[PATCH 4/4] Add mmtest1 test case
Hesham AL-Matary
heshamelmatary at gmail.com
Sat Jul 13 23:05:21 UTC 2013
From: Hesham ALmatary <heshamelmatary at gmail.com>
testsuites/libtests/Makefile.am | 2 +-
testsuites/libtests/configure.ac | 1 +
testsuites/libtests/mmtest1/Makefile.am | 18 +++++++++++
testsuites/libtests/mmtest1/init.c | 55 +++++++++++++++++++++++++++++++++
testsuites/libtests/mmtest1/mmtest1.doc | 1 +
testsuites/libtests/mmtest1/mmtests.scn | 7 +++++
testsuites/libtests/mmtest1/system.h | 33 ++++++++++++++++++++
7 files changed, 116 insertions(+), 1 deletion(-)
create mode 100644 testsuites/libtests/mmtest1/Makefile.am
create mode 100644 testsuites/libtests/mmtest1/init.c
create mode 100644 testsuites/libtests/mmtest1/mmtest1.doc
create mode 100644 testsuites/libtests/mmtest1/mmtests.scn
create mode 100644 testsuites/libtests/mmtest1/system.h
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index d1ffabc..d56398b 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -16,7 +16,7 @@ SUBDIRS += flashdisk01
SUBDIRS += bspcmdline01 cpuuse devfs01 devfs02 devfs03 devfs04 \
deviceio01 devnullfatal01 dumpbuf01 gxx01 \
malloctest malloc02 malloc03 malloc04 malloc05 heapwalk \
- putenvtest monitor monitor02 rtmonuse stackchk stackchk01 \
+ putenvtest monitor monitor02 mmtest1 rtmonuse stackchk stackchk01 \
termios termios01 termios02 termios03 termios04 termios05 \
termios06 termios07 termios08 \
rtems++ tztest block01 block02 block03 block04 block05 block06 block07 \
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 741c603..c1dbb78 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -85,6 +85,7 @@ malloc02/Makefile
malloc03/Makefile
malloc04/Makefile
malloc05/Makefile
+mmtest1/Makefile
monitor/Makefile
monitor02/Makefile
mouse01/Makefile
diff --git a/testsuites/libtests/mmtest1/Makefile.am b/testsuites/libtests/mmtest1/Makefile.am
new file mode 100644
index 0000000..a08e557
--- /dev/null
+++ b/testsuites/libtests/mmtest1/Makefile.am
@@ -0,0 +1,18 @@
+rtems_tests_PROGRAMS = mmtest1
+mmtest1_SOURCES = init.c system.h
+dist_rtems_tests_DATA = mmtests.scn
+include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
+include $(top_srcdir)/../automake/compile.am
+include $(top_srcdir)/../automake/leaf.am
+LINK_OBJS = $(mmtest1_OBJECTS) $(mmtest1_LDADD)
+LINK_LIBS = $(mmtest1_LDLIBS)
+mmtest1$(EXEEXT): $(mmtest1_OBJECTS) $(mmtest1_DEPENDENCIES)
+ @rm -f mmtest1$(EXEEXT)
+ $(make-exe)
+include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/libtests/mmtest1/init.c b/testsuites/libtests/mmtest1/init.c
index 0000000..d90e52d
--- /dev/null
+++ b/testsuites/libtests/mmtest1/init.c
@@ -0,0 +1,55 @@
+/* Init
+ * This routine is the initialization task for this test program.
+ * Copyright (c) 2013 Gedare Bloom.
+ * Copyright (c) 2012 Hesham Al-Matary.
+ * http://www.rtems.com/license/LICENSE.
+#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__
+#define CONFIGURE_INIT
+#include "system.h"
+#include <stdio.h>
+#include <stdlib.h>
+#include <rtems/score/mm.h>
+rtems_task Init(
+ rtems_task_argument ignored
+ Memory_management_Entry mme1 = {
+ .name = "Valid Entry-1",
+ .base = 0x00100000,
+ .size = 0x200000,
+ .installed = false,
+ .bsp_mme = NULL
+ Memory_management_Entry mme2 = {
+ .name = "Valid Entry-2",
+ .base = 0x00400000,
+ .size = 0x100000,
+ .bsp_mme = NULL
+ puts( "\n\n*** Start of mmtest1 ***\n" );
+ printf("Test 1: Installing Entry-1 \
+and set it as Read only\n");
+ _Memory_management_Install_entry( &mme1, RTEMS_MM_REGION_PROTECTION_READ_ONLY);
+ printf("Test 2 : Installing Entry-2\
+and set it as Write enabled\n");
+ _Memory_management_Install_entry( &mme2, RTEMS_MM_REGION_PROTECTION_WRITE);
+ printf( "\n\n*** End of mmtest1 ***\n" );
+ exit( 0 );
diff --git a/testsuites/libtests/mmtest1/mmtest1.doc b/testsuites/libtests/mmtest1/mmtest1.doc
index 0000000..210a761
--- /dev/null
+++ b/testsuites/libtests/mmtest1/mmtest1.doc
@@ -0,0 +1 @@
+Simple tests that tries to install memory management entries.
diff --git a/testsuites/libtests/mmtest1/mmtests.scn b/testsuites/libtests/mmtest1/mmtests.scn
index 0000000..6ba15c2
--- /dev/null
+++ b/testsuites/libtests/mmtest1/mmtests.scn
@@ -0,0 +1,7 @@
+*** Start of mmtest1 ***
+Test 1: Installing Entry-1 and set it as Read only
+Test 2 : Installing Entry-2and set it as Write enabled
+*** End of mmtest1 ***
diff --git a/testsuites/libtests/mmtest1/system.h b/testsuites/libtests/mmtest1/system.h
index 0000000..7560e1d
--- /dev/null
+++ b/testsuites/libtests/mmtest1/system.h
@@ -0,0 +1,33 @@
+/* system.h
+#include <rtems.h>
+/* functions */
+rtems_task Init(
+ rtems_task_argument argument
+/* configuration information */
+#include <bsp.h> /* for device driver prototypes */
+/* NOTICE: the clock driver is explicitly disabled */
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
+#define CONFIGURE_MAXIMUM_TASKS 9
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_USE_DEVFS_AS_BASE_FILESYSTEM
+#include <rtems/confdefs.h>
+/* end of include file */
1.8.3.1
