How memory access violation should be handled ?
Joel Sherrill Joel.Sherrill at OARcorp.com
Thu Jul 4 13:19:15 UTC 2013
Will this include enough information to know what type of access violation, the thread, the faulting address, and the instruction address?
It is a fatal error and it is a set of standard ones so maybe the master list can be extended.
Put yourself in the programmer's position. You want enough information to fix it.
Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
On 07/04/2013 04:40 AM, Hesham Moustafa wrote:
> Hi,
> What's the best way(s) to handle memory exceptions that result from memory
> access and permission violations ? for example, what should happen if an area
> of memory set to be read only and a thread tried to write data into this area ?
> Currently I am using it in debugging purpose to monitor exception handling and
> get some details, bit what should happen in practice ?
The systems should end up in an exception which should call
   rtems_fatal(
     RTEMS_FATAL_SOURCE_EXCEPTION,
     (rtems_fatal_code) exception_frame_pointer
This is all a single address space operating system can do.  The fatal
extensions can then deal with the error.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
rtems-devel mailing list
rtems-devel at rtems.org
http://www.rtems.org/mailman/listinfo/rtems-devel
