[GSOC] Help regarding pc386 3c509.c file
Vipul Nayyar
nayyar_vipul at yahoo.com
Wed Jul 17 13:58:07 UTC 2013
Hello,
Thanks for the guidance. As in the case of 3c509, there is I believe only one method, that need to be added to bsp.h . But for other files, there are multiple methods for example in ckinit, that are not internally used, but I feel they definitely cannot be removed(like a method to install interrupt handler, etc). So, I hope having multiple prototypes in bsp.h from a single file should not be a problem. Right ?
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Cc: Vipul Nayyar <nayyar_vipul at yahoo.com>
Sent: Tuesday, 16 July 2013 11:11 PM
Subject: Re: [GSOC] Help regarding pc386 3c509.c file
Hello Vipur,
its good that you ask. Actually you found a bug in the BSPs using
3c509.c. As Joel already said this rtems_3c509_driver_attach() is the
main entry point of the network interface driver and can be used by
applications to use this interface.
So lets have a look which BSP is affected:
~/git-rtems $ grep -r 3c509.c c | grep 'am:'
c/src/lib/libbsp/i386/pc386/Makefile.am:3c509_rel_SOURCES = 3c509/3c509.c
So luckily only the pc386 BSP. You can now add the prototype to
"c/src/lib/libbsp/i386/pc386/include/bsp.h" line 83. Just have a look
at the other network interface definitions.
On 15.07.2013 18:47, Vipul Nayyar wrote:
> Hello,
> I'm currently working on i386 pc386 BSP. This problem concerns the 3c509/3c509.c file.
> After turning rtems_3c509_driver_attach() from global to static, since it's not being used anywhere outside in the tree, I get this warning for unused function. Ideally I should delete it. If I delete it, then I end up deleting all other functions also. But this rtems_3c509_driver_attach() stores references to different handlers & calls them by passing a ifnet structure to if_attach(). I think it's a very important method & I don't think I should delete it.
> But this function rtems_3c509_driver_attach() is neither called locally , nor globally.
> If I were to treat it as global function, I think it should be declared in a header file, because declaring a global function locally seems bad.
> If I were to treat it as static, then I get this warning of unused function during compilation. How should I proceed ?
> Regards
> Vipul Nayyar
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130717/12aee3d2/attachment-0001.html>
