[PATCH] Updated Legacy code in i386 pc386
Vipul Nayyar
nayyar_vipul at yahoo.com
Wed Jul 24 12:11:09 UTC 2013
Hello Peter,
Thanks for the heads up. I put the cast their initially because the compiler gave me a warning that interrupt handler install function argument 4 requires a rtems_interrupt_handler type.
So can you tell me, what is the right way to go about this ? What kind of problems can be caused ? How do I make sure that I'm actually fixing that part of code ?
Regards
Vipul Nayyar
________________________________
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: Sebastian Huber <sebastian.huber at embedded-brains.de>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Wednesday, 24 July 2013 5:15 PM
Subject: Re: [PATCH] Updated Legacy code in i386 pc386
On Jul 24, 2013, at 06:08 , Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
I put (rtems_interrupt_handler) casts because I was getting warnings. After I removed them now, I think it's working fine. Don't know how.ecaus
Be extremely careful about using casting to eliminate compiler warnings. That can just cause problems to be hidden instead of fixed.
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130724/19f908f1/attachment-0001.html>
