Short term SMP fixes
Fri Jul 26 16:17:44 UTC 2013
On 7/26/2013 7:17 AM, Chris Johns wrote:
> Sebastian Huber wrote:
>> What about xyzapi.h, xyzcore.h and xyzimpl.h?
> I think xyzcore.h is ok but I do not like xyzapi.h. I feel the 'api'
> part in this case is implicit. For example in user code you see would:
>    #include <xyz.h>
> and not:
>    #include <xyzapi.h>
> because it is implicit a user would only be accessing the API. The
> standard C library is the same with <string.h> rather than
> <stringapi.h>. The C++ std is another example.
> Currently we are forced to have other names. Boost uses directories such
> impl which is nice because it avoids things like 'armdmacorecore.h'
> happening. I think stdc++v3 has bits or something like that.
I would rather add a subdirectory which indicates they are internal
implementation.
> Chris
> rtems-devel mailing list
> rtems-devel at rtems.org
