Thread-Local Storage, C++ Support and SMP
Gedare Bloom gedare at gwmail.gwu.edu
Fri Jul 5 15:06:50 UTC 2013
On Fri, Jul 5, 2013 at 3:33 AM, Sebastian Huber
> On 07/05/2013 03:10 AM, Gedare Bloom wrote:
>> Sebastian,
>> I have been working with the student to get the keys code mergeable. We
>> have
>> one last problem which maybe we can fix later. We need a generic freelist
>> implementation for some unlimited mode allocations. This is a boundary
>> case and
>> can be ignored for now. I will push for code we can merge soon. It should
>> fix
>> #3 (not sure if cancellation was tested) and 4, and #5 when we get
>> freelist
>> merged. The code all exists just needs review, fix, and merge.
> Its good that you work on this.  Is it possible to get an overview of the
> data structures and objects involved, because I am not that happy with some
> parts of the patch posted to the list.
Sure. The code exists in various branches at
https://github.com/ashi08104/rtems/branches
We have it like:
Key Objects are managed as Score Objects. A global tree contains all
of the values, searched first by pthread_key_t and then by thread_id.
A per-thread chain is maintained in the POSIX API Extensions for the
thread's key values for iterating during destructors. The values
themselves are either pre-allocated or pool allocated in a free list.
For a long time we looked at using an Score Object per Key Value, but
the overhead is high.
> I would do it as follows:
> Normal key objects which provide a tree root for key values (the thread ID
> is the tree key), e.g. no global tree.
We chose not to do one tree per key, although I suppose we can
revisit. I think I argued against it, but do not remember the reasons
now. Maybe overhead, or complexity? I forget. I think it is not too
hard to change to one Rbtree per Key Object.
> Key values are part of the corresponding key tree and in a list of key
> values for the corresponding thread.
> Each thread has a list of key values which is used to call the key
> destructors for the key values associated with the thread.
> The key values are not objects, but are pre-allocated in chunks.  So we have
> Configuration = {
>   .maximum_key_values = X | rtems_resource_unlimited(Y);
> In case no free key values are available we allocate a new chunk if the
> resource is unlimited or fail otherwise.
Yes, this is how we have done it too. The approach will introduce a
hopefully useful free list implementation that will need some extra
review and fix, but aims to be like a lightweight "slab allocator" for
the Score.
