[PATCH] add freelist data structure to score
Ashi
ashi08104 at gmail.com
Fri Jul 19 09:33:25 UTC 2013
On Fri, Jul 19, 2013 at 3:00 PM, Sebastian Huber <
> Hallo Ashi,
> this looks good. Thanks for test cases. Is it possible that you
> integrate everything in one test application, e.g. different test cases in
> different functions?
Yeah, I was also thinking about it. I think one test should be more
compact. And it should be done easily.
> Maybe we should use _Freechain_Get() and _Freechain_Put() to make the
> function name a bit shorter?
OK, I will update it shortly.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130719/9890136a/attachment.html>
