[PATCH] Updated Legacy code in arm gba
Vipul Nayyar
nayyar_vipul at yahoo.com
Thu Jul 11 08:30:21 UTC 2013
c/src/lib/libbsp/arm/gba/clock/clockdrv.c | 66 +++++++++----------------------
1 file changed, 19 insertions(+), 47 deletions(-)
diff --git a/c/src/lib/libbsp/arm/gba/clock/clockdrv.c b/c/src/lib/libbsp/arm/gba/clock/clockdrv.c
index ea9c539..eeb217c 100644
--- a/c/src/lib/libbsp/arm/gba/clock/clockdrv.c
+++ b/c/src/lib/libbsp/arm/gba/clock/clockdrv.c
@@ -18,33 +18,36 @@
#include <bsp.h>
#include <bsp/irq.h>
#include <gba.h>
+#include <assert.h>
void Clock_isr(rtems_irq_hdl_param arg);
-static void clock_isr_on(const rtems_irq_connect_data *unused);
-static void clock_isr_off(const rtems_irq_connect_data *unused);
-static int clock_isr_is_on(const rtems_irq_connect_data *irq);
-rtems_irq_connect_data clock_isr_data = {
- .name = BSP_IRQ_TIMER3,
- .hdl = Clock_isr,
- .handle = NULL,
- .on = clock_isr_on,
- .off = clock_isr_off,
- .isOn = clock_isr_is_on,
#define Clock_driver_support_at_tick()
#define Clock_driver_support_install_isr( _new, _old ) \
do { \
- BSP_install_rtems_irq_handler(&clock_isr_data); \
+ rtems_status_code status = RTEMS_SUCCESSFUL; \
+ status = rtems_interrupt_handler_install( \
+ BSP_IRQ_TIMER3, \
+ "Clock", \
+ RTEMS_INTERRUPT_UNIQUE, \
+ Clock_isr, \
+ NULL \
+ assert(status == RTEMS_SUCCESSFUL); \
_old = NULL; \
} while(0)
-#define Clock_driver_support_shutdown_hardware() \
- do { \
- BSP_remove_rtems_irq_handler(&clock_isr_data); \
+#define Clock_driver_support_shutdown_hardware() \
+ do { \
+ status = rtems_interrupt_handler_remove( \
+ BSP_IRQ_TIMER3, \
+ Clock_isr, \
+ NULL \
} while (0)
@@ -86,35 +89,4 @@ void Clock_driver_support_initialize_hardware(void)
GBA_REG_TM3CNT = (0x00c0|GBA_TMCNT_PS);
- * @brief This function is empty
- * @param unused an unused parameter
- * @return None
- * @return None
- * @param irq unused
- * @return constant 1
- return 1;
#include "../../../shared/clockdrv_shell.h"
1.7.11.7
