[PATCH] Updated Legacy code in arm rtl22xx
Fri Jul 12 00:56:27 UTC 2013
Joel Sherrill wrote:
> Should this be print? But this is beyond his scope
No, it is just a case of "... %#6x\n" -> "... %#6xn" so the line feed at
the end of the format string is now missing.
> Chris Johns<chrisj at rtems.org>  wrote:
> Vipul Nayyar wrote:
>> -    printf("cs8900_io_set_reg: reg: %#6x, val %#6x\n",
>> +    printf("cs8900_io_set_reg: reg: %#6x, val %#6xn",
> Did you do a global search and replace of '\' ? Please fix up and resubmit.
> Chris
> rtems-devel mailing list
> rtems-devel at rtems.org
