CONFIGURE_NUMBER_OF_DYNAMIC_DRIVERS in conf.t
Tue Jul 30 15:13:53 UTC 2013
On 7/30/2013 10:08 AM, Shubham Somani wrote:
> Hi,
> Currently we can get the maximum number of drivers using
> sizeof(ARRAY)/sizeof(ELEMENT) by default. But these are only for the
> static drivers.
> Should we add a new macro in conf.t for
> CONFIGURE_NUMBER_OF_DYNAMIC_DRIVERS in case the user wishes for more?
FWIW I suggested this. currently if the user wants to have
dynamically installed drivers, they have to define
CONFIGURE_MAXIMUM_DRIVERS to be greater than the
number of statically configured device drivers.
This would make a logical distinction between the number
of static and dynamic drivers.
I might also be prone to obsolete CONFIGURE_MAXIMUM_DRIVERS.
Add code to give the user an error with instructions.
> Cheers,
> Shubham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130730/06bf2815/attachment-0001.html>
