.h
>> @@ -38,6 +40,8 @@ POSIX_EXTERN Objects_Information
>> _POSIX_Mutex_Information;
>>   POSIX_EXTERN pthread_mutexattr_t _POSIX_Mutex_Default_attributes;
>> +extern const int _POSIX_Mutex_Return_codes[CORE_MUTEX_STATUS_LAST + 1];
>>    *  @brief POSIX Mutex Manager Initialization
>> @@ -144,11 +148,19 @@ int _POSIX_Mutex_Lock_support(
>>    * willing to block but the operation was unable to complete within the
>> time
>>    * allotted because the resource never became available.
>> -int _POSIX_Mutex_Translate_core_mutex_return_code(
>> +RTEMS_INLINE_ROUTINE int _POSIX_Mutex_Translate_core_mutex_return_code(
>>     CORE_mutex_Status  the_mutex_status
>> +   *  Internal consistency check for bad status from SuperCore
>> +  #if defined(RTEMS_DEBUG)
>> +    if ( the_mutex_status > CORE_MUTEX_STATUS_LAST )
>> +      return EINVAL;
>> +  #endif
>> +  return _POSIX_Mutex_Return_codes[the_mutex_status];
>>    *  _POSIX_Mutex_Get
> I don't like this kind of changes, because they contradict to the working
> principles of data abstraction and encapsulation.
> They expose internal implementation details and symbols, no user should see.
I think this file and it's structures/functions are not meant to be
part of the user API.
> Many people, comprising me, consider this to be very bad coding style.
> Ralf
> rtems-devel mailing list
> rtems-devel at rtems.org
