[PATCH] clean up all the spatomic test cases
Rempel, Cynthia
cynt6007 at vandals.uidaho.edu
Thu Jul 18 16:16:50 UTC 2013
Hi Wei Yang,
I noticed some emails in the archive discussing fixes to the tests, such as http://www.rtems.org/pipermail/rtems-devel/2013-July/003562.html ...
Do we really want to delete them, instead of applying the fix?
Thanks,
Cindy
________________________________________
Sent: Thursday, July 18, 2013 8:20 AM
To: Rempel, Cynthia
Cc: rtems-devel at rtems.org
Subject: Re: [PATCH] clean up all the spatomic test cases
Hi Cindy,
Those test cases is based on old atomic implementation, the new atomic implementation based on stdatomic.h has been submitted which does not support UP mode now, and all the test cases will be redesigned. Now it's usage is to test whether compiler works ok. Its test function is somewhat useless.
在 2013-7-18,下午11:06,"Rempel, Cynthia" <cynt6007 at vandals.uidaho.edu> 写道:
> Hi Wei Yang,
> Wow, this looks like a big change... Why are we cleaning up spatomic test cases?
> Why not just build them conditionally?
> Thanks,
> Cindy
> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of WeiY [wei.a.yang at gmail.com]
> Sent: Thursday, July 18, 2013 7:44 AM
> To: rtems-devel at rtems.org
> Subject: [PATCH] clean up all the spatomic test cases
> c/src/lib/libbsp/bfin/acinclude.m4 | 4 +-
> c/src/lib/libbsp/powerpc/acinclude.m4 | 4 +-
> testsuites/sptests/Makefile.am | 4 +-
> testsuites/sptests/configure.ac | 7 --
> testsuites/sptests/spatomic01/Makefile.am | 24 ------
> testsuites/sptests/spatomic01/init.c | 63 --------------
> testsuites/sptests/spatomic01/spatomic01.doc | 23 -----
> testsuites/sptests/spatomic01/spatomic01.scn | 70 ---------------
> testsuites/sptests/spatomic01/system.h | 51 -----------
> testsuites/sptests/spatomic01/tasks.c | 93 --------------------
> testsuites/sptests/spatomic02/Makefile.am | 24 ------
> testsuites/sptests/spatomic02/init.c | 68 ---------------
> testsuites/sptests/spatomic02/spatomic02.doc | 23 -----
> testsuites/sptests/spatomic02/spatomic02.scn | 70 ---------------
> testsuites/sptests/spatomic02/system.h | 51 -----------
> testsuites/sptests/spatomic02/tasks.c | 94 ---------------------
> testsuites/sptests/spatomic03/Makefile.am | 24 ------
> testsuites/sptests/spatomic03/init.c | 68 ---------------
> testsuites/sptests/spatomic03/spatomic03.doc | 23 -----
> testsuites/sptests/spatomic03/spatomic03.scn | 102 ----------------------
> testsuites/sptests/spatomic03/system.h | 51 -----------
> testsuites/sptests/spatomic03/tasks.c | 102 ----------------------
> testsuites/sptests/spatomic04/Makefile.am | 24 ------
> testsuites/sptests/spatomic04/init.c | 68 ---------------
> testsuites/sptests/spatomic04/spatomic04.doc | 23 -----
> testsuites/sptests/spatomic04/spatomic04.scn | 102 ----------------------
> testsuites/sptests/spatomic04/system.h | 51 -----------
> testsuites/sptests/spatomic04/tasks.c | 102 ----------------------
> testsuites/sptests/spatomic05/Makefile.am | 24 ------
> testsuites/sptests/spatomic05/init.c | 68 ---------------
> testsuites/sptests/spatomic05/spatomic05.doc | 23 -----
> testsuites/sptests/spatomic05/spatomic05.scn | 102 ----------------------
> testsuites/sptests/spatomic05/system.h | 51 -----------
> testsuites/sptests/spatomic05/tasks.c | 101 ----------------------
> testsuites/sptests/spatomic06/Makefile.am | 24 ------
> testsuites/sptests/spatomic06/init.c | 68 ---------------
> testsuites/sptests/spatomic06/spatomic06.doc | 23 -----
> testsuites/sptests/spatomic06/spatomic06.scn | 102 ----------------------
> testsuites/sptests/spatomic06/system.h | 51 -----------
> testsuites/sptests/spatomic06/tasks.c | 101 ----------------------
> testsuites/sptests/spatomic07/Makefile.am | 24 ------
> testsuites/sptests/spatomic07/init.c | 68 ---------------
> testsuites/sptests/spatomic07/spatomic07.doc | 24 ------
> testsuites/sptests/spatomic07/spatomic07.scn | 102 ----------------------
> testsuites/sptests/spatomic07/system.h | 51 -----------
> testsuites/sptests/spatomic07/tasks.c | 117 --------------------------
> 46 files changed, 5 insertions(+), 2532 deletions(-)
> delete mode 100644 testsuites/sptests/spatomic01/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic01/init.c
> delete mode 100644 testsuites/sptests/spatomic01/spatomic01.doc
> delete mode 100644 testsuites/sptests/spatomic01/spatomic01.scn
> delete mode 100644 testsuites/sptests/spatomic01/system.h
> delete mode 100644 testsuites/sptests/spatomic01/tasks.c
> delete mode 100644 testsuites/sptests/spatomic02/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic02/init.c
> delete mode 100644 testsuites/sptests/spatomic02/spatomic02.doc
> delete mode 100644 testsuites/sptests/spatomic02/spatomic02.scn
> delete mode 100644 testsuites/sptests/spatomic02/system.h
> delete mode 100644 testsuites/sptests/spatomic02/tasks.c
> delete mode 100644 testsuites/sptests/spatomic03/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic03/init.c
> delete mode 100644 testsuites/sptests/spatomic03/spatomic03.doc
> delete mode 100644 testsuites/sptests/spatomic03/spatomic03.scn
> delete mode 100644 testsuites/sptests/spatomic03/system.h
> delete mode 100644 testsuites/sptests/spatomic03/tasks.c
> delete mode 100644 testsuites/sptests/spatomic04/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic04/init.c
> delete mode 100644 testsuites/sptests/spatomic04/spatomic04.doc
> delete mode 100644 testsuites/sptests/spatomic04/spatomic04.scn
> delete mode 100644 testsuites/sptests/spatomic04/system.h
> delete mode 100644 testsuites/sptests/spatomic04/tasks.c
> delete mode 100644 testsuites/sptests/spatomic05/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic05/init.c
> delete mode 100644 testsuites/sptests/spatomic05/spatomic05.doc
> delete mode 100644 testsuites/sptests/spatomic05/spatomic05.scn
> delete mode 100644 testsuites/sptests/spatomic05/system.h
> delete mode 100644 testsuites/sptests/spatomic05/tasks.c
> delete mode 100644 testsuites/sptests/spatomic06/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic06/init.c
> delete mode 100644 testsuites/sptests/spatomic06/spatomic06.doc
> delete mode 100644 testsuites/sptests/spatomic06/spatomic06.scn
> delete mode 100644 testsuites/sptests/spatomic06/system.h
> delete mode 100644 testsuites/sptests/spatomic06/tasks.c
> delete mode 100644 testsuites/sptests/spatomic07/Makefile.am
> delete mode 100644 testsuites/sptests/spatomic07/init.c
> delete mode 100644 testsuites/sptests/spatomic07/spatomic07.doc
> delete mode 100644 testsuites/sptests/spatomic07/spatomic07.scn
> delete mode 100644 testsuites/sptests/spatomic07/system.h
> delete mode 100644 testsuites/sptests/spatomic07/tasks.c
> diff --git a/c/src/lib/libbsp/bfin/acinclude.m4 b/c/src/lib/libbsp/bfin/acinclude.m4
> index 828fd89..ab6082e 100644
> --- a/c/src/lib/libbsp/bfin/acinclude.m4
> +++ b/c/src/lib/libbsp/bfin/acinclude.m4
> @@ -2,12 +2,12 @@
> AC_DEFUN([RTEMS_CHECK_BSPDIR],
> case "$1" in
> + TLL6527M )
> + AC_CONFIG_SUBDIRS([TLL6527M]);;
> bf537Stamp )
> AC_CONFIG_SUBDIRS([bf537Stamp]);;
> eZKit533 )
> AC_CONFIG_SUBDIRS([eZKit533]);;
> - TLL6527M )
> - AC_CONFIG_SUBDIRS([TLL6527M]);;
> AC_MSG_ERROR([Invalid BSP]);;
> esac
> diff --git a/c/src/lib/libbsp/powerpc/acinclude.m4 b/c/src/lib/libbsp/powerpc/acinclude.m4
> index e46fa2b..6442399 100644
> --- a/c/src/lib/libbsp/powerpc/acinclude.m4
> +++ b/c/src/lib/libbsp/powerpc/acinclude.m4
> @@ -38,12 +38,12 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
> AC_CONFIG_SUBDIRS([t32mppc]);;
> tqm8xx )
> AC_CONFIG_SUBDIRS([tqm8xx]);;
> + virtex )
> + AC_CONFIG_SUBDIRS([virtex]);;
> virtex4 )
> AC_CONFIG_SUBDIRS([virtex4]);;
> virtex5 )
> AC_CONFIG_SUBDIRS([virtex5]);;
> - virtex )
> - AC_CONFIG_SUBDIRS([virtex]);;
> esac
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index 8e61968..e0dfb05 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -27,9 +27,7 @@ SUBDIRS = \
> spintrcritical17 spintrcritical18 spmkdir spmountmgr01 spheapprot \
> spsem01 spsem02 spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
> spedfsched01 spedfsched02 spedfsched03 \
> - spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
> - spatomic01 spatomic02 spatomic03 spatomic04 spatomic05 \
> - spatomic06 spatomic07
> + spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01
> SUBDIRS += spcontext01
> SUBDIRS += spfatal26
> SUBDIRS += speventtransient01
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index db44659..c2a2f11 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -117,13 +117,6 @@ sp76/Makefile
> sp77/Makefile
> sp2038/Makefile
> spassoc01/Makefile
> -spatomic01/Makefile
> -spatomic02/Makefile
> -spatomic03/Makefile
> -spatomic04/Makefile
> -spatomic05/Makefile
> -spatomic06/Makefile
> -spatomic07/Makefile
> spcbssched01/Makefile
> spcbssched02/Makefile
> spcbssched03/Makefile
> diff --git a/testsuites/sptests/spatomic01/Makefile.am b/testsuites/sptests/spatomic01/Makefile.am
> deleted file mode 100644
> index 3bf1e11..0000000
> --- a/testsuites/sptests/spatomic01/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic01
> -spatomic01_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic01.scn
> -dist_rtems_tests_DATA += spatomic01.doc
> -endif
> -include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
> -include $(top_srcdir)/../automake/compile.am
> -include $(top_srcdir)/../automake/leaf.am
> -if ATOMIC
> -AM_CPPFLAGS += -I$(top_srcdir)/../support/include
> -LINK_OBJS = $(spatomic01_OBJECTS)
> -LINK_LIBS = $(spatomic01_LDLIBS)
> -spatomic01$(EXEEXT): $(spatomic01_OBJECTS) $(spatomic01_DEPENDENCIES)
> - @rm -f spatomic01$(EXEEXT)
> - $(make-exe)
> -endif
> -include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/spatomic01/init.c b/testsuites/sptests/spatomic01/init.c
> index 7326bf7..0000000
> --- a/testsuites/sptests/spatomic01/init.c
> +++ /dev/null
> @@ -1,63 +0,0 @@
> - * Copyright (c) 2012 Deng Hengyi.
> - * This test case is to test atomic load operation.
> - * The license and distribution terms for this file may be
> - * found in the file LICENSE in this distribution or at
> - * http://www.rtems.com/license/LICENSE.
> -#ifdef HAVE_CONFIG_H
> -#include "config.h"
> -#endif
> -#define CONFIGURE_INIT
> -#include "system.h"
> -rtems_task Init(
> - rtems_task_argument argument
> - int i;
> - char ch;
> - rtems_id id;
> - rtems_status_code status;
> - /* Put start of test message */
> - puts( "\n\n*** spatomic01 TEST ***\n" );
> - /* Create and start tasks to test */
> - for ( i=0; i< TASK_NUMS ; i++ ) {
> - ch = '0' + i;
> - status = rtems_task_create(
> - rtems_build_name( 'T', 'A', ch, ' ' ),
> - 1,
> - RTEMS_MINIMUM_STACK_SIZE,
> - RTEMS_DEFAULT_MODES,
> - RTEMS_DEFAULT_ATTRIBUTES,
> - &id
> - directive_failed( status, "task create" );
> - status = rtems_task_start( id, Test_task, i );
> - directive_failed( status, "task start" );
> - rtems_build_name( 'A', 'T', '0', ' ' ),
> - 1,
> - &id
> - status = rtems_task_start( id, Wait_task, 0 );
> - status = rtems_task_delete( RTEMS_SELF );
> - directive_failed( status, "delete" );
> diff --git a/testsuites/sptests/spatomic01/spatomic01.doc b/testsuites/sptests/spatomic01/spatomic01.doc
> index dc322a3..0000000
> --- a/testsuites/sptests/spatomic01/spatomic01.doc
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -# COPYRIGHT (c) 1989-2012.
> -# On-Line Applications Research Corporation (OAR).
> -# The license and distribution terms for this file may be
> -# found in the file LICENSE in this distribution or at
> -# http://www.rtems.com/license/LICENSE.
> -This file describes the directives and concepts tested by this test set.
> -test set name: spatomic01
> -directives:
> - _Atomic_Load_int
> - _Atomic_Load_long
> - _Atomic_Load_ptr
> - _Atomic_Load_32
> - _Atomic_Load_64
> -concepts:
> -+ Ensure that the atomic load operations listed above behave as defined.
> diff --git a/testsuites/sptests/spatomic01/spatomic01.scn b/testsuites/sptests/spatomic01/spatomic01.scn
> index 9979d80..0000000
> --- a/testsuites/sptests/spatomic01/spatomic01.scn
> +++ /dev/null
> @@ -1,70 +0,0 @@
> -*** spatomic01 TEST ***
> -task0: _Atomic_Load_int: SUCCESS
> -task0: _Atomic_Load_long: SUCCESS
> -task0: _Atomic_Load_ptr: SUCCESS
> -task0: _Atomic_Load_32: SUCCESS
> -task1: _Atomic_Load_int: SUCCESS
> -task1: _Atomic_Load_long: SUCCESS
> -task1: _Atomic_Load_ptr: SUCCESS
> -task1: _Atomic_Load_32: SUCCESS
> -task2: _Atomic_Load_int: SUCCESS
> -task2: _Atomic_Load_long: SUCCESS
> -task2: _Atomic_Load_ptr: SUCCESS
> -task2: _Atomic_Load_32: SUCCESS
> -task3: _Atomic_Load_int: SUCCESS
> -task3: _Atomic_Load_long: SUCCESS
> -task3: _Atomic_Load_ptr: SUCCESS
> -task3: _Atomic_Load_32: SUCCESS
> -*** END OF TEST spatomic01 ***
> diff --git a/testsuites/sptests/spatomic01/system.h b/testsuites/sptests/spatomic01/system.h
> index 55931f2..0000000
> --- a/testsuites/sptests/spatomic01/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> - * COPYRIGHT (c) 1989-2011.
> - * On-Line Applications Research Corporation (OAR).
> -#include "tmacros.h"
> -#include "test_support.h"
> -/* functions */
> -rtems_task Init(
> -rtems_task Test_task(
> -rtems_task Wait_task(
> -/* configuration information */
> -#define TASK_NUMS 4
> -#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> -#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> -#define CONFIGURE_MAXIMUM_TASKS \
> - (2 + TASK_NUMS)
> -#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> -#include <rtems/confdefs.h>
> -/* global variables */
> - * Keep the names and IDs in global variables so another task can use them.
> -TEST_EXTERN volatile bool TaskRan[ TASK_NUMS ];
> - * Handy macros and static inline functions
> -/* end of include file */
> diff --git a/testsuites/sptests/spatomic01/tasks.c b/testsuites/sptests/spatomic01/tasks.c
> index 9392a5b..0000000
> --- a/testsuites/sptests/spatomic01/tasks.c
> +++ /dev/null
> @@ -1,93 +0,0 @@
> -#endif
> -#include <stdlib.h>
> -#include <rtems/rtems/atomic.h>
> -#define TEST_REPEAT 1000
> -#define ATOMIC_LOAD_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar) \
> - Atomic_##TYPE t; \
> - R_TYPE a; \
> - R_TYPE b; \
> - unsigned int i; \
> - for (i = 0; i < TEST_REPEAT; i++){ \
> - b = (R_TYPE)rand(); \
> - atomic_init(&t, b); \
> - a = _Atomic_Load_##NAME(&t, mem_bar); \
> - rtems_test_assert(a == b); \
> - printf("\ntask%d: Atomic_Load_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - /* Get the task name */
> - p = rtems_object_get_name( RTEMS_SELF, 5, name );
> - rtems_test_assert( p != NULL );
> - /* Print that the task is up and running. */
> - /* test relaxed barrier */
> - ATOMIC_LOAD_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - /* test acquire barrier */
> - ATOMIC_LOAD_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_LOAD_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_ACQUIRE);
> - /* Set the flag that the task is up and running */
> - TaskRan[argument] = true;
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - /* Wait on the all tasks to run */
> - while (1) {
> - allDone = true;
> - for ( i=0; i<TASK_NUMS ; i++ ) {
> - if (TaskRan[i] == false)
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic01 ***\n" );
> - rtems_test_exit( 0 );
> diff --git a/testsuites/sptests/spatomic02/Makefile.am b/testsuites/sptests/spatomic02/Makefile.am
> index cf3e655..0000000
> --- a/testsuites/sptests/spatomic02/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic02
> -spatomic02_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic02.scn
> -dist_rtems_tests_DATA += spatomic02.doc
> -endif
> -if ATOMIC
> -LINK_OBJS = $(spatomic02_OBJECTS)
> -LINK_LIBS = $(spatomic02_LDLIBS)
> -spatomic02$(EXEEXT): $(spatomic02_OBJECTS) $(spatomic02_DEPENDENCIES)
> - $(make-exe)
> -endif
> diff --git a/testsuites/sptests/spatomic02/init.c b/testsuites/sptests/spatomic02/init.c
> index 7eec1ea..0000000
> --- a/testsuites/sptests/spatomic02/init.c
> +++ /dev/null
> @@ -1,68 +0,0 @@
> - * This test case is to test atomic store operation.
> -#endif
> -rtems_task Init(
> - int i;
> - char ch;
> - rtems_id id;
> - puts( "\n\n*** spatomic02 TEST ***\n" );
> - /* Initialize the TaskRan array */
> - TaskRan[i] = false;
> - /* Create and start tasks for each processor */
> - ch = '0' + i;
> - 1,
> - &id
> - 1,
> - &id
> diff --git a/testsuites/sptests/spatomic02/spatomic02.doc b/testsuites/sptests/spatomic02/spatomic02.doc
> index 70e6744..0000000
> --- a/testsuites/sptests/spatomic02/spatomic02.doc
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -test set name: spatomic02
> -directives:
> - _Atomic_Store_int
> - _Atomic_Store_long
> - _Atomic_Store_ptr
> - _Atomic_Store_32
> - _Atomic_Store_64
> -concepts:
> -+ Ensure that the atomic store operations listed above behave as defined.
> diff --git a/testsuites/sptests/spatomic02/spatomic02.scn b/testsuites/sptests/spatomic02/spatomic02.scn
> index 31ba7e9..0000000
> --- a/testsuites/sptests/spatomic02/spatomic02.scn
> +++ /dev/null
> @@ -1,70 +0,0 @@
> -*** spatomic02 TEST ***
> -task0: _Atomic_Store_int: SUCCESS
> -task0: _Atomic_Store_long: SUCCESS
> -task0: _Atomic_Store_ptr: SUCCESS
> -task0: _Atomic_Store_32: SUCCESS
> -task1: _Atomic_Store_int: SUCCESS
> -task1: _Atomic_Store_long: SUCCESS
> -task1: _Atomic_Store_ptr: SUCCESS
> -task1: _Atomic_Store_32: SUCCESS
> -task2: _Atomic_Store_int: SUCCESS
> -task2: _Atomic_Store_long: SUCCESS
> -task2: _Atomic_Store_ptr: SUCCESS
> -task2: _Atomic_Store_32: SUCCESS
> -task3: _Atomic_Store_int: SUCCESS
> -task3: _Atomic_Store_long: SUCCESS
> -task3: _Atomic_Store_ptr: SUCCESS
> -task3: _Atomic_Store_32: SUCCESS
> -*** END OF TEST spatomic02 ***
> diff --git a/testsuites/sptests/spatomic02/system.h b/testsuites/sptests/spatomic02/system.h
> --- a/testsuites/sptests/spatomic02/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> -/* functions */
> -rtems_task Init(
> - (2 + TASK_NUMS)
> diff --git a/testsuites/sptests/spatomic02/tasks.c b/testsuites/sptests/spatomic02/tasks.c
> index 558b718..0000000
> --- a/testsuites/sptests/spatomic02/tasks.c
> +++ /dev/null
> @@ -1,94 +0,0 @@
> -#endif
> -#define ATOMIC_STORE_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar) \
> - R_TYPE a; \
> - R_TYPE b; \
> - unsigned int i; \
> - _Atomic_Store_##NAME(&t, b, mem_bar); \
> - a = _Atomic_Load_##NAME(&t, memory_order_relaxed); \
> - printf("\ntask%d: Atomic_Store_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - ATOMIC_STORE_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - /* test release barrier */
> - ATOMIC_STORE_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELEASE);
> - ATOMIC_STORE_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELEASE);
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - while (1) {
> - allDone = true;
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic02 ***\n" );
> diff --git a/testsuites/sptests/spatomic03/Makefile.am b/testsuites/sptests/spatomic03/Makefile.am
> index 15b3b47..0000000
> --- a/testsuites/sptests/spatomic03/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic03
> -spatomic03_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic03.scn
> -dist_rtems_tests_DATA += spatomic03.doc
> -endif
> -if ATOMIC
> -LINK_OBJS = $(spatomic03_OBJECTS)
> -LINK_LIBS = $(spatomic03_LDLIBS)
> -spatomic03$(EXEEXT): $(spatomic03_OBJECTS) $(spatomic03_DEPENDENCIES)
> - @rm -f spatomic03$(EXEEXT)
> - $(make-exe)
> -endif
> diff --git a/testsuites/sptests/spatomic03/init.c b/testsuites/sptests/spatomic03/init.c
> index 946797e..0000000
> --- a/testsuites/sptests/spatomic03/init.c
> +++ /dev/null
> @@ -1,68 +0,0 @@
> - * This test case is to test atomic add operation.
> -#endif
> -rtems_task Init(
> - int i;
> - char ch;
> - rtems_id id;
> - puts( "\n\n*** spatomic03 TEST ***\n" );
> - ch = '0' + i;
> - 1,
> - &id
> - 1,
> - &id
> diff --git a/testsuites/sptests/spatomic03/spatomic03.doc b/testsuites/sptests/spatomic03/spatomic03.doc
> index 130dca9..0000000
> --- a/testsuites/sptests/spatomic03/spatomic03.doc
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -test set name: spatomic03
> -directives:
> - _Atomic_Fetch_add_int
> - _Atomic_Fetch_add_long
> - _Atomic_Fetch_add_ptr
> - _Atomic_Fetch_add_32
> - _Atomic_Fetch_add_64
> -concepts:
> -+ Ensure that the atomic add operations listed above behave as defined.
> diff --git a/testsuites/sptests/spatomic03/spatomic03.scn b/testsuites/sptests/spatomic03/spatomic03.scn
> index 69216e5..0000000
> --- a/testsuites/sptests/spatomic03/spatomic03.scn
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -*** spatomic03 TEST ***
> -task0: _Atomic_Fetch_add_int: SUCCESS
> -task0: _Atomic_Fetch_add_long: SUCCESS
> -task0: _Atomic_Fetch_add_ptr: SUCCESS
> -task0: _Atomic_Fetch_add_32: SUCCESS
> -task1: _Atomic_Fetch_add_int: SUCCESS
> -task1: _Atomic_Fetch_add_long: SUCCESS
> -task1: _Atomic_Fetch_add_ptr: SUCCESS
> -task1: _Atomic_Fetch_add_32: SUCCESS
> -task2: _Atomic_Fetch_add_int: SUCCESS
> -task2: _Atomic_Fetch_add_long: SUCCESS
> -task2: _Atomic_Fetch_add_ptr: SUCCESS
> -task2: _Atomic_Fetch_add_32: SUCCESS
> -task3: _Atomic_Fetch_add_int: SUCCESS
> -task3: _Atomic_Fetch_add_long: SUCCESS
> -task3: _Atomic_Fetch_add_ptr: SUCCESS
> -task3: _Atomic_Fetch_add_32: SUCCESS
> -*** END OF TEST spatomic03 ***
> diff --git a/testsuites/sptests/spatomic03/system.h b/testsuites/sptests/spatomic03/system.h
> --- a/testsuites/sptests/spatomic03/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> -/* functions */
> -rtems_task Init(
> - (2 + TASK_NUMS)
> diff --git a/testsuites/sptests/spatomic03/tasks.c b/testsuites/sptests/spatomic03/tasks.c
> index d03cf54..0000000
> --- a/testsuites/sptests/spatomic03/tasks.c
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -#endif
> -#define ATOMIC_FETCH_ADD_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar)\
> - R_TYPE a; \
> - R_TYPE b; \
> - R_TYPE c; \
> - unsigned int i; \
> - a = (R_TYPE)(rand() % ((R_TYPE)-1 / 2)); \
> - b = (R_TYPE)(rand() % ((R_TYPE)-1 / 2)); \
> - _Atomic_Store_##NAME(&t, a, ATOMIC_ORDER_RELAXED); \
> - _Atomic_Fetch_add_##NAME(&t, b, mem_bar); \
> - c = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_RELAXED); \
> - rtems_test_assert(c == (R_TYPE)(a + b)); \
> - printf("\ntask%d: Atomic_Fetch_add_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_ADD_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELEASE);
> - ATOMIC_FETCH_ADD_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELEASE);
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - while (1) {
> - allDone = true;
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic03 ***\n" );
> diff --git a/testsuites/sptests/spatomic04/Makefile.am b/testsuites/sptests/spatomic04/Makefile.am
> index d03e8b5..0000000
> --- a/testsuites/sptests/spatomic04/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic04
> -spatomic04_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic04.scn
> -dist_rtems_tests_DATA += spatomic04.doc
> -endif
> -if ATOMIC
> -LINK_OBJS = $(spatomic04_OBJECTS)
> -LINK_LIBS = $(spatomic04_LDLIBS)
> -spatomic04$(EXEEXT): $(spatomic04_OBJECTS) $(spatomic04_DEPENDENCIES)
> - @rm -f spatomic04$(EXEEXT)
> - $(make-exe)
> -endif
> diff --git a/testsuites/sptests/spatomic04/init.c b/testsuites/sptests/spatomic04/init.c
> index f0b0751..0000000
> --- a/testsuites/sptests/spatomic04/init.c
> +++ /dev/null
> @@ -1,68 +0,0 @@
> - * This test case is to test atomic sub operation.
> -#endif
> -rtems_task Init(
> - int i;
> - char ch;
> - rtems_id id;
> - puts( "\n\n*** spatomic04 TEST ***\n" );
> - ch = '0' + i;
> - 1,
> - &id
> - 1,
> - &id
> diff --git a/testsuites/sptests/spatomic04/spatomic04.doc b/testsuites/sptests/spatomic04/spatomic04.doc
> index 6fc8f09..0000000
> --- a/testsuites/sptests/spatomic04/spatomic04.doc
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -test set name: spatomic04
> -directives:
> - _Atomic_Fetch_sub_int
> - _Atomic_Fetch_sub_long
> - _Atomic_Fetch_sub_ptr
> - _Atomic_Fetch_sub_32
> - _Atomic_Fetch_sub_64
> -concepts:
> -+ Ensure that the atomic sub operations listed above behave as defined.
> diff --git a/testsuites/sptests/spatomic04/spatomic04.scn b/testsuites/sptests/spatomic04/spatomic04.scn
> index 550e87e..0000000
> --- a/testsuites/sptests/spatomic04/spatomic04.scn
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -patomic04 TEST ***
> -task0: _Atomic_Fetch_sub_int: SUCCESS
> -task0: _Atomic_Fetch_sub_long: SUCCESS
> -task0: _Atomic_Fetch_sub_ptr: SUCCESS
> -task0: _Atomic_Fetch_sub_32: SUCCESS
> -task1: _Atomic_Fetch_sub_int: SUCCESS
> -task1: _Atomic_Fetch_sub_long: SUCCESS
> -task1: _Atomic_Fetch_sub_ptr: SUCCESS
> -task1: _Atomic_Fetch_sub_32: SUCCESS
> -task2: _Atomic_Fetch_sub_int: SUCCESS
> -task2: _Atomic_Fetch_sub_long: SUCCESS
> -task2: _Atomic_Fetch_sub_ptr: SUCCESS
> -task2: _Atomic_Fetch_sub_32: SUCCESS
> -task3: _Atomic_Fetch_sub_int: SUCCESS
> -task3: _Atomic_Fetch_sub_long: SUCCESS
> -task3: _Atomic_Fetch_sub_ptr: SUCCESS
> -task3: _Atomic_Fetch_sub_32: SUCCESS
> -*** END OF TEST spatomic04 ***
> diff --git a/testsuites/sptests/spatomic04/system.h b/testsuites/sptests/spatomic04/system.h
> --- a/testsuites/sptests/spatomic04/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> -/* functions */
> -rtems_task Init(
> - (2 + TASK_NUMS)
> diff --git a/testsuites/sptests/spatomic04/tasks.c b/testsuites/sptests/spatomic04/tasks.c
> index 9f587be..0000000
> --- a/testsuites/sptests/spatomic04/tasks.c
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -#endif
> -#define ATOMIC_FETCH_SUB_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar)\
> - R_TYPE a; \
> - R_TYPE b; \
> - R_TYPE c; \
> - unsigned int i; \
> - _Atomic_Fetch_sub_##NAME(&t, b, mem_bar); \
> - rtems_test_assert(c == (R_TYPE)(a - b)); \
> - printf("\ntask%d: Atomic_Fetch_sub_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_SUB_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELEASE);
> - ATOMIC_FETCH_SUB_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELEASE);
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - while (1) {
> - allDone = true;
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic04 ***\n" );
> diff --git a/testsuites/sptests/spatomic05/Makefile.am b/testsuites/sptests/spatomic05/Makefile.am
> index cf72b8e..0000000
> --- a/testsuites/sptests/spatomic05/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic05
> -spatomic05_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic05.scn
> -dist_rtems_tests_DATA += spatomic05.doc
> -endif
> -if ATOMIC
> -LINK_OBJS = $(spatomic05_OBJECTS)
> -LINK_LIBS = $(spatomic05_LDLIBS)
> -spatomic05$(EXEEXT): $(spatomic05_OBJECTS) $(spatomic05_DEPENDENCIES)
> - @rm -f spatomic05$(EXEEXT)
> - $(make-exe)
> -endif
> diff --git a/testsuites/sptests/spatomic05/init.c b/testsuites/sptests/spatomic05/init.c
> index 328d417..0000000
> --- a/testsuites/sptests/spatomic05/init.c
> +++ /dev/null
> @@ -1,68 +0,0 @@
> - * This test case is to test atomic and operation.
> -#endif
> -rtems_task Init(
> - int i;
> - char ch;
> - rtems_id id;
> - puts( "\n\n*** spatomic05 TEST ***\n" );
> - ch = '0' + i;
> - 1,
> - &id
> - 1,
> - &id
> diff --git a/testsuites/sptests/spatomic05/spatomic05.doc b/testsuites/sptests/spatomic05/spatomic05.doc
> index 018dd64..0000000
> --- a/testsuites/sptests/spatomic05/spatomic05.doc
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -test set name: spatomic05
> -directives:
> - _Atomic_Fetch_and_int
> - _Atomic_Fetch_and_long
> - _Atomic_Fetch_and_ptr
> - _Atomic_Fetch_and_32
> - _Atomic_Fetch_and_64
> -concepts:
> -+ Ensure that the atomic and operations listed above behave as defined.
> diff --git a/testsuites/sptests/spatomic05/spatomic05.scn b/testsuites/sptests/spatomic05/spatomic05.scn
> index 84020b9..0000000
> --- a/testsuites/sptests/spatomic05/spatomic05.scn
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -patomic05 TEST ***
> -task0: _Atomic_Fetch_and_int: SUCCESS
> -task0: _Atomic_Fetch_and_long: SUCCESS
> -task0: _Atomic_Fetch_and_ptr: SUCCESS
> -task0: _Atomic_Fetch_and_32: SUCCESS
> -task1: _Atomic_Fetch_and_int: SUCCESS
> -task1: _Atomic_Fetch_and_long: SUCCESS
> -task1: _Atomic_Fetch_and_ptr: SUCCESS
> -task1: _Atomic_Fetch_and_32: SUCCESS
> -task2: _Atomic_Fetch_and_int: SUCCESS
> -task2: _Atomic_Fetch_and_long: SUCCESS
> -task2: _Atomic_Fetch_and_ptr: SUCCESS
> -task2: _Atomic_Fetch_and_32: SUCCESS
> -task3: _Atomic_Fetch_and_int: SUCCESS
> -task3: _Atomic_Fetch_and_long: SUCCESS
> -task3: _Atomic_Fetch_and_ptr: SUCCESS
> -task3: _Atomic_Fetch_and_32: SUCCESS
> -*** END OF TEST spatomic05 ***
> diff --git a/testsuites/sptests/spatomic05/system.h b/testsuites/sptests/spatomic05/system.h
> --- a/testsuites/sptests/spatomic05/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> -/* functions */
> -rtems_task Init(
> - (2 + TASK_NUMS)
> diff --git a/testsuites/sptests/spatomic05/tasks.c b/testsuites/sptests/spatomic05/tasks.c
> index 5f93dae..0000000
> --- a/testsuites/sptests/spatomic05/tasks.c
> +++ /dev/null
> @@ -1,101 +0,0 @@
> -#endif
> -#define ATOMIC_FETCH_AND_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar)\
> - R_TYPE a; \
> - R_TYPE b; \
> - R_TYPE c; \
> - unsigned int i; \
> - _Atomic_Fetch_and_##NAME(&t, b, mem_bar); \
> - rtems_test_assert(c == (R_TYPE)(a & b)); \
> - printf("\ntask%d: Atomic_Fetch_and_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_AND_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELEASE);
> - ATOMIC_FETCH_AND_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELEASE);
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - while (1) {
> - allDone = true;
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic05 ***\n" );
> diff --git a/testsuites/sptests/spatomic06/Makefile.am b/testsuites/sptests/spatomic06/Makefile.am
> index 82150f9..0000000
> --- a/testsuites/sptests/spatomic06/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic06
> -spatomic06_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic06.scn
> -dist_rtems_tests_DATA += spatomic06.doc
> -endif
> -if ATOMIC
> -LINK_OBJS = $(spatomic06_OBJECTS)
> -LINK_LIBS = $(spatomic06_LDLIBS)
> -spatomic06$(EXEEXT): $(spatomic06_OBJECTS) $(spatomic06_DEPENDENCIES)
> - @rm -f spatomic06$(EXEEXT)
> - $(make-exe)
> -endif
> diff --git a/testsuites/sptests/spatomic06/init.c b/testsuites/sptests/spatomic06/init.c
> index 4a7ecfc..0000000
> --- a/testsuites/sptests/spatomic06/init.c
> +++ /dev/null
> @@ -1,68 +0,0 @@
> - * This test case is to test atomic or operation.
> -#endif
> -rtems_task Init(
> - int i;
> - char ch;
> - rtems_id id;
> - puts( "\n\n*** spatomic06 TEST ***\n" );
> - ch = '0' + i;
> - 1,
> - &id
> - 1,
> - &id
> diff --git a/testsuites/sptests/spatomic06/spatomic06.doc b/testsuites/sptests/spatomic06/spatomic06.doc
> index 5a4d033..0000000
> --- a/testsuites/sptests/spatomic06/spatomic06.doc
> +++ /dev/null
> @@ -1,23 +0,0 @@
> -test set name: spatomic06
> -directives:
> - _Atomic_Fetch_or_int
> - _Atomic_Fetch_or_long
> - _Atomic_Fetch_or_ptr
> - _Atomic_Fetch_or_32
> - _Atomic_Fetch_or_64
> -concepts:
> -+ Ensure that the atomic or operations listed above behave as defined.
> diff --git a/testsuites/sptests/spatomic06/spatomic06.scn b/testsuites/sptests/spatomic06/spatomic06.scn
> index 1429061..0000000
> --- a/testsuites/sptests/spatomic06/spatomic06.scn
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -*** spatomic06 TEST ***
> -task0: _Atomic_Fetch_or_int: SUCCESS
> -task0: _Atomic_Fetch_or_long: SUCCESS
> -task0: _Atomic_Fetch_or_ptr: SUCCESS
> -task0: _Atomic_Fetch_or_32: SUCCESS
> -task1: _Atomic_Fetch_or_int: SUCCESS
> -task1: _Atomic_Fetch_or_long: SUCCESS
> -task1: _Atomic_Fetch_or_ptr: SUCCESS
> -task1: _Atomic_Fetch_or_32: SUCCESS
> -task2: _Atomic_Fetch_or_int: SUCCESS
> -task2: _Atomic_Fetch_or_long: SUCCESS
> -task2: _Atomic_Fetch_or_ptr: SUCCESS
> -task2: _Atomic_Fetch_or_32: SUCCESS
> -task3: _Atomic_Fetch_or_int: SUCCESS
> -task3: _Atomic_Fetch_or_long: SUCCESS
> -task3: _Atomic_Fetch_or_ptr: SUCCESS
> -task3: _Atomic_Fetch_or_32: SUCCESS
> -*** END OF TEST spatomic06 ***
> diff --git a/testsuites/sptests/spatomic06/system.h b/testsuites/sptests/spatomic06/system.h
> --- a/testsuites/sptests/spatomic06/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> -/* functions */
> -rtems_task Init(
> - (2 + TASK_NUMS)
> diff --git a/testsuites/sptests/spatomic06/tasks.c b/testsuites/sptests/spatomic06/tasks.c
> index b03d3f0..0000000
> --- a/testsuites/sptests/spatomic06/tasks.c
> +++ /dev/null
> @@ -1,101 +0,0 @@
> -#endif
> -#define ATOMIC_FETCH_OR_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar) \
> - R_TYPE a; \
> - R_TYPE b; \
> - R_TYPE c; \
> - unsigned int i; \
> - _Atomic_Fetch_or_##NAME(&t, b, mem_bar); \
> - rtems_test_assert(c == (R_TYPE)(a | b)); \
> - printf("\ntask%d: Atomic_Fetch_or_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_FETCH_OR_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELEASE);
> - ATOMIC_FETCH_OR_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELEASE);
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - while (1) {
> - allDone = true;
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic06 ***\n" );
> diff --git a/testsuites/sptests/spatomic07/Makefile.am b/testsuites/sptests/spatomic07/Makefile.am
> index bd63c52..0000000
> --- a/testsuites/sptests/spatomic07/Makefile.am
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -if ATOMIC
> -rtems_tests_PROGRAMS = spatomic07
> -spatomic07_SOURCES = init.c tasks.c system.h
> -dist_rtems_tests_DATA = spatomic07.scn
> -dist_rtems_tests_DATA += spatomic07.doc
> -endif
> -if ATOMIC
> -LINK_OBJS = $(spatomic07_OBJECTS)
> -LINK_LIBS = $(spatomic07_LDLIBS)
> -spatomic07$(EXEEXT): $(spatomic07_OBJECTS) $(spatomic07_DEPENDENCIES)
> - @rm -f spatomic07$(EXEEXT)
> - $(make-exe)
> -endif
> diff --git a/testsuites/sptests/spatomic07/init.c b/testsuites/sptests/spatomic07/init.c
> index 3cc1b27..0000000
> --- a/testsuites/sptests/spatomic07/init.c
> +++ /dev/null
> @@ -1,68 +0,0 @@
> - * This test case is to test atomic compare and exchange operation.
> -#endif
> -rtems_task Init(
> - int i;
> - char ch;
> - rtems_id id;
> - puts( "\n\n*** spatomic07 TEST ***\n" );
> - ch = '0' + i;
> - 1,
> - &id
> - 1,
> - &id
> diff --git a/testsuites/sptests/spatomic07/spatomic07.doc b/testsuites/sptests/spatomic07/spatomic07.doc
> index 4ade88f..0000000
> --- a/testsuites/sptests/spatomic07/spatomic07.doc
> +++ /dev/null
> @@ -1,24 +0,0 @@
> -test set name: spatomic07
> -directives:
> - _Atomic_Compare_exchange_int
> - _Atomic_Compare_exchange_long
> - _Atomic_Compare_exchange_ptr
> - _Atomic_Compare_exchange_32
> - _Atomic_Compare_exchange_64
> -concepts:
> -+ Ensure that the atomic compare and exchange operations listed above behave
> - as defined.
> diff --git a/testsuites/sptests/spatomic07/spatomic07.scn b/testsuites/sptests/spatomic07/spatomic07.scn
> index bb37ba6..0000000
> --- a/testsuites/sptests/spatomic07/spatomic07.scn
> +++ /dev/null
> @@ -1,102 +0,0 @@
> -patomic07 TEST ***
> -task0: _Atomic_Compare_exchange_int: SUCCESS
> -task0: _Atomic_Compare_exchange_long: SUCCESS
> -task0: _Atomic_Compare_exchange_ptr: SUCCESS
> -task0: _Atomic_Compare_exchange_32: SUCCESS
> -task1: _Atomic_Compare_exchange_int: SUCCESS
> -task1: _Atomic_Compare_exchange_long: SUCCESS
> -task1: _Atomic_Compare_exchange_ptr: SUCCESS
> -task1: _Atomic_Compare_exchange_32: SUCCESS
> -task2: _Atomic_Compare_exchange_int: SUCCESS
> -task2: _Atomic_Compare_exchange_long: SUCCESS
> -task2: _Atomic_Compare_exchange_ptr: SUCCESS
> -task2: _Atomic_Compare_exchange_32: SUCCESS
> -task3: _Atomic_Compare_exchange_int: SUCCESS
> -task3: _Atomic_Compare_exchange_long: SUCCESS
> -task3: _Atomic_Compare_exchange_ptr: SUCCESS
> -task3: _Atomic_Compare_exchange_32: SUCCESS
> -*** END OF TEST spatomic07 ***
> diff --git a/testsuites/sptests/spatomic07/system.h b/testsuites/sptests/spatomic07/system.h
> --- a/testsuites/sptests/spatomic07/system.h
> +++ /dev/null
> @@ -1,51 +0,0 @@
> -/* functions */
> -rtems_task Init(
> - (2 + TASK_NUMS)
> diff --git a/testsuites/sptests/spatomic07/tasks.c b/testsuites/sptests/spatomic07/tasks.c
> index 286a994..0000000
> --- a/testsuites/sptests/spatomic07/tasks.c
> +++ /dev/null
> @@ -1,117 +0,0 @@
> -#endif
> -#define ATOMIC_CAS_NO_BARRIER(NAME, TYPE, R_TYPE, task_id, mem_bar) \
> - R_TYPE a; \
> - R_TYPE b; \
> - unsigned int i; \
> - int r; \
> - a = rand() % (R_TYPE)-1; \
> - b = a + 1; \
> - r = _Atomic_Compare_exchange_##NAME(&t, &b, a - 1, mem_bar, memory_order_relaxed); \
> - if(r != 0){ \
> - printf("\ntask%d: Atomic_Compare_exchange_" #NAME ": FAILED\n", (unsigned int)task_id); \
> - rtems_test_exit( 0 ); \
> - r = _Atomic_Compare_exchange_##NAME(&t, &a, a - 1, mem_bar, memory_order_relaxed); \
> - b = _Atomic_Load_##NAME(&t, ATOMIC_ORDER_RELAXED); \
> - if((r == 0) ||((r != 0) && ((a - 1) != b))){ \
> - b = a + 1; \
> - r = _Atomic_Compare_exchange_##NAME(&t, &b, a, mem_bar, memory_order_relaxed); \
> - if(r != 0){ \
> - printf("\ntask%d: Atomic_Compare_exchange_" #NAME ": SUCCESS\n", (unsigned int)task_id); \
> - char name[5];
> - char *p;
> - ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELAXED);
> - ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_ACQUIRE);
> - ATOMIC_CAS_NO_BARRIER(uint, Uint, uint_fast32_t, argument, ATOMIC_ORDER_RELEASE);
> - ATOMIC_CAS_NO_BARRIER(ptr, Pointer, uintptr_t, argument, ATOMIC_ORDER_RELEASE);
> - char name[5];
> - char *p;
> - bool allDone;
> - int i;
> - while (1) {
> - allDone = true;
> - allDone = false;
> - if (allDone) {
> - puts( "\n\n*** END OF TEST spatomic07 ***\n" );
> 1.7.9.5
> rtems-devel mailing list
