[PATCH v2] score: Error for non-preemptible tasks on SMP
Fri Jul 19 08:18:54 UTC 2013
A common use case for disabled preemption was to ensure mutual exclusion
on single-processor configurations.  On SMP this does not work.
To abandon non-preemptible tasks simplifies the scheduler.
 cpukit/rtems/src/taskcreate.c               |    1 +
 cpukit/rtems/src/taskmode.c                 |   13 ++-
 cpukit/sapi/include/confdefs.h              |    6 +-
 cpukit/score/src/threadinitialize.c         |    7 ++
 testsuites/smptests/Makefile.am             |    1 -
 testsuites/smptests/configure.ac            |    1 -
 testsuites/smptests/smp04/Makefile.am       |   23 ----
 testsuites/smptests/smp04/init.c            |  150 ---------------------------
 testsuites/smptests/smp04/smp04.doc         |   14 ---
 testsuites/smptests/smp04/smp04.scn         |    8 --
 testsuites/smptests/smp04/system.h          |   68 ------------
 testsuites/smptests/smpunsupported01/init.c |   17 +++-
 12 files changed, 41 insertions(+), 268 deletions(-)
 delete mode 100644 testsuites/smptests/smp04/Makefile.am
 delete mode 100644 testsuites/smptests/smp04/init.c
 delete mode 100644 testsuites/smptests/smp04/smp04.doc
 delete mode 100644 testsuites/smptests/smp04/smp04.scn
 delete mode 100644 testsuites/smptests/smp04/system.h
diff --git a/cpukit/rtems/src/taskcreate.c b/cpukit/rtems/src/taskcreate.c
index 64ad1eb..471990d 100644
--- a/cpukit/rtems/src/taskcreate.c
+++ b/cpukit/rtems/src/taskcreate.c
@@ -19,6 +19,7 @@
 #endif
+#include <rtems/config.h>
 #include <rtems/rtems/modes.h>
diff --git a/cpukit/rtems/src/taskmode.c b/cpukit/rtems/src/taskmode.c
index d9c7fce..eb3636d 100644
--- a/cpukit/rtems/src/taskmode.c
+++ b/cpukit/rtems/src/taskmode.c
@@ -19,6 +19,7 @@
 #endif
@@ -67,8 +68,18 @@ rtems_status_code rtems_task_mode(
    *  These are generic thread scheduling characteristics.
-  if ( mask & RTEMS_PREEMPT_MASK )
+  if ( mask & RTEMS_PREEMPT_MASK ) {
+#if defined( RTEMS_SMP )
+    if (
+      rtems_configuration_is_smp_enabled()
+        && !_Modes_Is_preempt( mode_set )
+      return RTEMS_NOT_IMPLEMENTED;
+#endif
     executing->is_preemptible = _Modes_Is_preempt( mode_set );
   if ( mask & RTEMS_TIMESLICE_MASK ) {
     if ( _Modes_Is_timeslice(mode_set) ) {
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index b7cbfaa..c969fa7 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -1021,7 +1021,11 @@ const rtems_libio_helper rtems_fs_init_helper =
 #endif
 #ifndef CONFIGURE_INIT_TASK_INITIAL_MODES
-  #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
+  #if defined(RTEMS_SMP) && defined(CONFIGURE_SMP_APPLICATION)
+    #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_DEFAULT_MODES
+  #else
+    #define CONFIGURE_INIT_TASK_INITIAL_MODES RTEMS_NO_PREEMPT
+  #endif
 #endif
 #ifndef CONFIGURE_INIT_TASK_ARGUMENTS
diff --git a/cpukit/score/src/threadinitialize.c b/cpukit/score/src/threadinitialize.c
index 4c40ae8..cc74573 100644
--- a/cpukit/score/src/threadinitialize.c
+++ b/cpukit/score/src/threadinitialize.c
@@ -18,6 +18,7 @@
 #endif
 #include <rtems/score/apiext.h>
 #include <rtems/score/context.h>
 #include <rtems/score/interr.h>
@@ -57,6 +58,12 @@ bool _Thread_Initialize(
   bool                 extension_status;
   int                  i;
+  if ( rtems_configuration_is_smp_enabled() && !is_preemptible ) {
+    return false;
+#endif
    *  Initialize the Ada self pointer
diff --git a/testsuites/smptests/Makefile.am b/testsuites/smptests/Makefile.am
index 6760432..7a37751 100644
--- a/testsuites/smptests/Makefile.am
+++ b/testsuites/smptests/Makefile.am
@@ -6,7 +6,6 @@ if SMPTESTS
 SUBDIRS += smp01
 SUBDIRS += smp02
 SUBDIRS += smp03
-SUBDIRS += smp04
 SUBDIRS += smp05
 SUBDIRS += smp06
 SUBDIRS += smp07
diff --git a/testsuites/smptests/configure.ac b/testsuites/smptests/configure.ac
index 9d7a6ca..64859d3 100644
--- a/testsuites/smptests/configure.ac
+++ b/testsuites/smptests/configure.ac
@@ -39,7 +39,6 @@ AC_CONFIG_FILES([Makefile
 smp01/Makefile
 smp02/Makefile
 smp03/Makefile
-smp04/Makefile
 smp05/Makefile
 smp06/Makefile
 smp07/Makefile
diff --git a/testsuites/smptests/smp04/Makefile.am b/testsuites/smptests/smp04/Makefile.am
deleted file mode 100644
index cc426fd..0000000
--- a/testsuites/smptests/smp04/Makefile.am
+++ /dev/null
@@ -1,23 +0,0 @@
-rtems_tests_PROGRAMS = smp04
-smp04_SOURCES = init.c system.h ../../support/src/locked_print.c
-dist_rtems_tests_DATA = smp04.scn
-dist_rtems_tests_DATA += smp04.doc
-include $(RTEMS_ROOT)/make/custom/@RTEMS_BSP at .cfg
-include $(top_srcdir)/../automake/compile.am
-include $(top_srcdir)/../automake/leaf.am
-AM_CPPFLAGS += -I$(top_srcdir)/../support/include
-AM_CPPFLAGS += -DSMPTEST
-LINK_OBJS = $(smp04_OBJECTS)
-LINK_LIBS = $(smp04_LDLIBS)
-smp04$(EXEEXT): $(smp04_OBJECTS) $(smp04_DEPENDENCIES)
-	@rm -f smp04$(EXEEXT)
-	$(make-exe)
-include $(top_srcdir)/../automake/local.am
diff --git a/testsuites/smptests/smp04/init.c b/testsuites/smptests/smp04/init.c
index 8cbfbb8..0000000
--- a/testsuites/smptests/smp04/init.c
+++ /dev/null
@@ -1,150 +0,0 @@
- *  COPYRIGHT (c) 1989-2011.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.com/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#define CONFIGURE_INIT
-#include "system.h"
-#include <stdio.h>
-#include <inttypes.h>
-void Loop() {
-  volatile int i;
-  for (i=0; i<500000; i++);
-rtems_task Test_task(
-  rtems_task_argument task_index
-  uint32_t cpu_num;
-  cpu_num = rtems_smp_get_current_processor();
-  locked_printf("  CPU %d running task TA%" PRIu32 "\n", cpu_num, task_index );
-  Loop();
-  TaskRan[task_index] = true;
-  while(1);
-rtems_task Init(
-  rtems_task_argument argument
-  uint32_t          i;
-  char              ch;
-  rtems_id          id;
-  rtems_status_code status;
-  bool              allDone;
-  uint32_t          cpu_num;
-  Loop();
-  locked_print_initialize();
-  locked_printf( "\n\n***  SMP04 TEST ***\n" );
-  /* Display which cpu is running this init thread. */
-  locked_printf("  CPU %" PRIu32 " running task Init\n", cpu_num );
-  /* Set all Tasks to not ran except for the init task */
-  TaskRan[0] = true;
-  for ( i=1; i <= rtems_smp_get_processor_count() ; i++ )
-    TaskRan[i] = false;
-   * For each processor create and start a task alternating
-   * between  RTEMS_PREEMPT and RTEMS_NO_PREEMPT.
-  for ( i=1; i < rtems_smp_get_processor_count() ; i++ ){
-    /* Create and start tasks for each CPU */
-    ch = '0' + i;
-    locked_printf(
-      "Create a TA%c a %s task\n",
-      ch,
-      ((i%2) ? "RTEMS_PREEMPT" : "RTEMS_NO_PREEMPT" )
-    status = rtems_task_create(
-      rtems_build_name( 'T', 'A', ch, ' ' ),
-      CONFIGURE_INIT_TASK_PRIORITY +
-        (2*rtems_smp_get_processor_count()) - (2*i),
-      RTEMS_MINIMUM_STACK_SIZE,
-      ((i%2) ? RTEMS_PREEMPT : RTEMS_NO_PREEMPT),
-      RTEMS_DEFAULT_ATTRIBUTES,
-      &id
-    locked_printf(
-      "Start TA%c a %s task\n",
-      ch,
-    status = rtems_task_start( id, Test_task, i );
-     * Force a wait on the task to run in order to synchronize on
-     * simulated systems.
-    while (TaskRan[i] == false)
-   * Create and start one more task.  This task
-   * should preempt the longest running PREEMPTABLE
-   * task and run on that cpu.
-  ch = '0' + rtems_smp_get_processor_count() ;
-  locked_printf(
-    ch,
-    "RTEMS_PREEMPT"
-    3,
-    RTEMS_PREEMPT,
-    &id
-  locked_printf(
-    ch,
-    "RTEMS_PREEMPT"
-    id,
-    Test_task,
-    rtems_smp_get_processor_count()
-   * Wait on the all tasks to run
-  while (1) {
-    allDone = true;
-    for ( i=1; i<=rtems_smp_get_processor_count() ; i++ ) {
-      if (TaskRan[i] == false)
-        allDone = false;
-    if (allDone) {
-      Loop();
-      locked_printf( "*** END OF TEST SMP04 ***\n" );
-      rtems_test_exit( 0 );
diff --git a/testsuites/smptests/smp04/smp04.doc b/testsuites/smptests/smp04/smp04.doc
index 274f98d..0000000
--- a/testsuites/smptests/smp04/smp04.doc
+++ /dev/null
@@ -1,14 +0,0 @@
-#  COPYRIGHT (c) 1989-2011.
-#  On-Line Applications Research Corporation (OAR).
-#  The license and distribution terms for this file may be
-#  found in the file LICENSE in this distribution or at
-#  http://www.rtems.com/license/LICENSE.
-This test startst Init task with priority 5 and preemption on which
-runs on CPU 0.  The init task alternates preemption off and preemtion
-on as it creates tasks for every other cpu in the system.  The priority
-of task N will be 5 + 2; task N-1 will be 5 + 4 .....
-Another task will be created after tasks are running on all cpus.  This
-task will be of a priority 3.  For a 4 cpu system this task should run
-on cpu 2.  For a 2 cpu system the task should preempt the Init task.
diff --git a/testsuites/smptests/smp04/smp04.scn b/testsuites/smptests/smp04/smp04.scn
index a6c775c..0000000
--- a/testsuites/smptests/smp04/smp04.scn
+++ /dev/null
@@ -1,8 +0,0 @@
-***  SMP04 TEST ***
-  CPU 0 running task Init
-  CPU 1 running task TA1
-  CPU 2 running task TA2
-  CPU 3 running task TA3
-  CPU 2 running task TA4
-*** END OF SMP 04 TEST ***
diff --git a/testsuites/smptests/smp04/system.h b/testsuites/smptests/smp04/system.h
index d3820c2..0000000
--- a/testsuites/smptests/smp04/system.h
+++ /dev/null
@@ -1,68 +0,0 @@
-#include "tmacros.h"
-#include "test_support.h"
-/* functions */
-rtems_task Init(
-/* configuration information */
-#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
-#define CONFIGURE_SMP_APPLICATION
-#define CONFIGURE_SMP_MAXIMUM_PROCESSORS   4
-#define CONFIGURE_MAXIMUM_TASKS            \
-    (1 + CONFIGURE_SMP_MAXIMUM_PROCESSORS)
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INIT_TASK_STACK_SIZE \
-    (3 * CONFIGURE_MINIMUM_TASK_STACK_SIZE)
-#define CONFIGURE_INIT_TASK_PRIORITY        5
-#define CONFIGURE_INIT_TASK_INITIAL_MODES   RTEMS_NO_PREEMPT
-#define CONFIGURE_MAXIMUM_SEMAPHORES          1
-#include <rtems/confdefs.h>
-/* global variables */
- *  Keep the names and IDs in global variables so another task can use them.
-void Loop(void);
-void PrintTaskInfo(
-  const char *task_name
-TEST_EXTERN volatile bool TaskRan[ CONFIGURE_SMP_MAXIMUM_PROCESSORS ];
- *  Handy macros and static inline functions
- *  Macro to hide the ugliness of printing the time.
-/* end of include file */
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index 3379de6..a9782e8 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -21,6 +21,8 @@
 static void test(void)
   rtems_status_code sc;
+  rtems_mode mode;
+  rtems_id id;
   rtems_test_assert(rtems_configuration_is_smp_enabled());
@@ -35,6 +37,19 @@ static void test(void)
   sc = rtems_task_variable_get(RTEMS_SELF, NULL, NULL);
   rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
+  sc = rtems_task_mode(RTEMS_NO_PREEMPT, RTEMS_PREEMPT_MASK, &mode);
+  rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
+  sc = rtems_task_create(
+    rtems_build_name('T', 'A', 'S', 'K'),
+    RTEMS_MINIMUM_PRIORITY,
+    RTEMS_MINIMUM_STACK_SIZE,
+    RTEMS_NO_PREEMPT,
+    RTEMS_DEFAULT_ATTRIBUTES,
+    &id
+  rtems_test_assert(sc == RTEMS_UNSATISFIED);
 static void Init(rtems_task_argument arg)
@@ -55,7 +70,7 @@ static void Init(rtems_task_argument arg)
 #define CONFIGURE_SMP_MAXIMUM_PROCESSORS 1
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS 2
1.7.7
