[PATCH] add freelist data structure to score
Ashi
ashi08104 at gmail.com
Sun Jul 21 13:55:21 UTC 2013
Sorry, this patch's github url is:
https://github.com/ashi08104/rtems/tree/add_freelist
Cheers,
Zhongwei
On Sun, Jul 21, 2013 at 9:51 PM, Ashi <ashi08104 at gmail.com> wrote:
> On Fri, Jul 19, 2013 at 5:33 PM, Ashi <ashi08104 at gmail.com> wrote:
>> On Fri, Jul 19, 2013 at 3:00 PM, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> Hallo Ashi,
>>> this looks good. Thanks for test cases. Is it possible that you
>>> integrate everything in one test application, e.g. different test cases in
>>> different functions?
>> Yeah, I was also thinking about it. I think one test should be more
>> compact. And it should be done easily.
>>> Maybe we should use _Freechain_Get() and _Freechain_Put() to make the
>>> function name a bit shorter?
>> OK, I will update it shortly.
>>> Hi, all. I've update the patch by following changes:
> - squash 3 test cases into 1
> - rename _Freechain_Get_node() and _Freechain_Put_node() to
> _Freechain_Get() and _Freechain_Put().
> And here is this patch's github url:
> Cheers,
> Zhongwei
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130721/44c60aff/attachment.html>
