[PATCH 2/2] smp: Provide cache optimized Per_CPU_Control
Tue Jul 30 16:19:26 UTC 2013
Why not just use the compiler attribute for alignment?
On 7/30/2013 10:44 AM, Sebastian Huber wrote:
> Delete _Per_CPU_Initialize_p.
>   c/src/lib/libbsp/i386/shared/irq/irq_asm.S |    5 ++-
>   c/src/lib/libbsp/sparc/shared/irq_asm.S    |   23 +++++++-------
>   cpukit/sapi/include/confdefs.h             |    3 +-
>   cpukit/score/include/rtems/score/percpu.h  |   45 +++++++++++++++++++--------
>   cpukit/score/src/percpu.c                  |    5 +--
>   5 files changed, 48 insertions(+), 33 deletions(-)
> diff --git a/c/src/lib/libbsp/i386/shared/irq/irq_asm.S b/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
> index 2b16234..bbc1afb 100644
> --- a/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
> +++ b/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
> @@ -99,9 +99,10 @@ SYM (_ISR_Handler):
>   .check_stack_switch:
>   	movl      esp, ebp                  /* ebp = previous stack pointer */
>   #if defined(RTEMS_SMP) && defined(BSP_HAS_SMP)
> -	movl     $SYM(_Per_CPU_Information_p), ebx
>   	call     SYM(_CPU_SMP_Get_current_processor)
> -	mov      (ebx,eax,4), ebx
> +	sall     $PER_CPU_CONTROL_SIZE_LOG2, eax
> +	addl     $SYM(_Per_CPU_Information), eax
> +	movl     eax, ebx
>           pushl    ecx
>           call     SYM(_ISR_SMP_Enter)
>           popl     ecx
> diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> index 5fb6a67..eb2f9c5 100644
> --- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
> +++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
> @@ -255,16 +255,18 @@ dont_fix_pil2:
>   SYM(_ISR_PER_CPU):
> -        sethi    %hi(_Per_CPU_Information_p), %l5
> -        add      %l5, %lo(_Per_CPU_Information_p), %l5
> +        sethi    %hi(_Per_CPU_Information), %l5
> +        add      %l5, %lo(_Per_CPU_Information), %l5
>       #if BSP_LEON3_SMP
>   	/* LEON3 SMP support */
>   	rd	%asr17, %l7
>   	srl	%l7, 28, %l7	/* CPU number is upper 4 bits so shift */
> -	sll	%l7, 2, %l7	/* l7 = offset */
> -	add	%l5, %l7, %l5
> +    #else
> +        mov	0, %l7
> +        nop
>       #endif
> -        ld       [%l5], %l5	/* l5 = pointer to per CPU */
> +	sll	%l7, PER_CPU_CONTROL_SIZE_LOG2, %l7	/* l7 = offset */
> +	add	%l5, %l7, %l5	/* l5 = pointer to per CPU */
>            *  On multi-core system, we need to use SMP safe versions
> @@ -456,19 +458,18 @@ isr_dispatch:
> -        ld       [%l5 + %lo(_Per_CPU_Information_p)], %l5
>       #if BSP_LEON3_SMP
>   	rd	%asr17, %l7
> -	add	%l5, %l7, %l5
>       #else
> -        nop
> +        mov	0, %l7
>           nop
>       #endif
>   #else
> diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
> index c969fa7..ed1385a 100644
> --- a/cpukit/sapi/include/confdefs.h
> +++ b/cpukit/sapi/include/confdefs.h
> @@ -2396,8 +2396,7 @@ const rtems_libio_helper rtems_fs_init_helper =
>     * Instantiate the Per CPU information based upon the user configuration.
>    #if defined(CONFIGURE_INIT)
> -   Per_CPU_Control _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
> -   Per_CPU_Control *_Per_CPU_Information_p[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
> +   Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
>    #endif
>   #endif
> diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
> index 11ba5f6..9b6866f 100644
> --- a/cpukit/score/include/rtems/score/percpu.h
> +++ b/cpukit/score/include/rtems/score/percpu.h
> @@ -33,6 +33,17 @@
>   extern "C" {
>   #endif
> +#if defined( RTEMS_SMP )
> +   * This ensures that on SMP configurations the individual per-CPU controls
> +   * are on different cache lines to prevent false sharing.  This define can be
> +   * used in assmbler code to easily get the per-CPU control for a particular
> +   * processor.
> +  #define PER_CPU_CONTROL_SIZE_LOG2 7
> +  #define PER_CPU_CONTROL_SIZE ( 1 << PER_CPU_CONTROL_SIZE_LOG2 )
> +#endif
>   #if !defined( ASM )
>   #ifndef __THREAD_CONTROL_DEFINED__
> @@ -184,32 +195,47 @@ typedef struct {
>     #endif
>   } Per_CPU_Control;
> +typedef struct {
> +  Per_CPU_Control per_cpu;
> +  char unused_space_for_cache_line_alignment
> +    [ PER_CPU_CONTROL_SIZE - sizeof( Per_CPU_Control ) ];
> +} Per_CPU_Control_envelope;
> +#else
> +typedef struct {
> +#endif
>    *  @brief Set of Per CPU Core Information
>    *  This is an array of per CPU core information.
> -extern Per_CPU_Control _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
> +extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
>   static inline Per_CPU_Control *_Per_CPU_Get( void )
>     _Assert_Thread_dispatching_repressed();
> -  return &_Per_CPU_Information[ _SMP_Get_current_processor() ];
> +  return &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu;
>   #else
> -#define _Per_CPU_Get() ( &_Per_CPU_Information[ 0 ] )
> +#define _Per_CPU_Get() ( &_Per_CPU_Information[ 0 ].per_cpu )
>   #endif
>   static inline Per_CPU_Control *_Per_CPU_Get_by_index( uint32_t index )
> -  return &_Per_CPU_Information[ index ];
> +  return &_Per_CPU_Information[ index ].per_cpu;
>   static inline uint32_t _Per_CPU_Get_index( const Per_CPU_Control *per_cpu )
> -  return ( uint32_t ) ( per_cpu - &_Per_CPU_Information[ 0 ] );
> +  const Per_CPU_Control_envelope *per_cpu_envelope =
> +    ( const Per_CPU_Control_envelope * ) per_cpu;
> +  return ( uint32_t ) ( per_cpu_envelope - &_Per_CPU_Information[ 0 ] );
> @@ -220,15 +246,6 @@ static inline void _Per_CPU_Send_interrupt( const Per_CPU_Control *per_cpu )
> - *  @brief Set of Pointers to Per CPU Core Information
> - *  This is an array of pointers to each CPU's per CPU data structure.
> - *  It should be simpler to retrieve this pointer in assembly language
> - *  that to calculate the array offset.
> -extern Per_CPU_Control *_Per_CPU_Information_p[];
>    *  @brief Initialize SMP Handler
>    *  This method initialize the SMP Handler.
> diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
> index 5e1a917..b041b45 100644
> --- a/cpukit/score/src/percpu.c
> +++ b/cpukit/score/src/percpu.c
> @@ -39,13 +39,10 @@
>        *  Initialize per cpu pointer table
> -    _Per_CPU_Information_p[0] = _Per_CPU_Get_by_index( 0 );
>       for ( cpu = 1 ; cpu < max_cpus; ++cpu ) {
>         Per_CPU_Control *p = _Per_CPU_Get_by_index( cpu );
> -      _Per_CPU_Information_p[cpu] = p;
>   #if CPU_ALLOCATE_INTERRUPT_STACK == TRUE
>           size_t size = rtems_configuration_get_interrupt_stack_size();
> @@ -101,5 +98,5 @@
>      * statically allocated per cpu structure.  And the fields are initialized
>      * as individual elements just like it has always been done.
> -  Per_CPU_Control _Per_CPU_Information[1];
> +  Per_CPU_Control_envelope _Per_CPU_Information[1];
>   #endif
