[PATCH] add freelist data structure to score
Ashi
ashi08104 at gmail.com
Wed Jul 24 08:07:53 UTC 2013
On Mon, Jul 22, 2013 at 11:08 PM, Sebastian Huber <
> Hello Ashi,
> after the weekend I think we can further simplify the Freechain interface.
> The node_size and bump_count are not necessary for the Freechain core
> routines (_Freechain_Get() and _Freechain_Put()). Thus we should also
> remove them. In case the extend handler needs more information you can use
> something like that:
> typedef struct {
> Freechain_Control super;
> size_t bump_count;
> } MyFreechain;
> bool MyFreechainExtend(Freechain_**Control *super)
> MyFreechain *self = (MyFreechain *) super;
> Thanks, Sebastian, it's a cool idea! I've update the code to this idea now.
And I also fix a bug in my previous code. In my previous code, the
test_node in test case is:
typedef struct {
Object_Control obj;
int x;
}test_node;
It should be Chain_Node, not Object_Control here. However, because
Object_Control's size is bigger than Chain_Node, the test case doesn't
crash.
The github url is: https://github.com/ashi08104/rtems/tree/add_freelist
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
Cheers,
Zhongwei
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130724/09f945e9/attachment.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130724/09f945e9/attachment.obj>
