Thread Life-Cycle Changes
Peter Dufault
dufault at hda.com
Mon Jul 8 13:01:43 UTC 2013
On Jul 8, 2013, at 03:18 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 07/05/2013 09:02 PM, Peter Dufault wrote:
>> On Jul 5, 2013, at 12:39 , Sebastian Huber<sebastian.huber at embedded-brains.de> wrote:
>>>> Ok, but in this case we should release 4.11 soon (weeks not months),
>>>> since this is on my critical path. It means also the POSIX and C++
>>>> support will be permanently broken in 4.11 in some areas.
>> Are these situations that are already broken and so existing POSIX or C++ RTEMS code will not be affected?
> I guess this is broken in all RTEMS versions.
I don't see any reason to hold up 4.11 then. If when fixed it "breaks" broken programs we just need to try to give a heads-up.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
