[PATCH] Updated Legacy code in i386 pc386
Vipul Nayyar
nayyar_vipul at yahoo.com
Fri Jul 26 13:25:11 UTC 2013
Hello,
I removed an empty line at the end in the pc386 patch file, when it was generated. Can you add an empty line at the end and try again?
Worked for me while testing it on another RTEMS repository. Otherwise I'll send it again with the same git send-email method.
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: Joel Sherrill <joel.sherrill at oarcorp.com>; "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Friday, 26 July 2013 4:51 PM
Subject: Re: [PATCH] Updated Legacy code in i386 pc386
Hello Vipul,
I had no problems with your other patches, but this one yields:
git apply pc386.patch
error: patch failed: c/src/lib/libbsp/i386/pc386/clock/ckinit.c:275
error: c/src/lib/libbsp/i386/pc386/clock/ckinit.c: patch does not apply
error: patch failed: c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c:429
error: c/src/lib/libbsp/i386/pc386/console/ps2_mouse.c: patch does not apply
error: patch failed: c/src/lib/libbsp/i386/pc386/console/vgacons.c:1
error: c/src/lib/libbsp/i386/pc386/console/vgacons.c: patch does not apply
error: patch failed: c/src/lib/libbsp/i386/pc386/include/bsp.h:134
error: c/src/lib/libbsp/i386/pc386/include/bsp.h: patch does not apply
error: patch failed: c/src/lib/libbsp/i386/shared/smp/smp-imps.c:120
error: c/src/lib/libbsp/i386/shared/smp/smp-imps.c: patch does not apply
I already committed the latest ARM patch from you.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130726/74611f50/attachment-0001.html>
