[PATCH] Updated Legacy code in arm rtl22xx
Vipul Nayyar
nayyar_vipul at yahoo.com
Thu Jul 11 09:33:45 UTC 2013
c/src/lib/libbsp/arm/rtl22xx/network/network.c | 25 +++++++++++++++++--------
1 file changed, 17 insertions(+), 8 deletions(-)
diff --git a/c/src/lib/libbsp/arm/rtl22xx/network/network.c b/c/src/lib/libbsp/arm/rtl22xx/network/network.c
index 3b54862..cd104f7 100644
--- a/c/src/lib/libbsp/arm/rtl22xx/network/network.c
+++ b/c/src/lib/libbsp/arm/rtl22xx/network/network.c
@@ -3,18 +3,13 @@
#include <sys/mbuf.h>
#include <bsp/irq.h>
#include <libchip/cs8900.h>
+#include <assert.h>
#define CS8900_BASE 0x20000300
unsigned int bsp_cs8900_io_base = 0;
unsigned int bsp_cs8900_memory_base = 0;
cs8900_device *g_cs;
void cs8900_isr(rtems_irq_hdl_param unused);
-rtems_irq_connect_data cs8900_isr_data = {LPC22xx_INTERRUPT_EINT2,
- cs8900_isr,
- NULL,
- NULL,
- NULL,
- NULL};
char g_enetbuf[1520];
@@ -69,13 +64,27 @@ unsigned short cs8900_mem_get_reg (cs8900_device *cs, unsigned long reg)
void cs8900_attach_interrupt (cs8900_device *cs)
+ rtems_status_code status = RTEMS_SUCCESSFUL;
g_cs = cs;
- BSP_install_rtems_irq_handler(&cs8900_isr_data);
+ status = rtems_interrupt_handler_install(
+ LPC22xx_INTERRUPT_EINT2,
+ "Network",
+ RTEMS_INTERRUPT_UNIQUE,
+ cs8900_isr,
+ NULL
+ assert(status == RTEMS_SUCCESSFUL);
void cs8900_detach_interrupt (cs8900_device *cs)
- BSP_remove_rtems_irq_handler(&cs8900_isr_data);
+ status = rtems_interrupt_handler_remove(
+ cs8900_isr,
+ NULL
unsigned short cs8900_get_data_block (cs8900_device *cs, unsigned char *data)
1.7.11.7
