[Patch] Removing legacy method from arm csb337
Tue Jul 2 07:30:35 UTC 2013
On 07/02/2013 09:18 AM, Andreas Heinig wrote:
> On Tuesday 02 July 2013 14:52:52 Vipul Nayyar wrote:
>> >Hello Andreas,
>> >Thanks Andreas for pointing out that silly mistake. I didn't focus on other
>> >variables being used. I've updated the patch, and wanted to ask, what
>> >should be done when status code returned is not successful ?
>> >commit 9b21c1effe34cb716c00ea1c11777ef16ce9c7cc
>> >Author: Vipul Nayyar<nayyar_vipul at yahoo.com>
>> >Date:   Tue Jul 2 12:20:49 2013 +0530
>> >     Updated Legacy code in arm csb337
>> >diff --git a/c/src/lib/libbsp/arm/csb337/network/network.c
>> >b/c/src/lib/libbsp/arm/csb337/network/network.c index e31bcc0..53d60d2
>> >100644
>> >--- a/c/src/lib/libbsp/arm/csb337/network/network.c
>> >+++ b/c/src/lib/libbsp/arm/csb337/network/network.c
>> >@@ -358,6 +358,7 @@ void at91rm9200_emac_init(void *arg)
>> >      at91rm9200_emac_softc_t     *sc = arg;
>> >      struct ifnet *ifp = &sc->arpcom.ac_if;
>> >+    rtems_status_code stc = RTEMS_SUCCESSFUL;
> I think you should name the rtems_status_code either 'sc' or 'status'. These
> names are used by default in most of the RTEMS modules.
Yes, status is a good name.
> In your case I suggest to rename the at91rm9200_emac_softc_t variable, because
> sc is confusing here anyway.
The "sc" is the standard name for this in BSD code.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
