[PATCH] Removed legacy data types from arm
Thu Jul 25 13:22:15 UTC 2013
Hello Pavel,
On 2013-07-25 14:14, Pavel Pisa wrote:
> Hello Vipul Nayyar,
> I have weak appeal to not remove rtems_irq_hdl_param
> definition from RTEMS headers. It would cause problems
> for code which needs to be compatible with more RTEMS
> versions.
we want to remove the legacy interrupt API only from the RTEMS sources.
Applications can still use it.
> As for users/functions prototypes, I am not sure, conversion
> to (void * ) is OK with me, but on the other hand
> rtems_irq_hdl_param documents what is that parameter
> and where its value originates.
Ok, this is a valid point.  We can add a typedef to the IRQ extensions API if
there is a desire for this.
http://www.rtems.org/onlinedocs/doxygen/cpukit/html/group__rtems__interrupt__extension.html#gafc892e6717ccfe939498305dc8ee29f4
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
