[PATCH] Updated Legacy code in arm csb336
Peter Dufault
dufault at hda.com
Tue Jul 9 22:36:26 UTC 2013
On Jul 9, 2013, at 11:00 , Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 7/9/2013 9:50 AM, Sebastian Huber wrote:
>> On 07/09/2013 02:21 PM, Vipul Nayyar wrote:
>>> Seems like a valid point to me, that you got there.
>>> Sebastian, What do you suggest ? Simply remove the 1 from '#define
>>> USE_INTERRUPTS 1' or change #if defined() to simply #if ?
>> I suggest to use one of the two methods suggested by Peter. The #if one seems
>> to be more bullet proof, but I think in the RTEMS sources the #ifdef ones are
>> prevailing.
> I think we need to be heading to the #if style.
> As I mentioned, Chris and I recently discussed some cases where we
> think BSPs may not be testing bspopts.h (e.g. configure.ac) constants
> correctly.
I agree that RTEMS should move toward the method that I prefer.
But to minimize the number of changes that Vipul makes that need to be reviewed (by both himself and others) I think he should just change the "#define OPTION 1" to "#define OPTION". The RTEMS style guide can be updated to prefer the "#if" over "#ifdef" directive and additional changes can be made in the future.
If the additional changes fall within the scope of what Vipul is working on now ("Updated Legacy code") then I definitely think it should be changed to be done the way that I like.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
