rtems-testing with gdb option
Sree harsha
sreehars at buffalo.edu
Sun Jul 28 18:46:34 UTC 2013
It is for pc386 to test the globaledf scheduler
Sent from my Verizon Wireless 4G LTE Smartphone
-------- Original message --------
Date: 07/28/2013 2:09 PM (GMT-05:00)
To: Sree Harsha Konduri <sreehars at buffalo.edu>
Cc: rtems-devel at rtems.org
Subject: Re: rtems-testing with gdb option
Depends on the simulator if that mode is supported. It is for simulators you run in a separate window from the gdb session.
Which simulator?
Sree Harsha Konduri <sreehars at buffalo.edu> wrote:
Hello,
The rtems-testing module is provided with a -G option to put the executable to run in gdb mode, but this is not the case when we run it with -G. Is there something i am missing, can someone help me on this?
Thanks,
Sree
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130728/8abcd0a3/attachment.html>
