[PATCH] Add basic infrastructure for libmm
Gedare Bloom
gedare at gwmail.gwu.edu
Sat Jul 13 18:36:22 UTC 2013
I think this patch is missing the cpukit/score files.
On Fri, Jul 12, 2013 at 8:35 PM, Hesham Moustafa
<heshamelmatary at gmail.com> wrote:
> Hi,
> This patch includes basic files and modifications to add libmm support. It
> includes the high-level score functions API, stubs for BSPs that do not
> support libmm at low-level and a test case called mmtest1. SPARC BSP is
> modified to support the stubs and run mmtest1. Another big patch is ready to
> add nop (stubs) libmm support for *ALL* BSPs after this patch is reviewed.
> diff --git a/testsuites/libtests/mmtest1/Makefile.am
> b/testsuites/libtests/mmtest1/Makefile.am
> new file mode 100644
> index 0000000..a08e557
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/Makefile.am
> @@ -0,0 +1,18 @@
> +rtems_tests_PROGRAMS = mmtest1
> +mmtest1_SOURCES = init.c system.h
> +dist_rtems_tests_DATA = mmtests.scn
> +include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> +include $(top_srcdir)/../automake/compile.am
> +include $(top_srcdir)/../automake/leaf.am
> +LINK_OBJS = $(mmtest1_OBJECTS) $(mmtest1_LDADD)
> +LINK_LIBS = $(mmtest1_LDLIBS)
> +mmtest1$(EXEEXT): $(mmtest1_OBJECTS) $(mmtest1_DEPENDENCIES)
> + @rm -f mmtest1$(EXEEXT)
> + $(make-exe)
> +include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/libtests/mmtest1/init.c
> b/testsuites/libtests/mmtest1/init.c
> index 0000000..9b5c4c4
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/init.c
> @@ -0,0 +1,59 @@
> +/* Init
> + * This routine is the initialization task for this test program.
> + * Copyright (c) 2013 Gedare Bloom.
> + * Copyright (c) 2012 Hesham Al-Matary.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> +#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
> +#define CONFIGURE_INIT
> +#include "system.h"
> +#include <stdio.h>
> +#include <stdlib.h>
> +#include <rtems/score/mm.h>
> +rtems_task Init(
> + rtems_task_argument ignored
> + Memory_management_Entry mme1 = {
> + .name = "Valid Entry-1",
> + .base = 0x00100000,
> + .size = 0x200000,
> + .installed = false,
> + .bsp_mme = NULL
> + Memory_management_Entry mme2 = {
> + .name = "Valid Entry-2",
> + .base = 0x00400000,
> + .size = 0x100000,
> + .bsp_mme = NULL
> + puts( "\n\n*** Start of mmtest1 ***\n" );
> + /* Initializing libmm is now done at BSP startup */
> + //puts( "initialize the memory management manager\n");
> + //_Memory_management_Initialize ( );
Delete commented-out code that is not going to be needed.
> + printf("Test 1: Installing Entry-1 \
> +and set it as Read only\n");
> + _Memory_management_Install_entry( &mme1,
> RTEMS_MM_REGION_PROTECTION_READ_ONLY);
> + printf("Test 2 : Installing Entry-2\
> +and set it as Write enabled\n");
> + _Memory_management_Install_entry( &mme2,
> RTEMS_MM_REGION_PROTECTION_WRITE);
> + printf( "\n\n*** End of mmtest1 ***\n" );
> + exit( 0 );
> diff --git a/testsuites/libtests/mmtest1/mmtest1.doc
> b/testsuites/libtests/mmtest1/mmtest1.doc
> index 0000000..210a761
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/mmtest1.doc
> @@ -0,0 +1 @@
> +Simple tests that tries to install memory management entries.
> diff --git a/testsuites/libtests/mmtest1/mmtests.scn
> b/testsuites/libtests/mmtest1/mmtests.scn
> index 0000000..8b13789
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/mmtests.scn
> @@ -0,0 +1 @@
Add the contents of the output to screen to this file.
> diff --git a/testsuites/libtests/mmtest1/system.h
> b/testsuites/libtests/mmtest1/system.h
> index 0000000..7560e1d
> --- /dev/null
> +++ b/testsuites/libtests/mmtest1/system.h
> @@ -0,0 +1,33 @@
> +/* system.h
> +#include <rtems.h>
> +/* functions */
> +rtems_task Init(
> + rtems_task_argument argument
> +/* configuration information */
> +#include <bsp.h> /* for device driver prototypes */
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS 9
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
> +#include <rtems/confdefs.h>
> +/* end of include file */
> diff --git a/c/src/lib/libcpu/shared/include/mm.h
> b/c/src/lib/libcpu/shared/include/mm.h
> index 0000000..02903f1
> --- /dev/null
> +++ b/c/src/lib/libcpu/shared/include/mm.h
> @@ -0,0 +1,23 @@
> +#ifndef __LIBCPU_MM_H
> +#define __LIBCPU_MM_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +void _CPU_Memory_management_Initialize(void);
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> index 0000000..2e3f528
> --- /dev/null
> +++ b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> @@ -0,0 +1,17 @@
> + * Copyright (c) 2013 Hesham AL-Matary
> +#include <rtems.h>
> +#include <libcpu/mm.h>
> +void _CPU_Memory_management_Initialize( void ) { }
> +void _CPU_Memory_management_Install_entry( Memory_management_Entry *mpe,
> uint32_t flags ) { }
> +void _CPU_Memory_management_Uninstall_entry( Memory_management_Entry *mpe )
We should consider making the interface take arguments like "name,
base, size" directly instead of these Memory_management_Entry
structures.
> diff --git a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> index 988f3ec..545d945 100644
> --- a/c/src/lib/libbsp/sparc/erc32/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/erc32/Makefile.am
> @@ -3,6 +3,7 @@ ACLOCAL_AMFLAGS = -I ../../../../aclocal
> include $(top_srcdir)/../../../../automake/compile.am
> include_bspdir = $(includedir)/bsp
> +include_libcpudir = $(includedir)/libcpu
> dist_project_lib_DATA = bsp_specs
> @@ -18,6 +19,8 @@ noinst_PROGRAMS =
> include_HEADERS += include/erc32.h
> include_HEADERS += ../../shared/include/coverhd.h
> +include_libcpu_HEADERS = ../../../libcpu/shared/include/mm.h
> noinst_LIBRARIES = libbspstart.a
> libbspstart_a_SOURCES = ../../sparc/shared/start.S
> project_lib_DATA = start.$(OBJEXT)
> @@ -65,6 +68,9 @@ libbsp_a_SOURCES += \
> ../../shared/src/irq-server.c \
> ../../shared/src/irq-shell.c
> +# LIBMM
> +libbsp_a_SOURCES += ../../../libcpu/shared/src/no_memorymanagement.c
> if HAS_SMP
> libbsp_a_SOURCES += ../../shared/smp/getcpuid.c ../../shared/smp/smp_stub.c
> endif
> diff --git a/c/src/lib/libbsp/sparc/erc32/preinstall.am
> b/c/src/lib/libbsp/sparc/erc32/preinstall.am
> index a235296..e422e9d 100644
> --- a/c/src/lib/libbsp/sparc/erc32/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/erc32/preinstall.am
> @@ -33,6 +33,11 @@ $(PROJECT_INCLUDE)/bsp/$(dirstamp):
> @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
> +$(PROJECT_INCLUDE)/libcpu/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
> + @: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
> $(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
> PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
> @@ -61,6 +66,10 @@ $(PROJECT_INCLUDE)/coverhd.h:
> ../../shared/include/coverhd.h $(PROJECT_INCLUDE)/
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
> +$(PROJECT_INCLUDE)/libcpu/mm.h: ../../../libcpu/shared/include/mm.h
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/mm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/mm.h
> $(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT) $(PROJECT_LIB)/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
> TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
> diff --git a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> index ae6dfb0..bafccee 100644
> --- a/c/src/lib/libbsp/sparc/leon2/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon2/Makefile.am
> @@ -28,6 +29,7 @@ include_HEADERS += ../../sparc/shared/include/pci.h
> nodist_include_HEADERS = include/bspopts.h
> nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
> DISTCLEANFILES = include/bspopts.h
> noinst_PROGRAMS =
> @@ -118,6 +120,9 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
> # timer
> libbsp_a_SOURCES += timer/timer.c
> +# LIBMM
> if HAS_SMP
> endif
> diff --git a/c/src/lib/libbsp/sparc/leon2/preinstall.am
> b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> index 84aa2b4..d4fa808 100644
> --- a/c/src/lib/libbsp/sparc/leon2/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon2/preinstall.am
> @@ -121,6 +126,10 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h:
> ../../shared/include/bootcard.h $(PROJECT_INC
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
> $(PROJECT_INCLUDE)/leon.h: include/leon.h $(PROJECT_INCLUDE)/$(dirstamp)
> $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/leon.h
> PREINSTALL_FILES += $(PROJECT_INCLUDE)/leon.h
> diff --git a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> index 8b21893..113ff99 100644
> --- a/c/src/lib/libbsp/sparc/leon3/Makefile.am
> +++ b/c/src/lib/libbsp/sparc/leon3/Makefile.am
> @@ -12,6 +13,7 @@ include_HEADERS += ../../sparc/shared/include/debug_defs.h
> noinst_PROGRAMS =
> @@ -112,6 +114,9 @@ libbsp_a_SOURCES += ../../sparc/shared/i2c/i2cmst.c
> # timer
> +# LIBMM
> if HAS_SMP
> libbsp_a_SOURCES += smp/getcpuid.c
> libbsp_a_SOURCES += smp/smp_leon3.c
> diff --git a/c/src/lib/libbsp/sparc/leon3/preinstall.am
> b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> index dffbb5a..6d7b5be 100644
> --- a/c/src/lib/libbsp/sparc/leon3/preinstall.am
> +++ b/c/src/lib/libbsp/sparc/leon3/preinstall.am
> @@ -57,6 +62,10 @@ $(PROJECT_INCLUDE)/bsp/bootcard.h:
> Thanks,
> Hesham
Leave off the signature line. If you use "git-send-email" it should
just work I think. Instructions are on the wiki.
http://www.rtems.org/wiki/index.php/Git_Users#Submitting_a_Patch
