Dependencies issue with the test applications
Tue Jul 30 09:27:48 UTC 2013
Hello R.,
On 2013-07-30 11:19, R. Diez wrote:
> Hi all:
> I am still trying to port RTEMS to the Arduino Due. After having implemented the start-up code and the basic serial port console, I am trying to get the hello.exe test application up and running.
> I noticed that, when I change a source file in my new Board Support Package, hello.exe does not get rebuilt. This is slowing me down, as I need to resort to a full build every time.
> I tried deleting just the hello.exe as a work-around, but that didn't work.
Deleting hello.exe should work.  In this case it must invoke the linker to
produce an new hello.exe which uses the updated libraries.
> Is there something wrong with the dependencies? Can someone else confirm this with an older, tried-and-true BSP?
Yes, this is a bug in the build system.  The *.exe files have no dependencies
to the libraries in the build tree.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
