[PATCH 17/25] posix: Create semaphore implementation header
Sebastian Huber
Thu Jul 18 14:26:05 UTC 2013
Move implementation specific parts of semaphore.h and semaphore.inl into
new header file semaphoreimpl.h. The semaphore.h contains now only the
application visible API.
cpukit/libcsupport/src/resource_snapshot.c | 2 +-
cpukit/posix/Makefile.am | 2 +-
cpukit/posix/include/rtems/posix/semaphore.h | 134 +-------------
cpukit/posix/include/rtems/posix/semaphoreimpl.h | 207 ++++++++++++++++++++++
cpukit/posix/inline/rtems/posix/semaphore.inl | 87 ---------
cpukit/posix/preinstall.am | 8 +-
cpukit/posix/src/posixtimespecabsolutetimeout.c | 2 +-
cpukit/posix/src/semaphore.c | 2 +-
cpukit/posix/src/semaphorecreatesupp.c | 2 +-
cpukit/posix/src/semaphoredeletesupp.c | 2 +-
cpukit/posix/src/semaphoretranslatereturncode.c | 2 +-
cpukit/posix/src/semaphorewaitsupp.c | 2 +-
cpukit/posix/src/semclose.c | 2 +-
cpukit/posix/src/semdestroy.c | 2 +-
cpukit/posix/src/semgetvalue.c | 2 +-
cpukit/posix/src/seminit.c | 2 +-
cpukit/posix/src/semopen.c | 2 +-
cpukit/posix/src/sempost.c | 2 +-
cpukit/posix/src/semtimedwait.c | 2 +-
cpukit/posix/src/semtrywait.c | 2 +-
cpukit/posix/src/semunlink.c | 2 +-
cpukit/posix/src/semwait.c | 2 +-
cpukit/sapi/src/posixapi.c | 2 +-
23 files changed, 239 insertions(+), 235 deletions(-)
create mode 100644 cpukit/posix/include/rtems/posix/semaphoreimpl.h
delete mode 100644 cpukit/posix/inline/rtems/posix/semaphore.inl
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 079b549..fba8a2e 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -36,7 +36,7 @@
#include <rtems/posix/psignal.h>
#include <rtems/posix/pthread.h>
#include <rtems/posix/rwlock.h>
- #include <rtems/posix/semaphore.h>
+ #include <rtems/posix/semaphoreimpl.h>
#include <rtems/posix/spinlock.h>
#include <rtems/posix/timer.h>
#endif
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index f108f00..6900ce0 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -39,6 +39,7 @@ include_rtems_posix_HEADERS += include/rtems/posix/psignalimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/pthread.h
include_rtems_posix_HEADERS += include/rtems/posix/ptimer.h
include_rtems_posix_HEADERS += include/rtems/posix/semaphore.h
+include_rtems_posix_HEADERS += include/rtems/posix/semaphoreimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/threadsup.h
include_rtems_posix_HEADERS += include/rtems/posix/time.h
include_rtems_posix_HEADERS += include/rtems/posix/timer.h
@@ -51,7 +52,6 @@ include_rtems_posix_HEADERS += inline/rtems/posix/key.inl
include_rtems_posix_HEADERS += inline/rtems/posix/mqueue.inl
include_rtems_posix_HEADERS += inline/rtems/posix/pthread.inl
include_rtems_posix_HEADERS += inline/rtems/posix/priority.inl
-include_rtems_posix_HEADERS += inline/rtems/posix/semaphore.inl
include_rtems_posix_HEADERS += inline/rtems/posix/timer.inl
include_rtems_posix_HEADERS += inline/rtems/posix/barrier.inl
include_rtems_posix_HEADERS += inline/rtems/posix/rwlock.inl
diff --git a/cpukit/posix/include/rtems/posix/semaphore.h b/cpukit/posix/include/rtems/posix/semaphore.h
index 92be580..81fee49 100644
--- a/cpukit/posix/include/rtems/posix/semaphore.h
+++ b/cpukit/posix/include/rtems/posix/semaphore.h
@@ -19,6 +19,14 @@
#ifndef _RTEMS_POSIX_SEMAPHORE_H
#define _RTEMS_POSIX_SEMAPHORE_H
+#include <semaphore.h>
+#include <rtems/score/object.h>
+#include <rtems/score/coresem.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
* @defgroup POSIXSemaphorePrivate POSIX Semaphore Private Support
@@ -28,14 +36,6 @@
-#ifdef __cplusplus
-extern "C" {
-#endif
-#include <semaphore.h>
-#include <rtems/score/coresem.h>
-#include <rtems/posix/posixapi.h>
* Data Structure used to manage a POSIX semaphore
@@ -57,127 +57,11 @@ typedef struct {
#endif
} POSIX_Semaphore_Control;
- * The following defines the information control block used to manage
- * this class of objects.
-POSIX_EXTERN Objects_Information _POSIX_Semaphore_Information;
- * _POSIX_Semaphore_Manager_initialization
- * DESCRIPTION:
- * This routine performs the initialization necessary for this manager.
-void _POSIX_Semaphore_Manager_initialization(void);
- * _POSIX_Semaphore_Allocate
- * DESCRIPTION:
- * This function allocates a semaphore control block from
- * the inactive chain of free semaphore control blocks.
-RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Allocate( void );
- * _POSIX_Semaphore_Free
- * DESCRIPTION:
- * This routine frees a semaphore control block to the
- * inactive chain of free semaphore control blocks.
-RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free (
- POSIX_Semaphore_Control *the_semaphore
- * _POSIX_Semaphore_Get
- * DESCRIPTION:
- * This function maps semaphore IDs to semaphore control blocks.
- * If ID corresponds to a local semaphore, then it returns
- * the_semaphore control pointer which maps to ID and location
- * is set to OBJECTS_LOCAL. if the semaphore ID is global and
- * resides on a remote node, then location is set to OBJECTS_REMOTE,
- * and the_semaphore is undefined. Otherwise, location is set
- * to OBJECTS_ERROR and the_semaphore is undefined.
-RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get (
- sem_t *id,
- Objects_Locations *location
- * _POSIX_Semaphore_Create_support
- * DESCRIPTION:
- * This routine supports the sem_init and sem_open routines.
-int _POSIX_Semaphore_Create_support(
- const char *name,
- size_t name_len,
- int pshared,
- unsigned int value,
- POSIX_Semaphore_Control **the_sem
- * @brief POSIX delete a semaphore.
- * DESCRIPTION:
- * This routine supports the sem_close and sem_unlink routines.
-void _POSIX_Semaphore_Delete(
- * @brief POSIX semaphore wait support.
- * DESCRIPTION:
- * This routine supports the sem_wait, sem_trywait, and sem_timedwait
- * services.
-int _POSIX_Semaphore_Wait_support(
- sem_t *sem,
- bool blocking,
- Watchdog_Interval timeout
- * _POSIX_Semaphore_Translate_core_semaphore_return_code
- * DESCRIPTION:
- * A support routine which converts core semaphore status codes into the
- * appropriate POSIX status values.
-int _POSIX_Semaphore_Translate_core_semaphore_return_code(
- CORE_semaphore_Status the_semaphore_status
-#include <rtems/posix/semaphore.inl>
#ifdef __cplusplus
#endif
#endif
/* end of include file */
diff --git a/cpukit/posix/include/rtems/posix/semaphoreimpl.h b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
new file mode 100644
index 0000000..6d1939f
--- /dev/null
+++ b/cpukit/posix/include/rtems/posix/semaphoreimpl.h
@@ -0,0 +1,207 @@
+ * @file
+ * @brief Private Inlined Routines for POSIX Semaphores
+ * This include file contains the static inline implementation of the private
+ * inlined routines for POSIX Semaphores.
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_POSIX_SEMAPHOREIMPL_H
+#define _RTEMS_POSIX_SEMAPHOREIMPL_H
+#include <rtems/posix/semaphore.h>
+#include <rtems/posix/posixapi.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * The following defines the information control block used to manage
+ * this class of objects.
+POSIX_EXTERN Objects_Information _POSIX_Semaphore_Information;
+ * _POSIX_Semaphore_Manager_initialization
+ * DESCRIPTION:
+ * This routine performs the initialization necessary for this manager.
+void _POSIX_Semaphore_Manager_initialization(void);
+ * _POSIX_Semaphore_Allocate
+ * DESCRIPTION:
+ * This function allocates a semaphore control block from
+ * the inactive chain of free semaphore control blocks.
+RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Allocate( void );
+ * _POSIX_Semaphore_Free
+ * DESCRIPTION:
+ * This routine frees a semaphore control block to the
+ * inactive chain of free semaphore control blocks.
+RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Free (
+ POSIX_Semaphore_Control *the_semaphore
+ * _POSIX_Semaphore_Get
+ * DESCRIPTION:
+ * This function maps semaphore IDs to semaphore control blocks.
+ * If ID corresponds to a local semaphore, then it returns
+ * the_semaphore control pointer which maps to ID and location
+ * is set to OBJECTS_LOCAL. if the semaphore ID is global and
+ * resides on a remote node, then location is set to OBJECTS_REMOTE,
+ * and the_semaphore is undefined. Otherwise, location is set
+ * to OBJECTS_ERROR and the_semaphore is undefined.
+RTEMS_INLINE_ROUTINE POSIX_Semaphore_Control *_POSIX_Semaphore_Get (
+ sem_t *id,
+ Objects_Locations *location
+ * _POSIX_Semaphore_Create_support
+ * DESCRIPTION:
+ * This routine supports the sem_init and sem_open routines.
+int _POSIX_Semaphore_Create_support(
+ const char *name,
+ size_t name_len,
+ int pshared,
+ unsigned int value,
+ POSIX_Semaphore_Control **the_sem
+ * @brief POSIX delete a semaphore.
+ * DESCRIPTION:
+ * This routine supports the sem_close and sem_unlink routines.
+void _POSIX_Semaphore_Delete(
+ * @brief POSIX semaphore wait support.
+ * DESCRIPTION:
+ * This routine supports the sem_wait, sem_trywait, and sem_timedwait
+ * services.
+int _POSIX_Semaphore_Wait_support(
+ sem_t *sem,
+ bool blocking,
+ Watchdog_Interval timeout
+ * _POSIX_Semaphore_Translate_core_semaphore_return_code
+ * DESCRIPTION:
+ * A support routine which converts core semaphore status codes into the
+ * appropriate POSIX status values.
+int _POSIX_Semaphore_Translate_core_semaphore_return_code(
+ CORE_semaphore_Status the_semaphore_status
+ return (POSIX_Semaphore_Control *)
+ _Objects_Allocate( &_POSIX_Semaphore_Information );
+ _Objects_Free( &_POSIX_Semaphore_Information, &the_semaphore->Object );
+ * _POSIX_Semaphore_Namespace_remove
+RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Namespace_remove (
+ _Objects_Namespace_remove(
+ &_POSIX_Semaphore_Information, &the_semaphore->Object );
+ sem_t *id,
+ _Objects_Get( &_POSIX_Semaphore_Information, (Objects_Id)*id, location );
+ * @see _POSIX_Name_to_id().
+RTEMS_INLINE_ROUTINE int _POSIX_Semaphore_Name_to_id(
+ const char *name,
+ Objects_Id *id,
+ size_t *len
+ return _POSIX_Name_to_id( &_POSIX_Semaphore_Information, name, id, len );
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/posix/inline/rtems/posix/semaphore.inl b/cpukit/posix/inline/rtems/posix/semaphore.inl
deleted file mode 100644
index 49c5e1b..0000000
--- a/cpukit/posix/inline/rtems/posix/semaphore.inl
+++ /dev/null
@@ -1,87 +0,0 @@
- * @file
- * @brief Private Inlined Routines for POSIX Semaphores
- * This include file contains the static inline implementation of the private
- * inlined routines for POSIX Semaphores.
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#ifndef _RTEMS_POSIX_SEMAPHORE_H
-# error "Never use <rtems/posix/semaphore.inl> directly; include <rtems/posix/semaphore.h> instead."
-#endif
-#ifndef _RTEMS_POSIX_SEMAPHORE_INL
-#define _RTEMS_POSIX_SEMAPHORE_INL
- return (POSIX_Semaphore_Control *)
- _Objects_Allocate( &_POSIX_Semaphore_Information );
- _Objects_Free( &_POSIX_Semaphore_Information, &the_semaphore->Object );
- * _POSIX_Semaphore_Namespace_remove
-RTEMS_INLINE_ROUTINE void _POSIX_Semaphore_Namespace_remove (
- _Objects_Namespace_remove(
- &_POSIX_Semaphore_Information, &the_semaphore->Object );
- sem_t *id,
- _Objects_Get( &_POSIX_Semaphore_Information, (Objects_Id)*id, location );
- * @see _POSIX_Name_to_id().
-RTEMS_INLINE_ROUTINE int _POSIX_Semaphore_Name_to_id(
- const char *name,
- Objects_Id *id,
- size_t *len
- return _POSIX_Name_to_id( &_POSIX_Semaphore_Information, name, id, len );
-#endif
-/* end of include file */
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 74ceb42..0fda0df 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -100,6 +100,10 @@ $(PROJECT_INCLUDE)/rtems/posix/semaphore.h: include/rtems/posix/semaphore.h $(PR
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/semaphore.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/semaphore.h
+$(PROJECT_INCLUDE)/rtems/posix/semaphoreimpl.h: include/rtems/posix/semaphoreimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/semaphoreimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/semaphoreimpl.h
$(PROJECT_INCLUDE)/rtems/posix/threadsup.h: include/rtems/posix/threadsup.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/threadsup.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/threadsup.h
@@ -144,10 +148,6 @@ $(PROJECT_INCLUDE)/rtems/posix/priority.inl: inline/rtems/posix/priority.inl $(P
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/priority.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/priority.inl
-$(PROJECT_INCLUDE)/rtems/posix/semaphore.inl: inline/rtems/posix/semaphore.inl $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/semaphore.inl
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/semaphore.inl
$(PROJECT_INCLUDE)/rtems/posix/timer.inl: inline/rtems/posix/timer.inl $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/timer.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/timer.inl
diff --git a/cpukit/posix/src/posixtimespecabsolutetimeout.c b/cpukit/posix/src/posixtimespecabsolutetimeout.c
index e94805e..913de6c 100644
--- a/cpukit/posix/src/posixtimespecabsolutetimeout.c
+++ b/cpukit/posix/src/posixtimespecabsolutetimeout.c
@@ -28,7 +28,7 @@
-#include <rtems/posix/semaphore.h>
+#include <rtems/posix/semaphoreimpl.h>
#include <rtems/posix/time.h>
#include <rtems/seterr.h>
diff --git a/cpukit/posix/src/semaphore.c b/cpukit/posix/src/semaphore.c
index 58da098..21d67c5 100644
--- a/cpukit/posix/src/semaphore.c
+++ b/cpukit/posix/src/semaphore.c
@@ -29,7 +29,7 @@
#include <rtems/config.h>
diff --git a/cpukit/posix/src/semaphorecreatesupp.c b/cpukit/posix/src/semaphorecreatesupp.c
index 026e7fa..fecbdb5 100644
--- a/cpukit/posix/src/semaphorecreatesupp.c
+++ b/cpukit/posix/src/semaphorecreatesupp.c
@@ -30,7 +30,7 @@
diff --git a/cpukit/posix/src/semaphoredeletesupp.c b/cpukit/posix/src/semaphoredeletesupp.c
index a24adef..6e46f53 100644
--- a/cpukit/posix/src/semaphoredeletesupp.c
+++ b/cpukit/posix/src/semaphoredeletesupp.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semaphoretranslatereturncode.c b/cpukit/posix/src/semaphoretranslatereturncode.c
index 44885d6..c4e6558 100644
--- a/cpukit/posix/src/semaphoretranslatereturncode.c
+++ b/cpukit/posix/src/semaphoretranslatereturncode.c
@@ -25,7 +25,7 @@
diff --git a/cpukit/posix/src/semaphorewaitsupp.c b/cpukit/posix/src/semaphorewaitsupp.c
index f3ce600..67ecb43 100644
--- a/cpukit/posix/src/semaphorewaitsupp.c
+++ b/cpukit/posix/src/semaphorewaitsupp.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semclose.c b/cpukit/posix/src/semclose.c
index 07f7536..81cb316 100644
--- a/cpukit/posix/src/semclose.c
+++ b/cpukit/posix/src/semclose.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semdestroy.c b/cpukit/posix/src/semdestroy.c
index cef3406..0e547df 100644
--- a/cpukit/posix/src/semdestroy.c
+++ b/cpukit/posix/src/semdestroy.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semgetvalue.c b/cpukit/posix/src/semgetvalue.c
index 24527d1..3e584e2 100644
--- a/cpukit/posix/src/semgetvalue.c
+++ b/cpukit/posix/src/semgetvalue.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/seminit.c b/cpukit/posix/src/seminit.c
index f0dcb71..39a75b5 100644
--- a/cpukit/posix/src/seminit.c
+++ b/cpukit/posix/src/seminit.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semopen.c b/cpukit/posix/src/semopen.c
index 113c622..c74925b 100644
--- a/cpukit/posix/src/semopen.c
+++ b/cpukit/posix/src/semopen.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/sempost.c b/cpukit/posix/src/sempost.c
index 79e5ec8..6b9f876 100644
--- a/cpukit/posix/src/sempost.c
+++ b/cpukit/posix/src/sempost.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semtimedwait.c b/cpukit/posix/src/semtimedwait.c
index 9f54ad3..6d41579 100644
--- a/cpukit/posix/src/semtimedwait.c
+++ b/cpukit/posix/src/semtimedwait.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semtrywait.c b/cpukit/posix/src/semtrywait.c
index b80e515..2aa6d28 100644
--- a/cpukit/posix/src/semtrywait.c
+++ b/cpukit/posix/src/semtrywait.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semunlink.c b/cpukit/posix/src/semunlink.c
index c34add8..cee2a64 100644
--- a/cpukit/posix/src/semunlink.c
+++ b/cpukit/posix/src/semunlink.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/posix/src/semwait.c b/cpukit/posix/src/semwait.c
index 16fc907..fbc59e4 100644
--- a/cpukit/posix/src/semwait.c
+++ b/cpukit/posix/src/semwait.c
@@ -28,7 +28,7 @@
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index 1581809..bda9a28 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -40,7 +40,7 @@
1.7.7
