[PATCH] Updated Legacy code in i386 pc386
Vipul Nayyar nayyar_vipul at yahoo.com
Sun Jul 21 19:22:57 UTC 2013
 c/src/lib/libbsp/i386/pc386/3c509/3c509.c       | 111 +++++-------------------
 c/src/lib/libbsp/i386/pc386/clock/ckinit.c      |  79 +++++++----------
 c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c |  58 +++++--------
 c/src/lib/libbsp/i386/pc386/console/vgacons.c   |  35 +++-----
 c/src/lib/libbsp/i386/pc386/include/bsp.h       |  10 ++-
 c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c     |  58 ++++---------
 c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c     |  44 ++++------
 c/src/lib/libbsp/i386/shared/comm/tty_drv.c     |  93 ++++++++------------
 c/src/lib/libbsp/i386/shared/smp/smp-imps.c     |  30 +++----
 9 files changed, 179 insertions(+), 339 deletions(-)
diff --git a/c/src/lib/libbsp/i386/pc386/3c509/3c509.c b/c/src/lib/libbsp/i386/pc386/3c509/3c509.c
index ec309ba..178040b 100644
--- a/c/src/lib/libbsp/i386/pc386/3c509/3c509.c
+++ b/c/src/lib/libbsp/i386/pc386/3c509/3c509.c
@@ -60,6 +60,7 @@
 #include <rtems/error.h>
+#include <assert.h>
 #include <sys/param.h>
 #include <sys/mbuf.h>
@@ -163,11 +164,11 @@ struct ep_softc
     struct ep_board *epb;
     int unit;
-    rtems_irq_connect_data   irqInfo;
-    rtems_id		     	 rxDaemonTid;
-    rtems_id		     	 txDaemonTid;
+    rtems_id rxDaemonTid;
+    rtems_id txDaemonTid;
+    rtems_vector_number name;
-    int              	 acceptBroadcast;
+    int acceptBroadcast;
     short tx_underrun;
     short rx_no_first;
@@ -355,7 +356,7 @@ static __inline unsigned short inw( unsigned short io_addr )
  * RETURNS: nothing.
-void __inline outb( unsigned short io_addr, uint8_t out_data )
+static __inline void outb( unsigned short io_addr, uint8_t out_data )
   outport_byte( io_addr, out_data );
@@ -403,46 +404,6 @@ static int get_eeprom_data( int id_port, int offset )
- * DESCRIPTION: Waits until the EEPROM of the card is ready to be accessed.
- * RETURNS: 0 - not ready; 1 - ok
-static int eeprom_rdy( struct ep_softc *sc )
-    int i;
-    for (i = 0; is_eeprom_busy(BASE) && i < MAX_EEPROMBUSY; i++)
-	    continue;
-    if (i >= MAX_EEPROMBUSY)
-	   printf("ep%d: eeprom failed to come ready.\n", sc->unit);
-	   return (0);
-    return (1);
- * DESCRIPTION:
- * get_e: gets a 16 bits word from the EEPROM.
- * We must have set the window before call this routine.
- * RETURNS: data from EEPROM
-u_short get_e(  struct ep_softc *sc, int offset )
-    if( !eeprom_rdy(sc) )
-	   return (0xffff);
-    outw(BASE + EP_W0_EEPROM_COMMAND, EEPROM_CMD_RD | offset );
-	   return( 0xffff );
-    return( inw( BASE + EP_W0_EEPROM_DATA ) );
  * DESCRIPTION:
  * Driver interrupt handler. This routine is called by the RTEMS kernel when this
  * interrupt is raised.
@@ -450,7 +411,7 @@ u_short get_e(  struct ep_softc *sc, int offset )
  * RETURNS: nothing.
-static rtems_isr ap_interrupt_handler( rtems_vector_number v )
+static rtems_isr ap_interrupt_handler(void)
   struct ep_softc *sc = (struct ep_softc *)&ep_softc[ 0 ];
@@ -464,30 +425,6 @@ static rtems_isr ap_interrupt_handler( rtems_vector_number v )
  * DESCRIPTION:
- * RETURNS:
-static void nopOn(const rtems_irq_connect_data* notUsed)
-  /* does nothing */
- * DESCRIPTION:
- * RETURNS:
-static int _3c509_IsOn(const rtems_irq_connect_data* irq)
-  return BSP_irq_enabled_at_i8259s (irq->name);
- * DESCRIPTION:
  * Initializes the ethernet hardware.
  * RETURNS: nothing.
@@ -495,24 +432,22 @@ static int _3c509_IsOn(const rtems_irq_connect_data* irq)
 static void _3c509_initialize_hardware (struct ep_softc *sc)
-  rtems_status_code st;
+  rtems_status_code status;
   epinit( sc );
    * Set up interrupts
-  sc->irqInfo.hdl = ( rtems_irq_hdl )ap_interrupt_handler;
-  sc->irqInfo.on  = nopOn;
-  sc->irqInfo.off = nopOn;
-  sc->irqInfo.isOn = _3c509_IsOn;
-  printf ("3c509: IRQ with Kernel: %d\n", sc->irqInfo.name );
-  st = BSP_install_rtems_irq_handler( &sc->irqInfo );
-  if( !st )
-    rtems_panic ("Can't attach WD interrupt handler for irq %d\n", sc->irqInfo.name );
+  printf ("3c509: IRQ with Kernel: %d\n", (int)sc->name );
+  status = rtems_interrupt_handler_install(
+    sc->name,
+    "3c509",
+    RTEMS_INTERRUPT_UNIQUE,
+    (rtems_interrupt_handler)ap_interrupt_handler,
+    NULL
+  assert(status == RTEMS_SUCCESSFUL);
@@ -746,8 +681,8 @@ int rtems_3c509_driver_attach (struct rtems_bsdnet_ifconfig *config )
 	overrun = 0;
 	resend = 0;
-    ep_unit = 0;
-    ep_boards = 0;
+  ep_unit = 0;
+  ep_boards = 0;
 	 * Find a free driver
@@ -782,9 +717,9 @@ int rtems_3c509_driver_attach (struct rtems_bsdnet_ifconfig *config )
 		mtu = ETHERMTU;
 	if (config->irno)
-		sc->irqInfo.name = config->irno;
+		sc->name = config->irno;
 	else
-		sc->irqInfo.name = 10;
+		sc->name = 10;
 	if (config->port)
 		sc->ep_io_addr = config->port;
@@ -1046,13 +981,13 @@ static int ep_isa_attach( struct isa_device *is )
     irq = is->id_irq;
 	/* update the interrupt line number to registered with kernel */
-	sc->irqInfo.name = irq;
+	sc->name = irq;
     GO_WINDOW( 0 );
     SET_IRQ( BASE, irq );
     printf( "3C509: I/O=0x%x, IRQ=%d, CONNECTOR=%s, ",
-	    sc->ep_io_addr, sc->irqInfo.name,ep_conn_type[ sc->ep_connector ] );
+	    sc->ep_io_addr, (int)sc->name,ep_conn_type[ sc->ep_connector ] );
     ep_attach( sc );
     return 1;
diff --git a/c/src/lib/libbsp/i386/pc386/clock/ckinit.c b/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
index 37b0408..ef0a64c 100644
--- a/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
+++ b/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
@@ -27,6 +27,7 @@
 #include <bsp/irq.h>
 #include <bspopts.h>
 #include <libcpu/cpuModel.h>
 #define CLOCK_VECTOR 0
@@ -36,15 +37,10 @@ uint32_t pc386_clock_click_count;
 /* forward declaration */
 void Clock_isr(void *param);
-void Clock_driver_support_at_tick_tsc(void);
-void Clock_driver_support_at_tick_empty(void);
-uint32_t bsp_clock_nanoseconds_since_last_tick_tsc(void);
-uint32_t bsp_clock_nanoseconds_since_last_tick_i8254(void);
-void Clock_isr_handler(rtems_irq_hdl_param param);
-int clockIsOn(const rtems_irq_connect_data* unused);
-void clockOff(const rtems_irq_connect_data* unused);
-void Clock_driver_install_handler(void);
-void Clock_driver_support_initialize_hardware(void);
+static void Clock_driver_support_at_tick_tsc(void);
+static uint32_t bsp_clock_nanoseconds_since_last_tick_tsc(void);
+static uint32_t bsp_clock_nanoseconds_since_last_tick_i8254(void);
+static void Clock_isr_handler(void *param);
  * Roughly the number of cycles per tick and per nanosecond. Note that these
@@ -83,7 +79,7 @@ uint32_t (*Clock_driver_nanoseconds_since_last_tick)(void) = NULL;
  *  What do we do at each clock tick?
 #ifdef CLOCK_DRIVER_ISRS_PER_TICK
@@ -99,10 +95,6 @@ void Clock_driver_support_at_tick_tsc(void)
 #endif
 #define Clock_driver_support_install_isr( _new, _old ) \
   do { \
     _old = NULL; \
@@ -113,7 +105,7 @@ extern volatile uint32_t Clock_driver_isrs;
  * Get nanoseconds using Pentium-compatible TSC register
   uint64_t                 diff_nsec;
@@ -140,7 +132,7 @@ uint32_t bsp_clock_nanoseconds_since_last_tick_tsc(void)
  * Get nanoseconds using 8254 timer chip
   uint32_t                 usecs, clicks, isrs;
   uint32_t                 usecs1, usecs2;
@@ -232,9 +224,7 @@ static void calibrate_tsc(void)
   pc586_tsc_per_tick /= rtems_clock_get_ticks_per_second();
-static void clockOn(
-  const rtems_irq_connect_data* unused
+static void clockOn(void)
   pc386_isrs_per_tick        = 1;
   pc386_microseconds_per_isr = rtems_configuration_get_microseconds_per_tick();
@@ -267,43 +257,26 @@ static void clockOn(
     calibrate_tsc();
-  /* reset timer mode to standard (BIOS) value */
-  outport_byte(TIMER_MODE, TIMER_SEL0 | TIMER_16BIT | TIMER_RATEGEN);
-  outport_byte(TIMER_CNTR0, 0);
-} /* Clock_exit */
-  return ((i8259s_cache & 0x1) == 0);
 bool Clock_isr_enabled = false;
-  rtems_irq_hdl_param param
   if ( Clock_isr_enabled )
     Clock_isr( param );
-static rtems_irq_connect_data clockIrqData = {
-  BSP_PERIODIC_TIMER,
-  Clock_isr_handler,
-  0,
-  clockOn,
-  clockOff,
-  clockIsOn
-  if (!BSP_install_rtems_irq_handler (&clockIrqData)) {
-    printk("Unable to install system clock ISR handler\n");
-    rtems_fatal_error_occurred(1);
+    BSP_PERIODIC_TIMER,
+    "ckinit",
+    Clock_isr_handler,
+    NULL
+  clockOn();
@@ -326,7 +299,7 @@ void Clock_driver_support_initialize_hardware(void)
   if ( use_8254 ) {
     /* printk( "Use 8254\n" ); */
-    Clock_driver_support_at_tick = Clock_driver_support_at_tick_empty;
+    Clock_driver_support_at_tick = NULL;
     Clock_driver_nanoseconds_since_last_tick =
       bsp_clock_nanoseconds_since_last_tick_i8254;
   } else {
@@ -349,7 +322,13 @@ void Clock_driver_support_initialize_hardware(void)
 #define Clock_driver_support_shutdown_hardware() \
   do { \
-    BSP_remove_rtems_irq_handler (&clockIrqData); \
+    rtems_status_code status; \
+    status = rtems_interrupt_handler_remove(  \
+      BSP_PERIODIC_TIMER, \
+      Clock_isr_handler,  \
+      NULL  \
+    assert(status == RTEMS_SUCCESSFUL); \
   } while (0)
 #include "../../../shared/clockdrv_shell.h"
diff --git a/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c b/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c
index d0af6b9..3a40ccc 100644
--- a/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c
+++ b/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c
@@ -17,6 +17,7 @@
 #include <sys/types.h>
 #include <bsp.h>
@@ -29,6 +30,7 @@
 #define  INITIALIZE_MOUSE
 /* Some configuration switches are present in the include file... */
 #include "ps2_mouse.h"
+#include "ps2_drv.h"
 static void kbd_write_command_w(int data);
 #if 0
@@ -36,6 +38,7 @@ static void kbd_write_output_w(int data);
 #endif
 static unsigned char handle_kbd_event(void);
+static void ps2_set_driver_handler(int port, mouse_parser_enqueue_handler handler);
 /* used only by send_data - set by keyboard_interrupt */
 static volatile unsigned char reply_expected = 0;
@@ -56,14 +59,14 @@ static unsigned char mouse_reply_expected = 0;
 #define AUX_INTS_ON  (KBD_MODE_KCC | KBD_MODE_SYS | KBD_MODE_MOUSE_INT | KBD_MODE_KBD_INT)
 #define MAX_RETRIES	60		/* some aux operations take long time*/
-static void ps2_mouse_interrupt(rtems_irq_hdl_param);
+static void ps2_mouse_interrupt(void);
 static mouse_parser_enqueue_handler driver_input_handler_ps2 = NULL;
  * This routine sets the handler to handle the characters received
  * from the serial port.
-void ps2_set_driver_handler(
   int                          port,
@@ -78,30 +81,6 @@ static void mdelay( unsigned long t )
 static void*    termios_ttyp_paux = NULL;
-static void
-isr_on(const rtems_irq_connect_data *unused)
-  return;
-static void
-isr_off(const rtems_irq_connect_data *unused)
-  return;
-static int isr_is_on(const rtems_irq_connect_data *irq)
-  return BSP_irq_enabled_at_i8259s( irq->name );
-static rtems_irq_connect_data ps2_isr_data = { AUX_IRQ,
-                                               ps2_mouse_interrupt,
-                                               0,
-                                               isr_on,
-                                               isr_off,
-                                               isr_is_on };
  * Wait for keyboard controller input buffer to drain.
@@ -223,7 +202,7 @@ static unsigned char handle_kbd_event(void)
   return status;
-static void ps2_mouse_interrupt(rtems_irq_hdl_param ignored)
   handle_kbd_event();
@@ -323,11 +302,17 @@ static int queue_empty(void)
 static int release_aux(void)
   if (--aux_count)
     return 0;
   kbd_write_cmd(AUX_INTS_OFF);			    /* Disable controller ints */
   kbd_write_command_w(KBD_CCMD_MOUSE_DISABLE);
-  BSP_remove_rtems_irq_handler( &ps2_isr_data );
+    AUX_IRQ,
+    (rtems_interrupt_handler)ps2_mouse_interrupt,
+    NULL
   return 0;
@@ -338,18 +323,21 @@ static int release_aux(void)
 static int open_aux(void)
-  int status;
   if (aux_count++) {
     return 0;
   queue->head = queue->tail = 0;		/* Flush input queue */
-  status = BSP_install_rtems_irq_handler( &ps2_isr_data );
-  if( !status ) {
-    printk("Error installing ps2-mouse interrupt handler!\n" );
-    rtems_fatal_error_occurred( status );
+    AUX_IRQ,
+    "ps2_mouse",
+    NULL
   kbd_write_command_w(KBD_CCMD_MOUSE_ENABLE); /* Enable the auxiliary port on
                                                  controller. */
@@ -429,7 +417,7 @@ static int psaux_init( void )
  * paux device driver INITIALIZE entry point.
-rtems_device_driver paux_initialize(
+rtems_device_driver paux_initialize(
   rtems_device_major_number major,
   rtems_device_minor_number minor,
   void                      *arg)
diff --git a/c/src/lib/libbsp/i386/pc386/console/vgacons.c b/c/src/lib/libbsp/i386/pc386/console/vgacons.c
index d1143da..91d88ee 100644
--- a/c/src/lib/libbsp/i386/pc386/console/vgacons.c
+++ b/c/src/lib/libbsp/i386/pc386/console/vgacons.c
@@ -1,5 +1,5 @@
- *  This file contains the termios TTY driver for the i386
+ *  This file contains the termios TTY driver for the i386
  *  vga.
  *  COPYRIGHT (c) 1989-2011.
@@ -20,23 +20,11 @@
 #include <bsp.h>
 #include <crt.h>
+#include "keyboard.h"
 #define VGACONS_STATIC static
-  return BSP_irq_enabled_at_i8259s(irq->name);
-static rtems_irq_connect_data keyboard_isr_data = {
-  BSP_KEYBOARD,
-  keyboard_interrupt,
-  0,
-  NULL,
-  NULL,
-  isr_is_on
  *  vgacons_init
@@ -44,7 +32,7 @@ static rtems_irq_connect_data keyboard_isr_data = {
 VGACONS_STATIC void vgacons_init(int minor)
    * Note:  We do not initialize the KBD interface here since
    *        it was initialized regardless of whether the
    *        vga is available or not.  Therefore it is initialized
@@ -160,7 +148,7 @@ bool vgacons_probe(
   int minor
-  int         status;
   static bool firstTime = true;
   if ((*(unsigned char*) NB_MAX_ROW_ADDR == 0) &&
@@ -175,11 +163,14 @@ bool vgacons_probe(
    *  can be COM1 and you can still use the mouse/VGA for graphics.
   if ( firstTime ) {
-    status = BSP_install_rtems_irq_handler(&keyboard_isr_data);
-    if (!status) {
-      printk("Error installing keyboard interrupt handler!\n");
-      rtems_fatal_error_occurred(status);
+      BSP_KEYBOARD,
+      "vgacons",
+      keyboard_interrupt,
+      NULL
   firstTime = false;
diff --git a/c/src/lib/libbsp/i386/pc386/include/bsp.h b/c/src/lib/libbsp/i386/pc386/include/bsp.h
index 5e6dcc6..625d4ce 100644
--- a/c/src/lib/libbsp/i386/pc386/include/bsp.h
+++ b/c/src/lib/libbsp/i386/pc386/include/bsp.h
@@ -80,6 +80,10 @@ extern int rtems_dec21140_driver_attach(struct rtems_bsdnet_ifconfig *, int);
 #define BSP_DEC21140_NETWORK_DRIVER_NAME    "dc1"
 #define BSP_DEC21140_NETWORK_DRIVER_ATTACH  rtems_dec21140_driver_attach
+extern int rtems_3c509_driver_attach(struct rtems_bsdnet_ifconfig *config);
+#define BSP_3C509_NETWORK_DRIVER_NAME    "3c1"
+#define BSP_3C509_NETWORK_DRIVER_ATTACH  rtems_3c509_driver_attach
 #ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
 #define RTEMS_BSP_NETWORK_DRIVER_NAME   BSP_DEC21140_NETWORK_DRIVER_NAME
 #endif
@@ -134,7 +138,7 @@ extern int rtems_dec21140_driver_attach(struct rtems_bsdnet_ifconfig *, int);
 | Console Defines
-|      WARNING: These Values MUST match the order in
+|      WARNING: These Values MUST match the order in
 |               Console_Configuration_Ports
 #define    BSP_CONSOLE_VGA            0
@@ -182,6 +186,10 @@ char          _IBMPC_inch_sleep (void);  /* from 'inch.c'   */
 void Wait_X_ms(unsigned int timeToWait); /* from 'timer.c'  */
+void Clock_driver_install_handler(void); /* from 'ckinit.c'  */
+void Clock_driver_support_initialize_hardware(void); /* from 'ckinit.c'  */
+size_t read_aux(char * buffer, size_t count); /* from 'ps2_mouse.c'  */
 /* Definitions for BSPConsolePort */
 #define BSP_CONSOLE_PORT_CONSOLE (-1)
 #define BSP_CONSOLE_PORT_COM1    (BSP_UART_COM1)
diff --git a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
index b23699d..13df124 100644
--- a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
+++ b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
@@ -381,7 +381,7 @@ ne_check_status (struct ne_softc *sc, int from_irq_handler)
 /* Handle an NE2000 interrupt.  */
 static void
-ne_interrupt_handler (rtems_irq_hdl_param cdata)
+ne_interrupt_handler (void * cdata)
   rtems_vector_number v = (rtems_vector_number) cdata;
   struct ne_softc *sc;
@@ -401,41 +401,18 @@ ne_interrupt_handler (rtems_irq_hdl_param cdata)
 /* Turn NE2000 interrupts on.  */
 static void
-ne_interrupt_on (const rtems_irq_connect_data *irq)
+ne_interrupt_on (rtems_vector_number name)
 #ifdef DEBUG_NE
   printk ("ne_interrupt_on()\n");
 #endif
-  sc = ne_device_for_irno (irq->name);
+  sc = ne_device_for_irno (name);
   if (sc != NULL)
     outport_byte (sc->port + IMR, NE_INTERRUPTS);
-/* Turn NE2000 interrupts off.  See ne_interrupt_on.  */
-static void
-ne_interrupt_off (const rtems_irq_connect_data *irq)
-  struct ne_softc *sc;
-#ifdef DEBUG_NE
-  printk ("ne_interrupt_off()\n");
-#endif
-  if (sc != NULL)
-    outport_byte (sc->port + IMR, 0);
-/* Return whether NE2000 interrupts are on.  */
-static int
-ne_interrupt_is_on (const rtems_irq_connect_data *irq)
 /* Initialize the NE2000 hardware.  */
 static void
@@ -516,20 +493,21 @@ ne_init_hardware (struct ne_softc *sc)
 static void
 ne_init_irq_handler(int irno)
-  rtems_irq_connect_data irq;
 #ifdef DEBUG_NE
   printk("ne_init_irq_handler(%d)\n", irno);
 #endif
-  irq.name = irno;
-  irq.hdl = ne_interrupt_handler;
-  irq.handle = (rtems_irq_hdl) irno;
-  irq.on = ne_interrupt_on;
-  irq.off = ne_interrupt_off;
-  irq.isOn = ne_interrupt_is_on;
-  if (!BSP_install_rtems_irq_handler (&irq))
-    rtems_panic ("Can't attach NE interrupt handler for irq %d\n", irno);
+    irno,
+    "ne2000",
+    ne_interrupt_handler,
+    (void *)irno
+  ne_interrupt_on(irno);
 /* The NE2000 packet receive daemon.  This task is started when the
@@ -1075,7 +1053,7 @@ static int ne_set_multicast_filter(struct ne_softc* sc)
   int i=0;
   unsigned int port = sc->port;
   unsigned char cmd = 0;
   /* Save CMDR settings */
   inport_byte(port + CMDR, cmd);
   /* Change to page 1 */
@@ -1087,7 +1065,7 @@ static int ne_set_multicast_filter(struct ne_softc* sc)
   /* Revert to original CMDR settings */
-  outport_byte(port + CMDR, cmd);
+  outport_byte(port + CMDR, cmd);
   return 0;
@@ -1125,12 +1103,12 @@ ne_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
       break;
     break;
   case SIOCADDMULTI:
   case SIOCDELMULTI:
     struct ifreq* ifr = (struct ifreq*) data;
-    error = (command == SIOCADDMULTI ?
+    error = (command == SIOCADDMULTI ?
       ether_addmulti(ifr, &(sc->arpcom)) :
       ether_delmulti(ifr, &(sc->arpcom)) );
     /* ENETRESET indicates that driver should update its multicast filters */
diff --git a/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c b/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c
index d26464c..0ac6903 100644
--- a/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c
+++ b/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c
@@ -18,6 +18,7 @@
@@ -73,7 +74,6 @@
 struct wd_softc {
   struct arpcom			arpcom;
   struct mbuf			**rxMbuf;
   struct mbuf			**txMbuf;
@@ -84,6 +84,7 @@ struct wd_softc {
   int				txBdActiveCount;
   unsigned int 			port;
   unsigned char			*base;
@@ -127,7 +128,7 @@ static struct wd_softc wd_softc[NWDDRIVER];
  * WD interrupt handler
 static void
-wd8003Enet_interrupt_handler (void *unused)
+wd8003Enet_interrupt_handler (void)
   unsigned int tport;
   unsigned char status, status2;
@@ -169,19 +170,6 @@ wd8003Enet_interrupt_handler (void *unused)
-   * code should be moved from wd8003Enet_initialize_hardware
-   * to this location
-static int wdIsOn(const rtems_irq_connect_data* irq)
  * Initialize the ethernet hardware
@@ -191,7 +179,7 @@ wd8003Enet_initialize_hardware (struct wd_softc *sc)
   int  i1, ultra;
   char cc1, cc2;
   unsigned char  temp;
   unsigned int tport;
   unsigned char *hwaddr;
@@ -257,15 +245,15 @@ wd8003Enet_initialize_hardware (struct wd_softc *sc)
    * Set up interrupts
-  sc->irqInfo.hdl = wd8003Enet_interrupt_handler;
-  sc->irqInfo.isOn = wdIsOn;
-  st = BSP_install_rtems_irq_handler (&sc->irqInfo);
-  if (!st)
-		  sc->irqInfo.name);
+    sc->name,
+    "wd8003",
+    (rtems_interrupt_handler)wd8003Enet_interrupt_handler,
+    NULL
 static void
@@ -397,7 +385,7 @@ sendpacket (struct ifnet *ifp, struct mbuf *m)
  * Driver transmit daemon
-void
+static void
 wd_txDaemon (void *arg)
 	struct wd_softc *sc = (struct wd_softc *)arg;
@@ -607,9 +595,9 @@ rtems_wd_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach)
 		mtu = ETHERMTU;
 	if (config->irno)
 	else
-		sc->irqInfo.name = 5;
+		sc->name = 5;
 	if (config->port)
 		sc->port = config->port;
diff --git a/c/src/lib/libbsp/i386/shared/comm/tty_drv.c b/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
index aafb02a..16a40df 100644
--- a/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
+++ b/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
@@ -27,63 +27,19 @@
 #include <termios.h>
 #include <uart.h>
+#include "tty_drv.h"
 int BSP_poll_read(int);
 /* Internal routines */
 static int tty1_conSetAttr( int minor, const struct termios *t);
 static int tty2_conSetAttr( int minor, const struct termios *t);
-static void isr_on(const rtems_irq_connect_data *);
-static void isr_off(const rtems_irq_connect_data *);
-static int  isr_is_on(const rtems_irq_connect_data *);
 extern BSP_polling_getchar_function_type BSP_poll_char;
 extern int BSPConsolePort;
 extern void rtems_set_waiting_id_comx( int port,  rtems_id id, rtems_event_set event );
- * Interrupt structure for tty1
-static rtems_irq_connect_data tty1_isr_data =
-  BSP_UART_COM1_IRQ,
-  BSP_uart_termios_isr_com1,
-  0,
-  isr_on,
-  isr_off,
-  isr_is_on};
- * Interrupt structure for tty2
-static rtems_irq_connect_data tty2_isr_data =
-  BSP_UART_COM2_IRQ,
-  BSP_uart_termios_isr_com2,
-  0,
-  isr_on,
-  isr_off,
-  isr_is_on};
-static void
-  return;
-static void
-  return;
-static int
-isr_is_on(const rtems_irq_connect_data *irq)
  *  TTYS1 - device driver INITIALIZE entry point.
 rtems_device_driver
@@ -111,12 +67,14 @@ tty1_initialize(rtems_device_major_number major,
   /* 9600-8-N-1, without hardware flow control */
   BSP_uart_init( BSP_UART_COM1, 9600, CHR_8_BITS, 0, 0, 0 );
-  status = BSP_install_rtems_irq_handler( &tty1_isr_data );
-  if( !status )
-    printk("Error installing ttyS1 interrupt handler!\n");
+    BSP_UART_COM1_IRQ,
+    "tty_drv",
+    BSP_uart_termios_isr_com1,
+    NULL
    * Register the device
@@ -132,7 +90,14 @@ tty1_initialize(rtems_device_major_number major,
 static int tty1_last_close(int major, int minor, void *arg)
-  BSP_remove_rtems_irq_handler( &tty1_isr_data );
+    NULL
   return 0;
@@ -339,12 +304,15 @@ tty2_initialize(rtems_device_major_number major,
   BSP_uart_init( BSP_UART_COM2, 9600, CHR_8_BITS, 0, 0, 0);
-  status = BSP_install_rtems_irq_handler( &tty2_isr_data );
-  if( !status )
-    printk("Error installing serial console interrupt handler!\n");
+    BSP_UART_COM2_IRQ,
+    "tty_drv",
+    BSP_uart_termios_isr_com2,
+    NULL
@@ -360,7 +328,14 @@ tty2_initialize(rtems_device_major_number major,
 static int tty2_last_close(int major, int minor, void *arg)
-  BSP_remove_rtems_irq_handler( &tty2_isr_data );
+    NULL
   return 0;
diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
index 916379e..3e51f02 100644
--- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
+++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
@@ -79,6 +79,7 @@
 #include <rtems/bspsmp.h>
 #include <rtems/bspIo.h>
 #include <libcpu/cpu.h>
 extern void _pc386_delay(void);
@@ -120,14 +121,14 @@ static void UDELAY(int x)
   while ( _i-- )
     _pc386_delay();
 #define READ_MSR_LO(_x) \
   (unsigned int)(read_msr(_x) & 0xffffffff)
 static inline unsigned long long read_msr(unsigned int msr)
   unsigned long long value;
   asm volatile("rdmsr" : "=A" (value) : "c" (msr));
   return value;
@@ -385,7 +386,7 @@ imps_read_config_table(unsigned start, int count)
     case IMPS_BCT_PROCESSOR:
       if ( imps_num_cpus < rtems_configuration_get_maximum_processors() ) {
 	add_processor((imps_processor *)start);
-      } else
+      } else
         imps_num_cpus++;
       start += 12;  /* 20 total */
       break;
@@ -751,22 +752,19 @@ rtems_isr ap_ipi_isr(
 #include <rtems/irq.h>
-static rtems_irq_connect_data apIPIIrqData = {
-  16,
-  (void *)ap_ipi_isr,
-  0,
-  NULL,            /* On */
-  NULL,            /* Off */
-  NULL,            /* IsOn */
 extern void bsp_reset(void);
 void ipi_install_irq(void)
-  if (!BSP_install_rtems_irq_handler (&apIPIIrqData)) {
-    printk("Unable to initialize IPI\n");
-    bsp_reset();
+    16,
+    "smp-imps",
+    ap_ipi_isr,
+    NULL
 #ifdef __SSE__
1.7.11.7
