[PATCH 23/25] posix: Create message queue implementation header
Sebastian Huber
Thu Jul 18 14:26:11 UTC 2013
Move implementation specific parts of mqueue.h and mqueue.inl into new
header file mqueueimpl.h. The mqueue.h contains now only the
application visible API.
cpukit/libcsupport/src/resource_snapshot.c | 2 +-
cpukit/posix/Makefile.am | 2 +-
cpukit/posix/include/rtems/posix/mqueue.h | 210 +--------------
cpukit/posix/include/rtems/posix/mqueueimpl.h | 368 +++++++++++++++++++++++++
cpukit/posix/inline/rtems/posix/mqueue.inl | 162 -----------
cpukit/posix/preinstall.am | 8 +-
cpukit/posix/src/mqueue.c | 2 +-
cpukit/posix/src/mqueueclose.c | 2 +-
cpukit/posix/src/mqueuecreatesupp.c | 2 +-
cpukit/posix/src/mqueuedeletesupp.c | 2 +-
cpukit/posix/src/mqueuegetattr.c | 2 +-
cpukit/posix/src/mqueuenotify.c | 2 +-
cpukit/posix/src/mqueueopen.c | 2 +-
cpukit/posix/src/mqueuereceive.c | 2 +-
cpukit/posix/src/mqueuerecvsupp.c | 2 +-
cpukit/posix/src/mqueuesend.c | 2 +-
cpukit/posix/src/mqueuesendsupp.c | 2 +-
cpukit/posix/src/mqueuesetattr.c | 2 +-
cpukit/posix/src/mqueuetimedreceive.c | 2 +-
cpukit/posix/src/mqueuetimedsend.c | 2 +-
cpukit/posix/src/mqueuetranslatereturncode.c | 2 +-
cpukit/posix/src/mqueueunlink.c | 2 +-
cpukit/sapi/src/posixapi.c | 2 +-
23 files changed, 395 insertions(+), 391 deletions(-)
create mode 100644 cpukit/posix/include/rtems/posix/mqueueimpl.h
delete mode 100644 cpukit/posix/inline/rtems/posix/mqueue.inl
diff --git a/cpukit/libcsupport/src/resource_snapshot.c b/cpukit/libcsupport/src/resource_snapshot.c
index 1bb57d2..4fc3f15 100644
--- a/cpukit/libcsupport/src/resource_snapshot.c
+++ b/cpukit/libcsupport/src/resource_snapshot.c
@@ -31,7 +31,7 @@
#ifdef RTEMS_POSIX_API
#include <rtems/posix/barrier.h>
#include <rtems/posix/cond.h>
- #include <rtems/posix/mqueue.h>
+ #include <rtems/posix/mqueueimpl.h>
#include <rtems/posix/key.h>
#include <rtems/posix/psignal.h>
diff --git a/cpukit/posix/Makefile.am b/cpukit/posix/Makefile.am
index 6900ce0..0accfd4 100644
--- a/cpukit/posix/Makefile.am
+++ b/cpukit/posix/Makefile.am
@@ -30,6 +30,7 @@ include_rtems_posix_HEADERS += include/rtems/posix/cond.h
include_rtems_posix_HEADERS += include/rtems/posix/config.h
include_rtems_posix_HEADERS += include/rtems/posix/key.h
include_rtems_posix_HEADERS += include/rtems/posix/mqueue.h
+include_rtems_posix_HEADERS += include/rtems/posix/mqueueimpl.h
include_rtems_posix_HEADERS += include/rtems/posix/mutex.h
include_rtems_posix_HEADERS += include/rtems/posix/muteximpl.h
include_rtems_posix_HEADERS += include/rtems/posix/posixapi.h
@@ -49,7 +50,6 @@ include_rtems_posix_HEADERS += include/rtems/posix/spinlock.h
include_rtems_posix_HEADERS += inline/rtems/posix/cond.inl
include_rtems_posix_HEADERS += inline/rtems/posix/key.inl
-include_rtems_posix_HEADERS += inline/rtems/posix/mqueue.inl
include_rtems_posix_HEADERS += inline/rtems/posix/pthread.inl
include_rtems_posix_HEADERS += inline/rtems/posix/priority.inl
include_rtems_posix_HEADERS += inline/rtems/posix/timer.inl
diff --git a/cpukit/posix/include/rtems/posix/mqueue.h b/cpukit/posix/include/rtems/posix/mqueue.h
index d6f370c..1db54b1 100644
--- a/cpukit/posix/include/rtems/posix/mqueue.h
+++ b/cpukit/posix/include/rtems/posix/mqueue.h
@@ -35,7 +35,10 @@
#include <mqueue.h> /* struct mq_attr */
#include <rtems/score/coremsg.h>
-#include <rtems/posix/posixapi.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
* @defgroup POSIX_MQUEUE_P Message Queues Private Support
@@ -44,9 +47,6 @@
-#ifdef __cplusplus
-extern "C" {
-#endif
* Data Structure used to manage a POSIX message queue
@@ -68,208 +68,6 @@ typedef struct {
int oflag;
} POSIX_Message_queue_Control_fd;
- * The following defines the information control block used to manage
- * this class of objects. The second item is used to manage the set
- * of "file descriptors" associated with the message queues.
-POSIX_EXTERN Objects_Information _POSIX_Message_queue_Information;
-POSIX_EXTERN Objects_Information _POSIX_Message_queue_Information_fds;
- * @brief Initialize message_queue manager related data structures.
- * DESCRIPTION:
- * This routine performs the initialization necessary for this manager.
- * NOTE: The structure of the routines is identical to that of POSIX
- * Message_queues to leave the option of having unnamed message
- * queues at a future date. They are currently not part of the
- * POSIX standard but unnamed message_queues are. This is also
- * the reason for the apparently unnecessary tracking of
- * the process_shared attribute. [In addition to the fact that
- * it would be trivial to add pshared to the mq_attr structure
- * and have process private message queues.]
- * This code ignores the O_RDONLY/O_WRONLY/O_RDWR flag at open
- * time.
-void _POSIX_Message_queue_Manager_initialization(void);
- * _POSIX_Message_queue_Create_support
- * DESCRIPTION:
- * This routine performs the creation of a message queue utilizing the
- * core message queue.
-int _POSIX_Message_queue_Create_support(
- const char *name,
- size_t name_len,
- int pshared,
- struct mq_attr *attr,
- POSIX_Message_queue_Control **message_queue
- * @brief Delete a POSIX message queue.
- * DESCRIPTION:
- * This routine supports the mq_unlink and mq_close routines by
- * doing most of the work involved with removing a message queue.
-void _POSIX_Message_queue_Delete(
- POSIX_Message_queue_Control *the_mq
- * @brief POSIX Message Queue Receive Support
- * DESCRIPTION:
- * This routine supports the various flavors of receiving a message.
- * time.
-ssize_t _POSIX_Message_queue_Receive_support(
- mqd_t mqdes,
- char *msg_ptr,
- size_t msg_len,
- unsigned int *msg_prio,
- bool wait,
- Watchdog_Interval timeout
- * _POSIX_Message_queue_Send_support
- * DESCRIPTION:
- * This routine posts a message to a specified message queue.
-int _POSIX_Message_queue_Send_support(
- mqd_t mqdes,
- const char *msg_ptr,
- size_t msg_len,
- unsigned int msg_prio,
- bool wait,
- * _POSIX_Message_queue_Allocate
- * DESCRIPTION:
- * This function allocates a message queue control block from
- * the inactive chain of free message queue control blocks.
-RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Allocate( void );
- * _POSIX_Message_queue_Free
- * DESCRIPTION:
- * This routine frees a message queue control block to the
- * inactive chain of free message queue control blocks.
-RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free (
- * _POSIX_Message_queue_Get
- * DESCRIPTION:
- * This function maps message queue IDs to message queue control blocks.
- * If ID corresponds to a local message queue, then it returns
- * the_mq control pointer which maps to ID and location
- * is set to OBJECTS_LOCAL. if the message queue ID is global and
- * resides on a remote node, then location is set to OBJECTS_REMOTE,
- * and the_message queue is undefined. Otherwise, location is set
- * to OBJECTS_ERROR and the_mq is undefined.
-RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Get (
- Objects_Id id,
- Objects_Locations *location
- * _POSIX_Message_queue_Is_null
- * DESCRIPTION:
- * This function returns TRUE if the_message_queue is NULL and FALSE otherwise.
-RTEMS_INLINE_ROUTINE bool _POSIX_Message_queue_Is_null (
- * _POSIX_Message_queue_Priority_to_core
- * DESCRIPTION:
- * XXX
-RTEMS_INLINE_ROUTINE CORE_message_queue_Submit_types _POSIX_Message_queue_Priority_to_core(
- unsigned int priority
- * _POSIX_Message_queue_Priority_from_core
- * DESCRIPTION:
- * XXX
-RTEMS_INLINE_ROUTINE unsigned int _POSIX_Message_queue_Priority_from_core(
- CORE_message_queue_Submit_types priority
- * _POSIX_Message_queue_Translate_core_message_queue_return_code
- * DESCRIPTION:
- * XXX
-int _POSIX_Message_queue_Translate_core_message_queue_return_code(
- uint32_t the_message_queue_status
-#include <rtems/posix/mqueue.inl>
#ifdef __cplusplus
diff --git a/cpukit/posix/include/rtems/posix/mqueueimpl.h b/cpukit/posix/include/rtems/posix/mqueueimpl.h
new file mode 100644
index 0000000..0f86e7f
--- /dev/null
+++ b/cpukit/posix/include/rtems/posix/mqueueimpl.h
@@ -0,0 +1,368 @@
+ * @file
+ * @brief Private Inlined Routines for POSIX Message Queue
+ * This include file contains the static inline implementation of the private
+ * inlined routines for POSIX Message Queue.
+ * COPYRIGHT (c) 1989-2011.
+ * On-Line Applications Research Corporation (OAR).
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_POSIX_MQUEUE_INL
+#define _RTEMS_POSIX_MQUEUE_INL
+#include <rtems/posix/mqueue.h>
+#include <rtems/posix/posixapi.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * The following defines the information control block used to manage
+ * this class of objects. The second item is used to manage the set
+ * of "file descriptors" associated with the message queues.
+POSIX_EXTERN Objects_Information _POSIX_Message_queue_Information;
+POSIX_EXTERN Objects_Information _POSIX_Message_queue_Information_fds;
+ * @brief Initialize message_queue manager related data structures.
+ * DESCRIPTION:
+ * This routine performs the initialization necessary for this manager.
+ * NOTE: The structure of the routines is identical to that of POSIX
+ * Message_queues to leave the option of having unnamed message
+ * queues at a future date. They are currently not part of the
+ * POSIX standard but unnamed message_queues are. This is also
+ * the reason for the apparently unnecessary tracking of
+ * the process_shared attribute. [In addition to the fact that
+ * it would be trivial to add pshared to the mq_attr structure
+ * and have process private message queues.]
+ * This code ignores the O_RDONLY/O_WRONLY/O_RDWR flag at open
+ * time.
+void _POSIX_Message_queue_Manager_initialization(void);
+ * _POSIX_Message_queue_Create_support
+ * DESCRIPTION:
+ * This routine performs the creation of a message queue utilizing the
+ * core message queue.
+int _POSIX_Message_queue_Create_support(
+ const char *name,
+ size_t name_len,
+ int pshared,
+ struct mq_attr *attr,
+ POSIX_Message_queue_Control **message_queue
+ * @brief Delete a POSIX message queue.
+ * DESCRIPTION:
+ * This routine supports the mq_unlink and mq_close routines by
+ * doing most of the work involved with removing a message queue.
+void _POSIX_Message_queue_Delete(
+ POSIX_Message_queue_Control *the_mq
+ * @brief POSIX Message Queue Receive Support
+ * DESCRIPTION:
+ * This routine supports the various flavors of receiving a message.
+ * time.
+ssize_t _POSIX_Message_queue_Receive_support(
+ mqd_t mqdes,
+ char *msg_ptr,
+ size_t msg_len,
+ unsigned int *msg_prio,
+ bool wait,
+ Watchdog_Interval timeout
+ * _POSIX_Message_queue_Send_support
+ * DESCRIPTION:
+ * This routine posts a message to a specified message queue.
+int _POSIX_Message_queue_Send_support(
+ mqd_t mqdes,
+ const char *msg_ptr,
+ size_t msg_len,
+ unsigned int msg_prio,
+ bool wait,
+ * _POSIX_Message_queue_Allocate
+ * DESCRIPTION:
+ * This function allocates a message queue control block from
+ * the inactive chain of free message queue control blocks.
+RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Allocate( void );
+ * _POSIX_Message_queue_Free
+ * DESCRIPTION:
+ * This routine frees a message queue control block to the
+ * inactive chain of free message queue control blocks.
+RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free (
+ * _POSIX_Message_queue_Get
+ * DESCRIPTION:
+ * This function maps message queue IDs to message queue control blocks.
+ * If ID corresponds to a local message queue, then it returns
+ * the_mq control pointer which maps to ID and location
+ * is set to OBJECTS_LOCAL. if the message queue ID is global and
+ * resides on a remote node, then location is set to OBJECTS_REMOTE,
+ * and the_message queue is undefined. Otherwise, location is set
+ * to OBJECTS_ERROR and the_mq is undefined.
+RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control *_POSIX_Message_queue_Get (
+ Objects_Id id,
+ Objects_Locations *location
+ * _POSIX_Message_queue_Is_null
+ * DESCRIPTION:
+ * This function returns TRUE if the_message_queue is NULL and FALSE otherwise.
+RTEMS_INLINE_ROUTINE bool _POSIX_Message_queue_Is_null (
+ * _POSIX_Message_queue_Priority_to_core
+ * DESCRIPTION:
+ * XXX
+RTEMS_INLINE_ROUTINE CORE_message_queue_Submit_types _POSIX_Message_queue_Priority_to_core(
+ unsigned int priority
+ * _POSIX_Message_queue_Priority_from_core
+ * DESCRIPTION:
+ * XXX
+RTEMS_INLINE_ROUTINE unsigned int _POSIX_Message_queue_Priority_from_core(
+ CORE_message_queue_Submit_types priority
+ * _POSIX_Message_queue_Translate_core_message_queue_return_code
+ * DESCRIPTION:
+ * XXX
+int _POSIX_Message_queue_Translate_core_message_queue_return_code(
+ uint32_t the_message_queue_status
+ POSIX_Message_queue_Control *_POSIX_Message_queue_Allocate( void )
+ return (POSIX_Message_queue_Control *)
+ _Objects_Allocate( &_POSIX_Message_queue_Information );
+ * _POSIX_Message_queue_Allocate_fd
+RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control_fd *
+ _POSIX_Message_queue_Allocate_fd( void )
+ return (POSIX_Message_queue_Control_fd *)
+ _Objects_Allocate( &_POSIX_Message_queue_Information_fds );
+ _Objects_Free( &_POSIX_Message_queue_Information, &the_mq->Object );
+ * _POSIX_Message_queue_Free_fd
+RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free_fd (
+ POSIX_Message_queue_Control_fd *the_mq_fd
+ _Objects_Free( &_POSIX_Message_queue_Information_fds, &the_mq_fd->Object );
+ * _POSIX_Message_queue_Namespace_remove
+RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Namespace_remove (
+ _Objects_Namespace_remove(
+ &_POSIX_Message_queue_Information, &the_mq->Object );
+ Objects_Id id,
+ _Objects_Get( &_POSIX_Message_queue_Information, id, location );
+ * _POSIX_Message_queue_Get_fd
+RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control_fd *_POSIX_Message_queue_Get_fd (
+ mqd_t id,
+ return (POSIX_Message_queue_Control_fd *) _Objects_Get(
+ &_POSIX_Message_queue_Information_fds,
+ (Objects_Id)id,
+ location
+ return !the_mq;
+ return (CORE_message_queue_Submit_types) priority * -1;
+ * DESCRIPTION:
+ * XXX
+ /* absolute value without a library dependency */
+ return (unsigned int) ((priority >= 0) ? priority : -priority);
+ * @see _POSIX_Name_to_id().
+RTEMS_INLINE_ROUTINE int _POSIX_Message_queue_Name_to_id(
+ const char *name,
+ Objects_Id *id,
+ size_t *len
+ return _POSIX_Name_to_id( &_POSIX_Message_queue_Information, name, id, len );
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/posix/inline/rtems/posix/mqueue.inl b/cpukit/posix/inline/rtems/posix/mqueue.inl
deleted file mode 100644
index e27efca..0000000
--- a/cpukit/posix/inline/rtems/posix/mqueue.inl
+++ /dev/null
@@ -1,162 +0,0 @@
- * @file
- * @brief Private Inlined Routines for POSIX Message Queue
- * This include file contains the static inline implementation of the private
- * inlined routines for POSIX Message Queue.
- * COPYRIGHT (c) 1989-2011.
- * On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#ifndef _RTEMS_POSIX_MQUEUE_H
-# error "Never use <rtems/posix/mqueue.inl> directly; include <rtems/posix/mqueue.h> instead."
-#endif
-#ifndef _RTEMS_POSIX_MQUEUE_INL
-#define _RTEMS_POSIX_MQUEUE_INL
- POSIX_Message_queue_Control *_POSIX_Message_queue_Allocate( void )
- return (POSIX_Message_queue_Control *)
- _Objects_Allocate( &_POSIX_Message_queue_Information );
- * _POSIX_Message_queue_Allocate_fd
-RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control_fd *
- _POSIX_Message_queue_Allocate_fd( void )
- return (POSIX_Message_queue_Control_fd *)
- _Objects_Allocate( &_POSIX_Message_queue_Information_fds );
- _Objects_Free( &_POSIX_Message_queue_Information, &the_mq->Object );
- * _POSIX_Message_queue_Free_fd
-RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Free_fd (
- POSIX_Message_queue_Control_fd *the_mq_fd
- _Objects_Free( &_POSIX_Message_queue_Information_fds, &the_mq_fd->Object );
- * _POSIX_Message_queue_Namespace_remove
-RTEMS_INLINE_ROUTINE void _POSIX_Message_queue_Namespace_remove (
- _Objects_Namespace_remove(
- &_POSIX_Message_queue_Information, &the_mq->Object );
- Objects_Id id,
- _Objects_Get( &_POSIX_Message_queue_Information, id, location );
- * _POSIX_Message_queue_Get_fd
-RTEMS_INLINE_ROUTINE POSIX_Message_queue_Control_fd *_POSIX_Message_queue_Get_fd (
- mqd_t id,
- return (POSIX_Message_queue_Control_fd *) _Objects_Get(
- &_POSIX_Message_queue_Information_fds,
- (Objects_Id)id,
- location
- return !the_mq;
- return (CORE_message_queue_Submit_types) priority * -1;
- * DESCRIPTION:
- * XXX
- /* absolute value without a library dependency */
- return (unsigned int) ((priority >= 0) ? priority : -priority);
- * @see _POSIX_Name_to_id().
-RTEMS_INLINE_ROUTINE int _POSIX_Message_queue_Name_to_id(
- const char *name,
- Objects_Id *id,
- size_t *len
- return _POSIX_Name_to_id( &_POSIX_Message_queue_Information, name, id, len );
-#endif
-/* end of include file */
diff --git a/cpukit/posix/preinstall.am b/cpukit/posix/preinstall.am
index 0fda0df..aee07c0 100644
--- a/cpukit/posix/preinstall.am
+++ b/cpukit/posix/preinstall.am
@@ -64,6 +64,10 @@ $(PROJECT_INCLUDE)/rtems/posix/mqueue.h: include/rtems/posix/mqueue.h $(PROJECT_
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/mqueue.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/mqueue.h
+$(PROJECT_INCLUDE)/rtems/posix/mqueueimpl.h: include/rtems/posix/mqueueimpl.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
+ $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/mqueueimpl.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/mqueueimpl.h
$(PROJECT_INCLUDE)/rtems/posix/mutex.h: include/rtems/posix/mutex.h $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/mutex.h
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/mutex.h
@@ -136,10 +140,6 @@ $(PROJECT_INCLUDE)/rtems/posix/key.inl: inline/rtems/posix/key.inl $(PROJECT_INC
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/key.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/key.inl
-$(PROJECT_INCLUDE)/rtems/posix/mqueue.inl: inline/rtems/posix/mqueue.inl $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
- $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/mqueue.inl
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/mqueue.inl
$(PROJECT_INCLUDE)/rtems/posix/pthread.inl: inline/rtems/posix/pthread.inl $(PROJECT_INCLUDE)/rtems/posix/$(dirstamp)
$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/posix/pthread.inl
PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/posix/pthread.inl
diff --git a/cpukit/posix/src/mqueue.c b/cpukit/posix/src/mqueue.c
index 93d6f1b..5d2dec7 100644
--- a/cpukit/posix/src/mqueue.c
+++ b/cpukit/posix/src/mqueue.c
@@ -30,7 +30,7 @@
#include <rtems/config.h>
#include <rtems/seterr.h>
-#include <rtems/posix/mqueue.h>
+#include <rtems/posix/mqueueimpl.h>
#include <rtems/posix/time.h>
diff --git a/cpukit/posix/src/mqueueclose.c b/cpukit/posix/src/mqueueclose.c
index f4d8661..4d082d7 100644
--- a/cpukit/posix/src/mqueueclose.c
+++ b/cpukit/posix/src/mqueueclose.c
@@ -41,7 +41,7 @@
diff --git a/cpukit/posix/src/mqueuecreatesupp.c b/cpukit/posix/src/mqueuecreatesupp.c
index 94b91d0..7628940 100644
--- a/cpukit/posix/src/mqueuecreatesupp.c
+++ b/cpukit/posix/src/mqueuecreatesupp.c
@@ -37,7 +37,7 @@
diff --git a/cpukit/posix/src/mqueuedeletesupp.c b/cpukit/posix/src/mqueuedeletesupp.c
index 1a72462..b1fef27 100644
--- a/cpukit/posix/src/mqueuedeletesupp.c
+++ b/cpukit/posix/src/mqueuedeletesupp.c
@@ -30,7 +30,7 @@
#if defined(RTEMS_DEBUG)
#include <rtems/bspIo.h>
diff --git a/cpukit/posix/src/mqueuegetattr.c b/cpukit/posix/src/mqueuegetattr.c
index f4244d0..3bdc386 100644
--- a/cpukit/posix/src/mqueuegetattr.c
+++ b/cpukit/posix/src/mqueuegetattr.c
@@ -41,7 +41,7 @@
diff --git a/cpukit/posix/src/mqueuenotify.c b/cpukit/posix/src/mqueuenotify.c
index e2a53e9..84a7d0d 100644
--- a/cpukit/posix/src/mqueuenotify.c
+++ b/cpukit/posix/src/mqueuenotify.c
@@ -31,7 +31,7 @@
diff --git a/cpukit/posix/src/mqueueopen.c b/cpukit/posix/src/mqueueopen.c
index 01d3d57..e01be7a 100644
--- a/cpukit/posix/src/mqueueopen.c
+++ b/cpukit/posix/src/mqueueopen.c
@@ -41,7 +41,7 @@
diff --git a/cpukit/posix/src/mqueuereceive.c b/cpukit/posix/src/mqueuereceive.c
index c5f9257..b02380e 100644
--- a/cpukit/posix/src/mqueuereceive.c
+++ b/cpukit/posix/src/mqueuereceive.c
@@ -29,7 +29,7 @@
ssize_t mq_receive(
diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
index cf1698f..5eb856a 100644
--- a/cpukit/posix/src/mqueuerecvsupp.c
+++ b/cpukit/posix/src/mqueuerecvsupp.c
@@ -29,7 +29,7 @@
diff --git a/cpukit/posix/src/mqueuesend.c b/cpukit/posix/src/mqueuesend.c
index 11016e4..6e3ed09 100644
--- a/cpukit/posix/src/mqueuesend.c
+++ b/cpukit/posix/src/mqueuesend.c
@@ -41,7 +41,7 @@
diff --git a/cpukit/posix/src/mqueuesendsupp.c b/cpukit/posix/src/mqueuesendsupp.c
index 093c425..2b2acb8 100644
--- a/cpukit/posix/src/mqueuesendsupp.c
+++ b/cpukit/posix/src/mqueuesendsupp.c
@@ -41,7 +41,7 @@
diff --git a/cpukit/posix/src/mqueuesetattr.c b/cpukit/posix/src/mqueuesetattr.c
index 0e16f1f..09a31d6 100644
--- a/cpukit/posix/src/mqueuesetattr.c
+++ b/cpukit/posix/src/mqueuesetattr.c
@@ -29,7 +29,7 @@
int mq_setattr(
diff --git a/cpukit/posix/src/mqueuetimedreceive.c b/cpukit/posix/src/mqueuetimedreceive.c
index 53b3364..c4868d6 100644
--- a/cpukit/posix/src/mqueuetimedreceive.c
+++ b/cpukit/posix/src/mqueuetimedreceive.c
@@ -43,7 +43,7 @@
diff --git a/cpukit/posix/src/mqueuetimedsend.c b/cpukit/posix/src/mqueuetimedsend.c
index da7e0e1..c3df3a9 100644
--- a/cpukit/posix/src/mqueuetimedsend.c
+++ b/cpukit/posix/src/mqueuetimedsend.c
@@ -29,7 +29,7 @@
int mq_timedsend(
diff --git a/cpukit/posix/src/mqueuetranslatereturncode.c b/cpukit/posix/src/mqueuetranslatereturncode.c
index 6142261..ef7072a 100644
--- a/cpukit/posix/src/mqueuetranslatereturncode.c
+++ b/cpukit/posix/src/mqueuetranslatereturncode.c
@@ -25,7 +25,7 @@
diff --git a/cpukit/posix/src/mqueueunlink.c b/cpukit/posix/src/mqueueunlink.c
index 0f68ae7..e2bf2a2 100644
--- a/cpukit/posix/src/mqueueunlink.c
+++ b/cpukit/posix/src/mqueueunlink.c
@@ -30,7 +30,7 @@
diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
index bda9a28..41bce8d 100644
--- a/cpukit/sapi/src/posixapi.c
+++ b/cpukit/sapi/src/posixapi.c
@@ -32,7 +32,7 @@
#include <rtems/posix/config.h>
#include <rtems/posix/priority.h>
1.7.7
