[PATCH 1/2] libmm score and stubs
Claus, Ric claus at slac.stanford.edu
Wed Jul 24 18:13:23 UTC 2013
There is already so much output generated during building that it slows a developer down to go through the output to determine what things must be paid attention to, what things can be ignored and what things are simply informational.  My vote is for a solution that doesn't add to that burden.  Most of the output is just distracting, but then on the other hand one does want to get some sense that the build is making progress.  It would be really nice, I think, to get just one over-printed line that shows what directory is being worked on and that newlines are generated only by error, warning, and perhaps informational messages.
Perhaps a possibility is to introduce --enable-mm on the configure line and then to print the compile-time warning only when there is a disagreement between the flag and the ability, i.e., --enable-mm is present, but mm support isn't, and --enable-mm is not present, but mm support is.  In the "normal" case (--enable-mm is present and mm is supported, and --enable-mm is not present and mm support isn't) the build system would stay quiet.
  Cheers,
              Ric
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] On Behalf Of Gedare Bloom [gedare at rtems.org]
Sent: Wednesday, July 24, 2013 9:50 AM
To: Rempel, Cynthia
Cc: rtems-devel at rtems.org
Subject: Re: [PATCH 1/2] libmm score and stubs
On Wed, Jul 24, 2013 at 12:43 PM, Rempel, Cynthia
>>From: gedare at gwmail.gwu.edu [gedare at gwmail.gwu.edu] on behalf of Gedare Bloom [gedare at rtems.org]
>>Sent: Wednesday, July 24, 2013 9:19 AM
>>To: Rempel, Cynthia
>>Cc: Hesham AL-Matary; rtems-devel at rtems.org
>>On Wed, Jul 24, 2013 at 11:02 AM, Rempel, Cynthia
>>> Hi Hesham,
>>> Thanks for doing the stubs :)
>>> Could you pull all the implementation specific parts of mm.h and mm.inl into a header called mmimpl.h ?
>>> It would then match the header-style score is heading towards...
>>> If the no_memorymanagement.c is for devices without mm support, could you have the functions print out a "stub warning/error" message? That way the user knows not to rely on memory management...
>>I don't think we should have the stubs do anything in the normal case.
> Why?
We should not add print statements to kernel code. Some users may
prefer to leave the stubs in place despite the lack of functionality.
Maybe you mean a compile-time warning, which would be fine to add.
>>We could add something when RTEMS_DEBUG is enabled.
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
