rtems-testing with gdb option
Joel Sherrill
Joel.Sherrill at OARcorp.com
Sun Jul 28 18:09:55 UTC 2013
Depends on the simulator if that mode is supported. It is for simulators you run in a separate window from the gdb session.
Which simulator?
Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
Hello,
The rtems-testing module is provided with a -G option to put the executable to run in gdb mode, but this is not the case when we run it with -G. Is there something i am missing, can someone help me on this?
Thanks,
Sree
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130728/c6b62065/attachment.html>
