[PATCH] add freelist data structure to score
Ashi ashi08104 at gmail.com
Sun Jul 21 13:51:04 UTC 2013
On Fri, Jul 19, 2013 at 5:33 PM, Ashi <ashi08104 at gmail.com> wrote:
> On Fri, Jul 19, 2013 at 3:00 PM, Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> Hallo Ashi,
>> this looks good.  Thanks for test cases.  Is it possible that you
>> integrate everything in one test application, e.g. different test cases in
>> different functions?
> Yeah, I was also thinking about it. I think one test should be more
> compact. And it should be done easily.
>> Maybe we should use _Freechain_Get() and _Freechain_Put() to make the
>> function name a bit shorter?
> OK, I will update it shortly.
>> Hi, all. I've update the patch by following changes:
  - squash 3 test cases into 1
  - rename _Freechain_Get_node() and _Freechain_Put_node() to
_Freechain_Get() and _Freechain_Put().
And here is this patch's github url:
Cheers,
Zhongwei
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130721/825e2132/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130721/825e2132/attachment-0001.obj>
