[PATCH] Updated Legacy code in i386 pc386
Tue Jul 23 07:02:03 UTC 2013
Hello Vipul,
it looks good for the first round.  Please make sure that you use the right
function types for rtems_interrupt_handler_install() and that you don't miss
on/off operations.
See comments below.
On 2013-07-21 21:22, Vipul Nayyar wrote:
>   c/src/lib/libbsp/i386/pc386/3c509/3c509.c       | 111 +++++-------------------
>   c/src/lib/libbsp/i386/pc386/clock/ckinit.c      |  79 +++++++----------
>   c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c |  58 +++++--------
>   c/src/lib/libbsp/i386/pc386/console/vgacons.c   |  35 +++-----
>   c/src/lib/libbsp/i386/pc386/include/bsp.h       |  10 ++-
>   c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c     |  58 ++++---------
>   c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c     |  44 ++++------
>   c/src/lib/libbsp/i386/shared/comm/tty_drv.c     |  93 ++++++++------------
>   c/src/lib/libbsp/i386/shared/smp/smp-imps.c     |  30 +++----
>   9 files changed, 179 insertions(+), 339 deletions(-)
> diff --git a/c/src/lib/libbsp/i386/pc386/3c509/3c509.c b/c/src/lib/libbsp/i386/pc386/3c509/3c509.c
> index ec309ba..178040b 100644
> --- a/c/src/lib/libbsp/i386/pc386/3c509/3c509.c
> +++ b/c/src/lib/libbsp/i386/pc386/3c509/3c509.c
> @@ -60,6 +60,7 @@
>   #include <errno.h>
>   #include <rtems/error.h>
>   #include <rtems/rtems_bsdnet.h>
> +#include <assert.h>
>   #include <sys/param.h>
>   #include <sys/mbuf.h>
> @@ -163,11 +164,11 @@ struct ep_softc
>       struct ep_board *epb;
>       int unit;
> -    rtems_irq_connect_data   irqInfo;
> -    rtems_id		     	 rxDaemonTid;
> -    rtems_id		     	 txDaemonTid;
> +    rtems_id rxDaemonTid;
> +    rtems_id txDaemonTid;
> +    rtems_vector_number name;
> -    int              	 acceptBroadcast;
> +    int acceptBroadcast;
>       short tx_underrun;
>       short rx_no_first;
Do we really need global variables here?  If it is possible to make them
static, then this would be good.
> @@ -355,7 +356,7 @@ static __inline unsigned short inw( unsigned short io_addr )
>    * RETURNS: nothing.
> -void __inline outb( unsigned short io_addr, uint8_t out_data )
> +static __inline void outb( unsigned short io_addr, uint8_t out_data )
>     outport_byte( io_addr, out_data );
> @@ -403,46 +404,6 @@ static int get_eeprom_data( int id_port, int offset )
> - * DESCRIPTION: Waits until the EEPROM of the card is ready to be accessed.
> - * RETURNS: 0 - not ready; 1 - ok
> -static int eeprom_rdy( struct ep_softc *sc )
> -    int i;
> -    for (i = 0; is_eeprom_busy(BASE) && i < MAX_EEPROMBUSY; i++)
> -	    continue;
> -    if (i >= MAX_EEPROMBUSY)
> -	   printf("ep%d: eeprom failed to come ready.\n", sc->unit);
> -	   return (0);
> -    return (1);
> - * DESCRIPTION:
> - * get_e: gets a 16 bits word from the EEPROM.
> - * We must have set the window before call this routine.
> - * RETURNS: data from EEPROM
> -u_short get_e(  struct ep_softc *sc, int offset )
> -    if( !eeprom_rdy(sc) )
> -	   return (0xffff);
> -    outw(BASE + EP_W0_EEPROM_COMMAND, EEPROM_CMD_RD | offset );
> -	   return( 0xffff );
> -    return( inw( BASE + EP_W0_EEPROM_DATA ) );
>    * DESCRIPTION:
>    * Driver interrupt handler. This routine is called by the RTEMS kernel when this
>    * interrupt is raised.
> @@ -450,7 +411,7 @@ u_short get_e(  struct ep_softc *sc, int offset )
>    * RETURNS: nothing.
> -static rtems_isr ap_interrupt_handler( rtems_vector_number v )
> +static rtems_isr ap_interrupt_handler(void)
You should use the right function type for rtems_interrupt_handler_install().
You need a case due to that later.  Function pointer casts are usually bad.
>     struct ep_softc *sc = (struct ep_softc *)&ep_softc[ 0 ];
You can pass sc as an argument like in previous patches.
> @@ -464,30 +425,6 @@ static rtems_isr ap_interrupt_handler( rtems_vector_number v )
>    * DESCRIPTION:
> - * RETURNS:
> -static void nopOn(const rtems_irq_connect_data* notUsed)
> -  /* does nothing */
> - * DESCRIPTION:
> - * RETURNS:
> -static int _3c509_IsOn(const rtems_irq_connect_data* irq)
> -  return BSP_irq_enabled_at_i8259s (irq->name);
> - * DESCRIPTION:
>    * Initializes the ethernet hardware.
>    * RETURNS: nothing.
> @@ -495,24 +432,22 @@ static int _3c509_IsOn(const rtems_irq_connect_data* irq)
>   static void _3c509_initialize_hardware (struct ep_softc *sc)
> -  rtems_status_code st;
> +  rtems_status_code status;
>     epinit( sc );
>      * Set up interrupts
> -  sc->irqInfo.hdl = ( rtems_irq_hdl )ap_interrupt_handler;
> -  sc->irqInfo.on  = nopOn;
> -  sc->irqInfo.off = nopOn;
> -  sc->irqInfo.isOn = _3c509_IsOn;
> -  printf ("3c509: IRQ with Kernel: %d\n", sc->irqInfo.name );
> -  st = BSP_install_rtems_irq_handler( &sc->irqInfo );
> -  if( !st )
> -    rtems_panic ("Can't attach WD interrupt handler for irq %d\n", sc->irqInfo.name );
> +  printf ("3c509: IRQ with Kernel: %d\n", (int)sc->name );
> +  status = rtems_interrupt_handler_install(
> +    sc->name,
> +    "3c509",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    (rtems_interrupt_handler)ap_interrupt_handler,
> +    NULL
> +  assert(status == RTEMS_SUCCESSFUL);
> @@ -746,8 +681,8 @@ int rtems_3c509_driver_attach (struct rtems_bsdnet_ifconfig *config )
>   	overrun = 0;
>   	resend = 0;
> -    ep_unit = 0;
> -    ep_boards = 0;
> +  ep_unit = 0;
> +  ep_boards = 0;
>   	 * Find a free driver
> @@ -782,9 +717,9 @@ int rtems_3c509_driver_attach (struct rtems_bsdnet_ifconfig *config )
>   		mtu = ETHERMTU;
>   	if (config->irno)
> -		sc->irqInfo.name = config->irno;
> +		sc->name = config->irno;
>   	else
> -		sc->irqInfo.name = 10;
> +		sc->name = 10;
>   	if (config->port)
>   		sc->ep_io_addr = config->port;
> @@ -1046,13 +981,13 @@ static int ep_isa_attach( struct isa_device *is )
>       irq = is->id_irq;
>   	/* update the interrupt line number to registered with kernel */
> -	sc->irqInfo.name = irq;
> +	sc->name = irq;
>       GO_WINDOW( 0 );
>       SET_IRQ( BASE, irq );
>       printf( "3C509: I/O=0x%x, IRQ=%d, CONNECTOR=%s, ",
> -	    sc->ep_io_addr, sc->irqInfo.name,ep_conn_type[ sc->ep_connector ] );
> +	    sc->ep_io_addr, (int)sc->name,ep_conn_type[ sc->ep_connector ] );
>       ep_attach( sc );
>       return 1;
> diff --git a/c/src/lib/libbsp/i386/pc386/clock/ckinit.c b/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> index 37b0408..ef0a64c 100644
> --- a/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> +++ b/c/src/lib/libbsp/i386/pc386/clock/ckinit.c
> @@ -27,6 +27,7 @@
>   #include <bsp/irq.h>
>   #include <bspopts.h>
>   #include <libcpu/cpuModel.h>
>   #define CLOCK_VECTOR 0
> @@ -36,15 +37,10 @@ uint32_t pc386_clock_click_count;
>   /* forward declaration */
>   void Clock_isr(void *param);
> -void Clock_driver_support_at_tick_tsc(void);
> -void Clock_driver_support_at_tick_empty(void);
> -uint32_t bsp_clock_nanoseconds_since_last_tick_tsc(void);
> -uint32_t bsp_clock_nanoseconds_since_last_tick_i8254(void);
> -void Clock_isr_handler(rtems_irq_hdl_param param);
> -int clockIsOn(const rtems_irq_connect_data* unused);
> -void clockOff(const rtems_irq_connect_data* unused);
> -void Clock_driver_install_handler(void);
> -void Clock_driver_support_initialize_hardware(void);
> +static void Clock_driver_support_at_tick_tsc(void);
> +static uint32_t bsp_clock_nanoseconds_since_last_tick_tsc(void);
> +static uint32_t bsp_clock_nanoseconds_since_last_tick_i8254(void);
> +static void Clock_isr_handler(void *param);
>    * Roughly the number of cycles per tick and per nanosecond. Note that these
> @@ -83,7 +79,7 @@ uint32_t (*Clock_driver_nanoseconds_since_last_tick)(void) = NULL;
>    *  What do we do at each clock tick?
>   #ifdef CLOCK_DRIVER_ISRS_PER_TICK
> @@ -99,10 +95,6 @@ void Clock_driver_support_at_tick_tsc(void)
>   #endif
>   #define Clock_driver_support_install_isr( _new, _old ) \
>     do { \
>       _old = NULL; \
> @@ -113,7 +105,7 @@ extern volatile uint32_t Clock_driver_isrs;
>    * Get nanoseconds using Pentium-compatible TSC register
>     uint64_t                 diff_nsec;
> @@ -140,7 +132,7 @@ uint32_t bsp_clock_nanoseconds_since_last_tick_tsc(void)
>    * Get nanoseconds using 8254 timer chip
>     uint32_t                 usecs, clicks, isrs;
>     uint32_t                 usecs1, usecs2;
> @@ -232,9 +224,7 @@ static void calibrate_tsc(void)
>     pc586_tsc_per_tick /= rtems_clock_get_ticks_per_second();
> -static void clockOn(
> -  const rtems_irq_connect_data* unused
> +static void clockOn(void)
>     pc386_isrs_per_tick        = 1;
>     pc386_microseconds_per_isr = rtems_configuration_get_microseconds_per_tick();
> @@ -267,43 +257,26 @@ static void clockOn(
>       calibrate_tsc();
> -  /* reset timer mode to standard (BIOS) value */
> -  outport_byte(TIMER_MODE, TIMER_SEL0 | TIMER_16BIT | TIMER_RATEGEN);
> -  outport_byte(TIMER_CNTR0, 0);
> -} /* Clock_exit */
> -  return ((i8259s_cache & 0x1) == 0);
>   bool Clock_isr_enabled = false;
> -  rtems_irq_hdl_param param
>     if ( Clock_isr_enabled )
>       Clock_isr( param );
> -static rtems_irq_connect_data clockIrqData = {
> -  BSP_PERIODIC_TIMER,
> -  Clock_isr_handler,
> -  0,
> -  clockOn,
> -  clockOff,
> -  clockIsOn
> -  if (!BSP_install_rtems_irq_handler (&clockIrqData)) {
> -    printk("Unable to install system clock ISR handler\n");
> -    rtems_fatal_error_occurred(1);
> +    BSP_PERIODIC_TIMER,
> +    "ckinit",
> +    Clock_isr_handler,
> +    NULL
> +  clockOn();
> @@ -326,7 +299,7 @@ void Clock_driver_support_initialize_hardware(void)
>     if ( use_8254 ) {
>       /* printk( "Use 8254\n" ); */
> -    Clock_driver_support_at_tick = Clock_driver_support_at_tick_empty;
> +    Clock_driver_support_at_tick = NULL;
>       Clock_driver_nanoseconds_since_last_tick =
>         bsp_clock_nanoseconds_since_last_tick_i8254;
>     } else {
> @@ -349,7 +322,13 @@ void Clock_driver_support_initialize_hardware(void)
>   #define Clock_driver_support_shutdown_hardware() \
>     do { \
> -    BSP_remove_rtems_irq_handler (&clockIrqData); \
clockOff() missing here?
> +    rtems_status_code status; \
> +    status = rtems_interrupt_handler_remove(  \
> +      BSP_PERIODIC_TIMER, \
> +      Clock_isr_handler,  \
> +      NULL  \
> +    assert(status == RTEMS_SUCCESSFUL); \
>     } while (0)
>   #include "../../../shared/clockdrv_shell.h"
> diff --git a/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c b/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c
> index d0af6b9..3a40ccc 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c
> @@ -17,6 +17,7 @@
>   #include <string.h>
>   #include <errno.h>
>   #include <sys/types.h>
>   #include <bsp.h>
> @@ -29,6 +30,7 @@
>   #define  INITIALIZE_MOUSE
>   /* Some configuration switches are present in the include file... */
>   #include "ps2_mouse.h"
> +#include "ps2_drv.h"
>   static void kbd_write_command_w(int data);
>   #if 0
> @@ -36,6 +38,7 @@ static void kbd_write_output_w(int data);
>   #endif
>   static unsigned char handle_kbd_event(void);
> +static void ps2_set_driver_handler(int port, mouse_parser_enqueue_handler handler);
>   /* used only by send_data - set by keyboard_interrupt */
>   static volatile unsigned char reply_expected = 0;
> @@ -56,14 +59,14 @@ static unsigned char mouse_reply_expected = 0;
>   #define AUX_INTS_ON  (KBD_MODE_KCC | KBD_MODE_SYS | KBD_MODE_MOUSE_INT | KBD_MODE_KBD_INT)
>   #define MAX_RETRIES	60		/* some aux operations take long time*/
> -static void ps2_mouse_interrupt(rtems_irq_hdl_param);
> +static void ps2_mouse_interrupt(void);
>   static mouse_parser_enqueue_handler driver_input_handler_ps2 = NULL;
>    * This routine sets the handler to handle the characters received
>    * from the serial port.
> -void ps2_set_driver_handler(
>     int                          port,
> @@ -78,30 +81,6 @@ static void mdelay( unsigned long t )
>   static void*    termios_ttyp_paux = NULL;
> -static void
> -isr_on(const rtems_irq_connect_data *unused)
> -  return;
> -static void
> -isr_off(const rtems_irq_connect_data *unused)
> -  return;
> -static int isr_is_on(const rtems_irq_connect_data *irq)
> -  return BSP_irq_enabled_at_i8259s( irq->name );
> -static rtems_irq_connect_data ps2_isr_data = { AUX_IRQ,
> -                                               ps2_mouse_interrupt,
> -                                               0,
> -                                               isr_on,
> -                                               isr_off,
> -                                               isr_is_on };
>    * Wait for keyboard controller input buffer to drain.
> @@ -223,7 +202,7 @@ static unsigned char handle_kbd_event(void)
>     return status;
> -static void ps2_mouse_interrupt(rtems_irq_hdl_param ignored)
Function type is wrong.
>     handle_kbd_event();
> @@ -323,11 +302,17 @@ static int queue_empty(void)
>   static int release_aux(void)
>     if (--aux_count)
>       return 0;
>     kbd_write_cmd(AUX_INTS_OFF);			    /* Disable controller ints */
>     kbd_write_command_w(KBD_CCMD_MOUSE_DISABLE);
> -  BSP_remove_rtems_irq_handler( &ps2_isr_data );
> +    AUX_IRQ,
> +    (rtems_interrupt_handler)ps2_mouse_interrupt,
> +    NULL
>     return 0;
> @@ -338,18 +323,21 @@ static int release_aux(void)
>   static int open_aux(void)
> -  int status;
>     if (aux_count++) {
>       return 0;
>     queue->head = queue->tail = 0;		/* Flush input queue */
> -  status = BSP_install_rtems_irq_handler( &ps2_isr_data );
> -  if( !status ) {
> -    printk("Error installing ps2-mouse interrupt handler!\n" );
> -    rtems_fatal_error_occurred( status );
> +    AUX_IRQ,
> +    "ps2_mouse",
> +    NULL
>     kbd_write_command_w(KBD_CCMD_MOUSE_ENABLE); /* Enable the auxiliary port on
>                                                    controller. */
> @@ -429,7 +417,7 @@ static int psaux_init( void )
>    * paux device driver INITIALIZE entry point.
> -rtems_device_driver paux_initialize(
> +rtems_device_driver paux_initialize(
>     rtems_device_major_number major,
>     rtems_device_minor_number minor,
>     void                      *arg)
> diff --git a/c/src/lib/libbsp/i386/pc386/console/vgacons.c b/c/src/lib/libbsp/i386/pc386/console/vgacons.c
> index d1143da..91d88ee 100644
> --- a/c/src/lib/libbsp/i386/pc386/console/vgacons.c
> +++ b/c/src/lib/libbsp/i386/pc386/console/vgacons.c
> @@ -1,5 +1,5 @@
> - *  This file contains the termios TTY driver for the i386
> + *  This file contains the termios TTY driver for the i386
>    *  vga.
>    *  COPYRIGHT (c) 1989-2011.
> @@ -20,23 +20,11 @@
>   #include <bsp.h>
>   #include <crt.h>
> +#include "keyboard.h"
>   #define VGACONS_STATIC static
> -  return BSP_irq_enabled_at_i8259s(irq->name);
> -static rtems_irq_connect_data keyboard_isr_data = {
> -  BSP_KEYBOARD,
> -  keyboard_interrupt,
> -  0,
> -  NULL,
> -  NULL,
> -  isr_is_on
>    *  vgacons_init
> @@ -44,7 +32,7 @@ static rtems_irq_connect_data keyboard_isr_data = {
>   VGACONS_STATIC void vgacons_init(int minor)
>      * Note:  We do not initialize the KBD interface here since
>      *        it was initialized regardless of whether the
>      *        vga is available or not.  Therefore it is initialized
> @@ -160,7 +148,7 @@ bool vgacons_probe(
>     int minor
> -  int         status;
>     static bool firstTime = true;
>     if ((*(unsigned char*) NB_MAX_ROW_ADDR == 0) &&
> @@ -175,11 +163,14 @@ bool vgacons_probe(
>      *  can be COM1 and you can still use the mouse/VGA for graphics.
>     if ( firstTime ) {
> -    status = BSP_install_rtems_irq_handler(&keyboard_isr_data);
> -    if (!status) {
> -      printk("Error installing keyboard interrupt handler!\n");
> -      rtems_fatal_error_occurred(status);
> +      BSP_KEYBOARD,
> +      "vgacons",
> +      keyboard_interrupt,
> +      NULL
>     firstTime = false;
> diff --git a/c/src/lib/libbsp/i386/pc386/include/bsp.h b/c/src/lib/libbsp/i386/pc386/include/bsp.h
> index 5e6dcc6..625d4ce 100644
> --- a/c/src/lib/libbsp/i386/pc386/include/bsp.h
> +++ b/c/src/lib/libbsp/i386/pc386/include/bsp.h
> @@ -80,6 +80,10 @@ extern int rtems_dec21140_driver_attach(struct rtems_bsdnet_ifconfig *, int);
>   #define BSP_DEC21140_NETWORK_DRIVER_NAME    "dc1"
>   #define BSP_DEC21140_NETWORK_DRIVER_ATTACH  rtems_dec21140_driver_attach
> +extern int rtems_3c509_driver_attach(struct rtems_bsdnet_ifconfig *config);
> +#define BSP_3C509_NETWORK_DRIVER_NAME    "3c1"
> +#define BSP_3C509_NETWORK_DRIVER_ATTACH  rtems_3c509_driver_attach
>   #ifndef RTEMS_BSP_NETWORK_DRIVER_NAME
>   #define RTEMS_BSP_NETWORK_DRIVER_NAME   BSP_DEC21140_NETWORK_DRIVER_NAME
>   #endif
> @@ -134,7 +138,7 @@ extern int rtems_dec21140_driver_attach(struct rtems_bsdnet_ifconfig *, int);
>   | Console Defines
> -|      WARNING: These Values MUST match the order in
> +|      WARNING: These Values MUST match the order in
>   |               Console_Configuration_Ports
>   #define    BSP_CONSOLE_VGA            0
> @@ -182,6 +186,10 @@ char          _IBMPC_inch_sleep (void);  /* from 'inch.c'   */
>   void Wait_X_ms(unsigned int timeToWait); /* from 'timer.c'  */
> +void Clock_driver_install_handler(void); /* from 'ckinit.c'  */
> +void Clock_driver_support_initialize_hardware(void); /* from 'ckinit.c'  */
> +size_t read_aux(char * buffer, size_t count); /* from 'ps2_mouse.c'  */
>   /* Definitions for BSPConsolePort */
>   #define BSP_CONSOLE_PORT_CONSOLE (-1)
>   #define BSP_CONSOLE_PORT_COM1    (BSP_UART_COM1)
> diff --git a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> index b23699d..13df124 100644
> --- a/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> +++ b/c/src/lib/libbsp/i386/pc386/ne2000/ne2000.c
> @@ -381,7 +381,7 @@ ne_check_status (struct ne_softc *sc, int from_irq_handler)
>   /* Handle an NE2000 interrupt.  */
>   static void
> -ne_interrupt_handler (rtems_irq_hdl_param cdata)
> +ne_interrupt_handler (void * cdata)
>     rtems_vector_number v = (rtems_vector_number) cdata;
>     struct ne_softc *sc;
> @@ -401,41 +401,18 @@ ne_interrupt_handler (rtems_irq_hdl_param cdata)
>   /* Turn NE2000 interrupts on.  */
>   static void
> -ne_interrupt_on (const rtems_irq_connect_data *irq)
> +ne_interrupt_on (rtems_vector_number name)
>   #ifdef DEBUG_NE
>     printk ("ne_interrupt_on()\n");
>   #endif
> -  sc = ne_device_for_irno (irq->name);
> +  sc = ne_device_for_irno (name);
>     if (sc != NULL)
>       outport_byte (sc->port + IMR, NE_INTERRUPTS);
> -/* Turn NE2000 interrupts off.  See ne_interrupt_on.  */
> -static void
> -ne_interrupt_off (const rtems_irq_connect_data *irq)
> -  struct ne_softc *sc;
> -#ifdef DEBUG_NE
> -  printk ("ne_interrupt_off()\n");
> -#endif
> -  if (sc != NULL)
> -    outport_byte (sc->port + IMR, 0);
> -/* Return whether NE2000 interrupts are on.  */
> -static int
> -ne_interrupt_is_on (const rtems_irq_connect_data *irq)
>   /* Initialize the NE2000 hardware.  */
>   static void
> @@ -516,20 +493,21 @@ ne_init_hardware (struct ne_softc *sc)
>   static void
>   ne_init_irq_handler(int irno)
> -  rtems_irq_connect_data irq;
>   #ifdef DEBUG_NE
>     printk("ne_init_irq_handler(%d)\n", irno);
>   #endif
> -  irq.name = irno;
> -  irq.hdl = ne_interrupt_handler;
> -  irq.handle = (rtems_irq_hdl) irno;
> -  irq.on = ne_interrupt_on;
> -  irq.off = ne_interrupt_off;
> -  irq.isOn = ne_interrupt_is_on;
> -  if (!BSP_install_rtems_irq_handler (&irq))
> -    rtems_panic ("Can't attach NE interrupt handler for irq %d\n", irno);
> +    irno,
> +    "ne2000",
> +    ne_interrupt_handler,
> +    (void *)irno
> +  ne_interrupt_on(irno);
>   /* The NE2000 packet receive daemon.  This task is started when the
> @@ -1075,7 +1053,7 @@ static int ne_set_multicast_filter(struct ne_softc* sc)
>     int i=0;
>     unsigned int port = sc->port;
>     unsigned char cmd = 0;
>     /* Save CMDR settings */
>     inport_byte(port + CMDR, cmd);
>     /* Change to page 1 */
> @@ -1087,7 +1065,7 @@ static int ne_set_multicast_filter(struct ne_softc* sc)
>     /* Revert to original CMDR settings */
> -  outport_byte(port + CMDR, cmd);
> +  outport_byte(port + CMDR, cmd);
>     return 0;
> @@ -1125,12 +1103,12 @@ ne_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
>         break;
>       break;
>     case SIOCADDMULTI:
>     case SIOCDELMULTI:
>       struct ifreq* ifr = (struct ifreq*) data;
> -    error = (command == SIOCADDMULTI ?
> +    error = (command == SIOCADDMULTI ?
>         ether_addmulti(ifr, &(sc->arpcom)) :
>         ether_delmulti(ifr, &(sc->arpcom)) );
>       /* ENETRESET indicates that driver should update its multicast filters */
> diff --git a/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c b/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c
> index d26464c..0ac6903 100644
> --- a/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c
> +++ b/c/src/lib/libbsp/i386/pc386/wd8003/wd8003.c
> @@ -18,6 +18,7 @@
>   #include <errno.h>
> @@ -73,7 +74,6 @@
>   struct wd_softc {
>     struct arpcom			arpcom;
>     struct mbuf			**rxMbuf;
>     struct mbuf			**txMbuf;
> @@ -84,6 +84,7 @@ struct wd_softc {
>     int				txBdActiveCount;
>     unsigned int 			port;
>     unsigned char			*base;
> @@ -127,7 +128,7 @@ static struct wd_softc wd_softc[NWDDRIVER];
>    * WD interrupt handler
>   static void
> -wd8003Enet_interrupt_handler (void *unused)
> +wd8003Enet_interrupt_handler (void)
>     unsigned int tport;
>     unsigned char status, status2;
> @@ -169,19 +170,6 @@ wd8003Enet_interrupt_handler (void *unused)
> -   * code should be moved from wd8003Enet_initialize_hardware
> -   * to this location
> -static int wdIsOn(const rtems_irq_connect_data* irq)
>    * Initialize the ethernet hardware
> @@ -191,7 +179,7 @@ wd8003Enet_initialize_hardware (struct wd_softc *sc)
>     int  i1, ultra;
>     char cc1, cc2;
>     unsigned char  temp;
>     unsigned int tport;
>     unsigned char *hwaddr;
> @@ -257,15 +245,15 @@ wd8003Enet_initialize_hardware (struct wd_softc *sc)
>      * Set up interrupts
> -  sc->irqInfo.hdl = wd8003Enet_interrupt_handler;
> -  sc->irqInfo.isOn = wdIsOn;
> -  st = BSP_install_rtems_irq_handler (&sc->irqInfo);
> -  if (!st)
> -		  sc->irqInfo.name);
> +    sc->name,
> +    "wd8003",
> +    (rtems_interrupt_handler)wd8003Enet_interrupt_handler,
> +    NULL
>   static void
> @@ -397,7 +385,7 @@ sendpacket (struct ifnet *ifp, struct mbuf *m)
>    * Driver transmit daemon
> -void
> +static void
>   wd_txDaemon (void *arg)
>   	struct wd_softc *sc = (struct wd_softc *)arg;
> @@ -607,9 +595,9 @@ rtems_wd_driver_attach (struct rtems_bsdnet_ifconfig *config, int attach)
>   		mtu = ETHERMTU;
>   	if (config->irno)
>   	else
> -		sc->irqInfo.name = 5;
> +		sc->name = 5;
>   	if (config->port)
>   		sc->port = config->port;
> diff --git a/c/src/lib/libbsp/i386/shared/comm/tty_drv.c b/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
> index aafb02a..16a40df 100644
> --- a/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
> +++ b/c/src/lib/libbsp/i386/shared/comm/tty_drv.c
> @@ -27,63 +27,19 @@
>   #include <termios.h>
>   #include <uart.h>
> +#include "tty_drv.h"
>   int BSP_poll_read(int);
>   /* Internal routines */
>   static int tty1_conSetAttr( int minor, const struct termios *t);
>   static int tty2_conSetAttr( int minor, const struct termios *t);
> -static void isr_on(const rtems_irq_connect_data *);
> -static void isr_off(const rtems_irq_connect_data *);
> -static int  isr_is_on(const rtems_irq_connect_data *);
>   extern BSP_polling_getchar_function_type BSP_poll_char;
>   extern int BSPConsolePort;
>   extern void rtems_set_waiting_id_comx( int port,  rtems_id id, rtems_event_set event );
> - * Interrupt structure for tty1
> -static rtems_irq_connect_data tty1_isr_data =
> -  BSP_UART_COM1_IRQ,
> -  BSP_uart_termios_isr_com1,
> -  0,
> -  isr_on,
> -  isr_off,
> -  isr_is_on};
> - * Interrupt structure for tty2
> -static rtems_irq_connect_data tty2_isr_data =
> -  BSP_UART_COM2_IRQ,
> -  BSP_uart_termios_isr_com2,
> -  0,
> -  isr_on,
> -  isr_off,
> -  isr_is_on};
> -static void
> -  return;
> -static void
> -  return;
> -static int
> -isr_is_on(const rtems_irq_connect_data *irq)
>    *  TTYS1 - device driver INITIALIZE entry point.
>   rtems_device_driver
> @@ -111,12 +67,14 @@ tty1_initialize(rtems_device_major_number major,
>     /* 9600-8-N-1, without hardware flow control */
>     BSP_uart_init( BSP_UART_COM1, 9600, CHR_8_BITS, 0, 0, 0 );
> -  status = BSP_install_rtems_irq_handler( &tty1_isr_data );
> -  if( !status )
> -    printk("Error installing ttyS1 interrupt handler!\n");
> +    BSP_UART_COM1_IRQ,
> +    "tty_drv",
> +    BSP_uart_termios_isr_com1,
> +    NULL
>      * Register the device
> @@ -132,7 +90,14 @@ tty1_initialize(rtems_device_major_number major,
>   static int tty1_last_close(int major, int minor, void *arg)
> -  BSP_remove_rtems_irq_handler( &tty1_isr_data );
> +    NULL
>     return 0;
> @@ -339,12 +304,15 @@ tty2_initialize(rtems_device_major_number major,
>     BSP_uart_init( BSP_UART_COM2, 9600, CHR_8_BITS, 0, 0, 0);
> -  status = BSP_install_rtems_irq_handler( &tty2_isr_data );
> -  if( !status )
> -    printk("Error installing serial console interrupt handler!\n");
> +    BSP_UART_COM2_IRQ,
> +    "tty_drv",
> +    BSP_uart_termios_isr_com2,
> +    NULL
> @@ -360,7 +328,14 @@ tty2_initialize(rtems_device_major_number major,
>   static int tty2_last_close(int major, int minor, void *arg)
> -  BSP_remove_rtems_irq_handler( &tty2_isr_data );
> +    NULL
>     return 0;
> diff --git a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> index 916379e..3e51f02 100644
> --- a/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> +++ b/c/src/lib/libbsp/i386/shared/smp/smp-imps.c
> @@ -79,6 +79,7 @@
>   #include <rtems/bspsmp.h>
>   #include <rtems/bspIo.h>
>   #include <libcpu/cpu.h>
>   extern void _pc386_delay(void);
> @@ -120,14 +121,14 @@ static void UDELAY(int x)
>     while ( _i-- )
>       _pc386_delay();
>   #define READ_MSR_LO(_x) \
>     (unsigned int)(read_msr(_x) & 0xffffffff)
>   static inline unsigned long long read_msr(unsigned int msr)
>     unsigned long long value;
>     asm volatile("rdmsr" : "=A" (value) : "c" (msr));
>     return value;
> @@ -385,7 +386,7 @@ imps_read_config_table(unsigned start, int count)
>       case IMPS_BCT_PROCESSOR:
>         if ( imps_num_cpus < rtems_configuration_get_maximum_processors() ) {
>   	add_processor((imps_processor *)start);
> -      } else
> +      } else
>           imps_num_cpus++;
>         start += 12;  /* 20 total */
>         break;
> @@ -751,22 +752,19 @@ rtems_isr ap_ipi_isr(
>   #include <rtems/irq.h>
> -static rtems_irq_connect_data apIPIIrqData = {
> -  16,
> -  (void *)ap_ipi_isr,
> -  0,
> -  NULL,            /* On */
> -  NULL,            /* Off */
> -  NULL,            /* IsOn */
>   extern void bsp_reset(void);
>   void ipi_install_irq(void)
> -  if (!BSP_install_rtems_irq_handler (&apIPIIrqData)) {
> -    printk("Unable to initialize IPI\n");
> -    bsp_reset();
> +    16,
> +    "smp-imps",
> +    ap_ipi_isr,
> +    NULL
>   #ifdef __SSE__
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
