alarm()
Fri Jul 19 16:06:21 UTC 2013
On 7/19/2013 10:21 AM, Sebastian Huber wrote:
> Hello,
> should it be possible to use alarm() from interrupt context?  There are some
> race conditions in this function I need to fix.
I personally don't think it makes sense to use it from an ISR.
If you want to return an error for that case, I think it is OK.
It is certainly beyond anything the POSIX standard addresses.
