[GSoC] libmm project status
Hesham Moustafa
heshamelmatary at gmail.com
Tue Jul 9 15:59:41 UTC 2013
On Tue, Jul 9, 2013 at 3:16 AM, Gedare Bloom <gedare at rtems.org> wrote:
> I suggest we move mmtest3 into smptests. The mmtests should run on all
> targets, just some targets will only have stubs without functionality. The
> goal in the end is a usable high level api for all targets if it is
> possible.
Actually I was confused about where is the best place for mmtest3 and I
thought of smptests too. Should I move it with the same name ?
> Until we have bsp specific tests it will be hard to construct good generic
> tests.
> On Jul 8, 2013 8:07 PM, "Rempel, Cynthia" <cynt6007 at vandals.uidaho.edu>
> wrote:
>> Hi Hesham Moustafa,
>> Thanks for adding the .doc s :)
>> Is there a way to conditionally build the mmtests based on whether libmm
>> is being built?
>> My initial thought is something like an AM_CONDITIONAL
>> http://www.gnu.org/software/automake/manual/html_node/Subdirectories-with-AM_005fCONDITIONAL.html
>> Although another way to conditionally build the tests may be better...
>> Ideally if we went that route (and if feasible), if there was a
>> conditional being used for building libmm, we would use the same
>> conditional for the libmm tests...
>> That might make it a little easier to commit these tests incrementally
>> into RTEMS... and thus reduce the number of patches at the end of the
>> summer :)
>> Thanks!
>> Cindy
>> ________________________________________
>> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on
>> behalf of Rempel, Cynthia [cynt6007 at vandals.uidaho.edu]
>> Sent: Monday, July 08, 2013 3:55 PM
>> To: Hesham Moustafa; rtems-devel at rtems.org
>> Cc: Gedare Bloom
>> Subject: RE: [GSoC] libmm project status
>> Hi,
>> Thanks for providing the link directly to the testcases!
>> Could you copy the information about each test into:
>> mmtest1/mmtest1.doc
>> Simple tests that tries to install memory management entries
>> mmtest2/mmtest2.doc
>> + Install entries with specific memory attributes (e.g read only region) :
>> + Check for memory protection violations (writing to read only blocks)
>> + Reading from read only blocks.
>> + Write/Read to/from unmapped region (error!).
>> + Write to a valid entry that was installed and then uninstalled (error!).
>> mmtest3/mmtest3.doc
>> + Tests for libmm behavior on SMP environments.
>> + Create tasks for each core and start it.
>> + Check for memory consistency and page tables and memory attributes
>> validity.
>> That way we can quickly identify what each test does in 5 years... Good
>> job with the documentation :)
>> Cindy
>> behalf of Hesham Moustafa [heshamelmatary at gmail.com]
>> Sent: Monday, July 08, 2013 3:39 PM
>> To: rtems-devel at rtems.org
>> Cc: Gedare Bloom
>> Subject: [GSoC] libmm project status
>> Hi all,
>> I have posted a new thread to my blog that contains a brief introduction
>> to libmm and latest updates, here is the thread [1] Please take a look.
>> TODO: port libmm for Raspberry PI board on real hardware.
>> Questions :
>> I have created a new test case at libtests called mmtest3 [2] which
>> simulate SMP use case on QEMU/Realview. It simply tries to invoke the same
>> task (which calls libmm function) for each core. There is a fatal error at
>> startup that branches to data exception handler but I am not sure why.
>> Please take a look and tell me if I am doing something wrong with that test
>> case.
>> Other test cases (mmtest1, mmtest2) run successfully on the same platform.
>> [1]
>> http://heshamelmatary.blogspot.com/2013/07/gsoc-2013-libmm-for-rtems.html
>> [2]
>> https://github.com/heshamelmatary/rtems-gsoc2013/tree/low-level-libmm/testsuites/libtests/mmtest3
>> Regards,
>> Hesham
>> rtems-devel mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130709/78afd867/attachment-0001.html>
