[PATCH 5/5] smpatomic test case update
WeiY
wei.a.yang at gmail.com
Sun Jul 7 15:52:13 UTC 2013
Signed-off-by: WeiY <wei.a.yang at gmail.com>
testsuites/smptests/smpatomic01/tasks.c | 35 ++++++---------
testsuites/smptests/smpatomic02/tasks.c | 35 ++++++---------
testsuites/smptests/smpatomic03/tasks.c | 46 ++++++++-----------
testsuites/smptests/smpatomic04/tasks.c | 46 ++++++++-----------
testsuites/smptests/smpatomic05/tasks.c | 46 ++++++++-----------
testsuites/smptests/smpatomic06/tasks.c | 46 ++++++++-----------
testsuites/smptests/smpatomic07/tasks.c | 75 ++++++++++++++-----------------
7 files changed, 138 insertions(+), 191 deletions(-)
diff --git a/testsuites/smptests/smpatomic01/tasks.c b/testsuites/smptests/smpatomic01/tasks.c
index 36bb431..e3e7778 100644
--- a/testsuites/smptests/smpatomic01/tasks.c
+++ b/testsuites/smptests/smpatomic01/tasks.c
@@ -18,20 +18,21 @@
#include <rtems/rtems/atomic.h>
-#define TEST_REPEAT 200000
+#define TEST_REPEAT 1000
-#define ATOMIC_LOAD_NO_BARRIER(NAME, TYPE, cpuid, mem_bar) \
+#define ATOMIC_LOAD_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
- Atomic_##TYPE t = (Atomic_##TYPE)-1, a = 0; \
+ Atomic_##TYPE t; \
+ R_TYPE a; \
+ R_TYPE b; \
unsigned int i; \
- a = _Atomic_Load_##NAME(&t, mem_bar); \
- rtems_test_assert(a == t); \
for (i = 0; i < TEST_REPEAT; i++){ \
- t = (Atomic_##TYPE)rand(); \
+ b = (R_TYPE)rand(); \
+ atomic_init(&t, b); \
+ a = Atomic_Load_##NAME(&t, mem_bar); \
+ rtems_test_assert(a == b); \
- locked_printf("\nCPU%d _Atomic_Load_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Load_" #NAME ": SUCCESS\n", cpuid); \
rtems_task Test_task(
@@ -51,22 +52,14 @@ rtems_task Test_task(
/* Print that the task is up and running. */
/* test relaxed barrier */
- ATOMIC_LOAD_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_LOAD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_LOAD_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_LOAD_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
/* test acquire barrier */
- ATOMIC_LOAD_NO_BARRIER(int, Int, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_LOAD_NO_BARRIER(long, Long, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_LOAD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_LOAD_NO_BARRIER(32, Int32, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, unsigned long, cpu_num, ATOMIC_ORDER_ACQUIRE);
// ATOMIC_LOAD_NO_BARRIER(64, cpu_num);
diff --git a/testsuites/smptests/smpatomic02/tasks.c b/testsuites/smptests/smpatomic02/tasks.c
index a85f58c..c20f659 100644
--- a/testsuites/smptests/smpatomic02/tasks.c
+++ b/testsuites/smptests/smpatomic02/tasks.c
@@ -18,20 +18,21 @@
-#define ATOMIC_STORE_NO_BARRIER(NAME, TYPE, cpuid, mem_bar) \
+#define ATOMIC_STORE_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
+ R_TYPE a; \
+ R_TYPE b; \
unsigned int i; \
- _Atomic_Store_##NAME(&a, t, mem_bar); \
+ Atomic_Store_##NAME(&t, b, mem_bar); \
- locked_printf("\nCPU%d _Atomic_Store_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Store_" #NAME ": SUCCESS\n", cpuid); \
- ATOMIC_STORE_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_STORE_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_STORE_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_STORE_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_STORE_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
/* test release barrier */
- ATOMIC_STORE_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_STORE_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_STORE_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_STORE_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
- ATOMIC_STORE_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
// ATOMIC_STORE_NO_BARRIER(64, cpu_num);
diff --git a/testsuites/smptests/smpatomic03/tasks.c b/testsuites/smptests/smpatomic03/tasks.c
index fdf81ab..f14829c 100644
--- a/testsuites/smptests/smpatomic03/tasks.c
+++ b/testsuites/smptests/smpatomic03/tasks.c
@@ -18,20 +18,24 @@
-#define ATOMIC_FETCH_ADD_NO_BARRIER(NAME, TYPE, cpuid, mem_bar)\
+#define ATOMIC_FETCH_ADD_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
- Atomic_##TYPE t = 0, a = 0, b = 0; \
+ R_TYPE a; \
+ R_TYPE b; \
+ R_TYPE c; \
unsigned int i; \
- a = (Atomic_##TYPE)(rand() % ((Atomic_##TYPE)-1 / 2)); \
- b = (Atomic_##TYPE)(rand() % ((Atomic_##TYPE)-1 / 2)); \
- t = a; \
- _Atomic_Fetch_add_##NAME(&t, b, mem_bar); \
- rtems_test_assert(t == (Atomic_##TYPE)(a + b)); \
+ a = (R_TYPE)(rand() % ((R_TYPE)-1 / 2)); \
+ b = (R_TYPE)(rand() % ((R_TYPE)-1 / 2)); \
+ Atomic_Store_##NAME(&t, a, mem_bar); \
+ Atomic_Fetch_add_##NAME(&t, b, mem_bar); \
+ c = Atomic_Load_##NAME(&t, mem_bar); \
+ rtems_test_assert(c == (R_TYPE)(a + b)); \
- locked_printf("\nCPU%d _Atomic_Fetch_add_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Fetch_add_" #NAME ": SUCCESS\n", cpuid); \
@@ -51,31 +55,19 @@ rtems_task Test_task(
- ATOMIC_FETCH_ADD_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_ADD_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_ADD_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_ADD_NO_BARRIER(int, Int, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_ADD_NO_BARRIER(long, Long, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_ADD_NO_BARRIER(32, Int32, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_ADD_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_ADD_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
- ATOMIC_FETCH_ADD_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
// ATOMIC_FETCH_ADD_NO_BARRIER(64, cpu_num);
diff --git a/testsuites/smptests/smpatomic04/tasks.c b/testsuites/smptests/smpatomic04/tasks.c
index 006c80e..bada199 100644
--- a/testsuites/smptests/smpatomic04/tasks.c
+++ b/testsuites/smptests/smpatomic04/tasks.c
@@ -18,20 +18,24 @@
-#define ATOMIC_FETCH_SUB_NO_BARRIER(NAME, TYPE, cpuid, mem_bar)\
+#define ATOMIC_FETCH_SUB_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
+ R_TYPE a; \
+ R_TYPE b; \
+ R_TYPE c; \
unsigned int i; \
- t = a; \
- _Atomic_Fetch_sub_##NAME(&t, b, mem_bar); \
- rtems_test_assert(t == (Atomic_##TYPE)(a - b)); \
+ Atomic_Fetch_sub_##NAME(&t, b, mem_bar); \
+ rtems_test_assert(c == (R_TYPE)(a - b)); \
- locked_printf("\nCPU%d _Atomic_Fetch_sub_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Fetch_sub_" #NAME ": SUCCESS\n", cpuid); \
- ATOMIC_FETCH_SUB_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_SUB_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_SUB_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_SUB_NO_BARRIER(int, Int, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_SUB_NO_BARRIER(long, Long, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_SUB_NO_BARRIER(32, Int32, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_SUB_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_SUB_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
- ATOMIC_FETCH_SUB_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
// ATOMIC_FETCH_SUB_NO_BARRIER(64, cpu_num);
diff --git a/testsuites/smptests/smpatomic05/tasks.c b/testsuites/smptests/smpatomic05/tasks.c
index 0061c82..4e4faed 100644
--- a/testsuites/smptests/smpatomic05/tasks.c
+++ b/testsuites/smptests/smpatomic05/tasks.c
@@ -18,20 +18,24 @@
-#define ATOMIC_FETCH_AND_NO_BARRIER(NAME, TYPE, cpuid, mem_bar)\
+#define ATOMIC_FETCH_AND_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar)\
+ R_TYPE a; \
+ R_TYPE b; \
+ R_TYPE c; \
unsigned int i; \
- t = a; \
- _Atomic_Fetch_and_##NAME(&t, b, mem_bar); \
- rtems_test_assert(t == (Atomic_##TYPE)(a & b)); \
+ Atomic_Fetch_and_##NAME(&t, b, mem_bar); \
+ rtems_test_assert(c == (R_TYPE)(a & b)); \
- locked_printf("\nCPU%d _Atomic_Fetch_and_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Fetch_and_" #NAME ": SUCCESS\n", cpuid); \
- ATOMIC_FETCH_AND_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_AND_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_AND_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_AND_NO_BARRIER(int, Int, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_AND_NO_BARRIER(long, Long, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_AND_NO_BARRIER(32, Int32, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_AND_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_AND_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
- ATOMIC_FETCH_AND_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
// ATOMIC_FETCH_AND_NO_BARRIER(64, cpu_num);
diff --git a/testsuites/smptests/smpatomic06/tasks.c b/testsuites/smptests/smpatomic06/tasks.c
index ec29b28..bb84b95 100644
--- a/testsuites/smptests/smpatomic06/tasks.c
+++ b/testsuites/smptests/smpatomic06/tasks.c
@@ -18,20 +18,24 @@
-#define ATOMIC_FETCH_OR_NO_BARRIER(NAME, TYPE, cpuid, mem_bar) \
+#define ATOMIC_FETCH_OR_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
+ R_TYPE a; \
+ R_TYPE b; \
+ R_TYPE c; \
unsigned int i; \
- t = a; \
- _Atomic_Fetch_or_##NAME(&t, b, mem_bar); \
- rtems_test_assert(t == (Atomic_##TYPE)(a | b)); \
+ Atomic_Fetch_or_##NAME(&t, b, mem_bar); \
+ rtems_test_assert(c == (R_TYPE)(a | b)); \
- locked_printf("\nCPU%d _Atomic_Fetch_or_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Fetch_or_" #NAME ": SUCCESS\n", cpuid); \
- ATOMIC_FETCH_OR_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_OR_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_FETCH_OR_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_FETCH_OR_NO_BARRIER(int, Int, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_OR_NO_BARRIER(long, Long, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_FETCH_OR_NO_BARRIER(32, Int32, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_FETCH_OR_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_OR_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
- ATOMIC_FETCH_OR_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
// ATOMIC_FETCH_OR_NO_BARRIER(64, cpu_num);
diff --git a/testsuites/smptests/smpatomic07/tasks.c b/testsuites/smptests/smpatomic07/tasks.c
index 88c69be..13cfc92 100644
--- a/testsuites/smptests/smpatomic07/tasks.c
+++ b/testsuites/smptests/smpatomic07/tasks.c
@@ -18,35 +18,40 @@
-#define ATOMIC_CAS_NO_BARRIER(NAME, TYPE, cpuid, mem_bar) \
+#define ATOMIC_CAS_NO_BARRIER(NAME, TYPE, R_TYPE, cpuid, mem_bar) \
- Atomic_##TYPE a = 0, b = 0; \
+ R_TYPE a; \
+ R_TYPE b; \
unsigned int i; \
int r; \
- a = rand() % (Atomic_##TYPE)-1; \
- b = a; \
- r = _Atomic_Compare_exchange_##NAME(&b, a + 1, a - 1, mem_bar); \
- if(r != 0){ \
- locked_printf("\nCPU%d _Atomic_Compare_exchange_" #NAME ": FAILED\n", cpuid); \
- rtems_test_exit( 0 ); \
- b = a; \
- r = _Atomic_Compare_exchange_##NAME(&b, a, a - 1, mem_bar); \
- if((r == 0) ||((r != 0) && ((a - 1) != b))){ \
- b = a; \
- r = _Atomic_Compare_exchange_##NAME(&b, a + 1, a, mem_bar); \
- if(r != 0){ \
+ a = rand() % (R_TYPE)-1; \
+ b = a + 1; \
+ r = Atomic_Compare_exchange_##NAME(&t, &b, a - 1, mem_bar, memory_order_relaxed);\
+ if(r != 0){ \
+ locked_printf("\ntask%d: Atomic_Compare_exchange_" #NAME ": FAILED\n", (unsigned int)cpuid); \
+ rtems_test_exit( 0 ); \
+ r = Atomic_Compare_exchange_##NAME(&t, &a, a - 1, mem_bar, memory_order_relaxed);\
+ b = Atomic_Load_##NAME(&t, mem_bar); \
+ if((r == 0) ||((r != 0) && ((a - 1) != b))){ \
+ b = a + 1; \
+ r = Atomic_Compare_exchange_##NAME(&t, &b, a, mem_bar, memory_order_relaxed); \
+ if(r != 0){ \
- locked_printf("\nCPU%d _Atomic_Compare_exchange_" #NAME ": SUCCESS\n", cpuid); \
+ locked_printf("\nCPU%d Atomic_Compare_exchange_" #NAME ": SUCCESS\n", cpuid); \
@@ -66,31 +71,19 @@ rtems_task Test_task(
- ATOMIC_CAS_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_CAS_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_CAS_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELAXED_BARRIER);
- ATOMIC_CAS_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELAXED_BARRIER);
+ ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELAXED);
- ATOMIC_CAS_NO_BARRIER(int, Int, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_CAS_NO_BARRIER(long, Long, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_CAS_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_ACQUIRE_BARRIER);
- ATOMIC_CAS_NO_BARRIER(32, Int32, cpu_num, ATOMIC_ACQUIRE_BARRIER);
+ ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_ACQUIRE);
- ATOMIC_CAS_NO_BARRIER(int, Int, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_CAS_NO_BARRIER(long, Long, cpu_num, ATOMIC_RELEASE_BARRIER);
- ATOMIC_CAS_NO_BARRIER(ptr, Pointer, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, cpu_num, ATOMIC_ORDER_RELEASE);
- ATOMIC_CAS_NO_BARRIER(32, Int32, cpu_num, ATOMIC_RELEASE_BARRIER);
+ ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, cpu_num, ATOMIC_ORDER_RELEASE);
// ATOMIC_CAS_NO_BARRIER(64, cpu_num);
1.7.9.5
