ESA SOCIS - Fault injection tools topic
Krzysztof Mięsowicz
krzysztof.miesowicz at gmail.com
Mon Jul 29 20:09:58 UTC 2013
Thank you for all replies very much.
I read about libfiu and it seems really interesting and I believe it can be
quite easy applied to RTEMS testing. I hope so :)
According to Joel's mail:
*Another area which we need help in is the coverage and testing
scripts. The coverage reporting really should be by directory or
capability. It is now reported in "lumps" that are too large.
Also rewriting as much of this as possible in Python including the
sim-scripts is highly desirable.*
Do you mean that coverage reporting framework should be rewrited and
reports should be generated for source directories instead of core and
developmental parts (as it is done now) ?
And what particularly do you mean by "rewriting as much of THIS as
possible" - do you mean all coverage reporting scripts which is now written
as bash scripts? Do I understand you correctly?
Greetings,
Krzysiek
2013/7/29 Rempel, Cynthia <cynt6007 at vandals.uidaho.edu>
> Hi,
> Did a quick write-up on the fault-injection open-project...
> http://blitiri.com.ar/p/libfiu/ looks interesting... (the python bindings
> have been Debian packaged)
> it would probably need to be evaluated more thoroughly as part of the
> project though...
> Thanks,
> Cindy
> ________________________________________
> From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on
> behalf of Rempel, Cynthia [cynt6007 at vandals.uidaho.edu]
> Sent: Monday, July 29, 2013 9:06 AM
> To: Joel Sherrill; Gedare Bloom
> Cc: Krzysztof Mięsowicz; rtems-devel at rtems.org
> Subject: RE: ESA SOCIS - Fault injection tools topic
> Hi,
> Thanks for the link! This will be helpful with fleshing out the project...
> Yes, the initial idea was to get a tool the RTEMS development community
> could use to help with certification efforts...
> and having the certification report would be very helpful...
> Given this information, we can start to write an open-project page for
> this...
> The criteria we typically use for evaluating other projects are:
> 1. Free and open source (usually modified BSD or special exception GPLv2,
> but as this is testing GPL would be fine)
> 2. Works under Linux and Windows
> 3. Still under maintainence
> Thanks!
> Cindy
> behalf of Joel Sherrill [joel.sherrill at OARcorp.com]
> Sent: Monday, July 29, 2013 8:23 AM
> To: Gedare Bloom
> Subject: Re: ESA SOCIS - Fault injection tools topic
> If I forgot the link:
> ftp://www.rtems.org/pub/rtems/esa_validation_report_450/
> On 7/29/2013 9:45 AM, Gedare Bloom wrote:
> > This seems like a good project. Ballista looks like it is "dead"
> > upstream. You'll want to scope your project to decide what / how much
> > of RTEMS you can reasonably instrument with fault injection. I also
> > wonder if it would be sensible to first start with a tool that can
> > support test input "fuzzing", which is related to but somewhat
> > different than fault injection. I think "fuzzing" is more
> > appropriately related to test coverage /testing, whereas fault
> > injection can include also non-valid inputs and faults, such as
> > flipping bits in code or modifying values on-the-fly.
> > On Mon, Jul 29, 2013 at 4:25 AM, Krzysztof Mięsowicz
> > <krzysztof.miesowicz at gmail.com> wrote:
> >> Hi!
> >> My name is Krzysiek. I participated in ESA SOCIS 2012 for RTEMS and
> worked
> >> on improving test coverage. I'm interested in participating in this
> edition
> >> of SOCIS again.
> >> I browse Open Projects page of RTEMS and I have question about topic
> related
> >> to fault injection tools. Have you any tips or suggestions to this topic
> >> (especially which tools are most desired or promising and how this
> project
> >> should look in details).
> >> I googled a bit about fault injection and free tools and find some:
> >> Ballista, LFI, Fuzz, or JACA which potentially could be applied to RTEMS
> >> testing. But I'm looking forward to any tips or thoughts from you and
> >> additionaly is it possible to be selected again this year.
> >> Thanks in advance for your replies.
> >> Krzysiek Mięsowicz
> >> _______________________________________________
> >> rtems-devel mailing list
> >> http://www.rtems.org/mailman/listinfo/rtems-devel
> Joel Sherrill, Ph.D. Director of Research & Development
> joel.sherrill at OARcorp.com On-Line Applications Research
> Ask me about RTEMS: a free RTOS Huntsville AL 35805
> Support Available (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130729/fb9e5a56/attachment-0001.html>
