[PATCH 2/2] smp: Provide cache optimized Per_CPU_Control
Sebastian Huber
Tue Jul 30 15:44:23 UTC 2013
Delete _Per_CPU_Initialize_p.
c/src/lib/libbsp/i386/shared/irq/irq_asm.S | 5 ++-
c/src/lib/libbsp/sparc/shared/irq_asm.S | 23 +++++++-------
cpukit/sapi/include/confdefs.h | 3 +-
cpukit/score/include/rtems/score/percpu.h | 45 +++++++++++++++++++--------
cpukit/score/src/percpu.c | 5 +--
5 files changed, 48 insertions(+), 33 deletions(-)
diff --git a/c/src/lib/libbsp/i386/shared/irq/irq_asm.S b/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
index 2b16234..bbc1afb 100644
--- a/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
+++ b/c/src/lib/libbsp/i386/shared/irq/irq_asm.S
@@ -99,9 +99,10 @@ SYM (_ISR_Handler):
.check_stack_switch:
movl esp, ebp /* ebp = previous stack pointer */
#if defined(RTEMS_SMP) && defined(BSP_HAS_SMP)
- movl $SYM(_Per_CPU_Information_p), ebx
call SYM(_CPU_SMP_Get_current_processor)
- mov (ebx,eax,4), ebx
+ sall $PER_CPU_CONTROL_SIZE_LOG2, eax
+ addl $SYM(_Per_CPU_Information), eax
+ movl eax, ebx
pushl ecx
call SYM(_ISR_SMP_Enter)
popl ecx
diff --git a/c/src/lib/libbsp/sparc/shared/irq_asm.S b/c/src/lib/libbsp/sparc/shared/irq_asm.S
index 5fb6a67..eb2f9c5 100644
--- a/c/src/lib/libbsp/sparc/shared/irq_asm.S
+++ b/c/src/lib/libbsp/sparc/shared/irq_asm.S
@@ -255,16 +255,18 @@ dont_fix_pil2:
SYM(_ISR_PER_CPU):
- sethi %hi(_Per_CPU_Information_p), %l5
- add %l5, %lo(_Per_CPU_Information_p), %l5
+ sethi %hi(_Per_CPU_Information), %l5
+ add %l5, %lo(_Per_CPU_Information), %l5
#if BSP_LEON3_SMP
/* LEON3 SMP support */
rd %asr17, %l7
srl %l7, 28, %l7 /* CPU number is upper 4 bits so shift */
- sll %l7, 2, %l7 /* l7 = offset */
- add %l5, %l7, %l5
+ #else
+ mov 0, %l7
+ nop
#endif
- ld [%l5], %l5 /* l5 = pointer to per CPU */
+ sll %l7, PER_CPU_CONTROL_SIZE_LOG2, %l7 /* l7 = offset */
+ add %l5, %l7, %l5 /* l5 = pointer to per CPU */
* On multi-core system, we need to use SMP safe versions
@@ -456,19 +458,18 @@ isr_dispatch:
- ld [%l5 + %lo(_Per_CPU_Information_p)], %l5
#if BSP_LEON3_SMP
rd %asr17, %l7
- add %l5, %l7, %l5
#else
- nop
+ mov 0, %l7
nop
#endif
#else
diff --git a/cpukit/sapi/include/confdefs.h b/cpukit/sapi/include/confdefs.h
index c969fa7..ed1385a 100644
--- a/cpukit/sapi/include/confdefs.h
+++ b/cpukit/sapi/include/confdefs.h
@@ -2396,8 +2396,7 @@ const rtems_libio_helper rtems_fs_init_helper =
* Instantiate the Per CPU information based upon the user configuration.
#if defined(CONFIGURE_INIT)
- Per_CPU_Control _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
- Per_CPU_Control *_Per_CPU_Information_p[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
+ Per_CPU_Control_envelope _Per_CPU_Information[CONFIGURE_SMP_MAXIMUM_PROCESSORS];
#endif
#endif
diff --git a/cpukit/score/include/rtems/score/percpu.h b/cpukit/score/include/rtems/score/percpu.h
index 11ba5f6..9b6866f 100644
--- a/cpukit/score/include/rtems/score/percpu.h
+++ b/cpukit/score/include/rtems/score/percpu.h
@@ -33,6 +33,17 @@
extern "C" {
#endif
+#if defined( RTEMS_SMP )
+ * This ensures that on SMP configurations the individual per-CPU controls
+ * are on different cache lines to prevent false sharing. This define can be
+ * used in assmbler code to easily get the per-CPU control for a particular
+ * processor.
+ #define PER_CPU_CONTROL_SIZE_LOG2 7
+ #define PER_CPU_CONTROL_SIZE ( 1 << PER_CPU_CONTROL_SIZE_LOG2 )
+#endif
#if !defined( ASM )
#ifndef __THREAD_CONTROL_DEFINED__
@@ -184,32 +195,47 @@ typedef struct {
#endif
} Per_CPU_Control;
+typedef struct {
+ Per_CPU_Control per_cpu;
+ char unused_space_for_cache_line_alignment
+ [ PER_CPU_CONTROL_SIZE - sizeof( Per_CPU_Control ) ];
+} Per_CPU_Control_envelope;
+#else
+typedef struct {
+#endif
* @brief Set of Per CPU Core Information
* This is an array of per CPU core information.
-extern Per_CPU_Control _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
+extern Per_CPU_Control_envelope _Per_CPU_Information[] CPU_STRUCTURE_ALIGNMENT;
static inline Per_CPU_Control *_Per_CPU_Get( void )
_Assert_Thread_dispatching_repressed();
- return &_Per_CPU_Information[ _SMP_Get_current_processor() ];
+ return &_Per_CPU_Information[ _SMP_Get_current_processor() ].per_cpu;
#else
-#define _Per_CPU_Get() ( &_Per_CPU_Information[ 0 ] )
+#define _Per_CPU_Get() ( &_Per_CPU_Information[ 0 ].per_cpu )
#endif
static inline Per_CPU_Control *_Per_CPU_Get_by_index( uint32_t index )
- return &_Per_CPU_Information[ index ];
+ return &_Per_CPU_Information[ index ].per_cpu;
static inline uint32_t _Per_CPU_Get_index( const Per_CPU_Control *per_cpu )
- return ( uint32_t ) ( per_cpu - &_Per_CPU_Information[ 0 ] );
+ const Per_CPU_Control_envelope *per_cpu_envelope =
+ ( const Per_CPU_Control_envelope * ) per_cpu;
+ return ( uint32_t ) ( per_cpu_envelope - &_Per_CPU_Information[ 0 ] );
@@ -220,15 +246,6 @@ static inline void _Per_CPU_Send_interrupt( const Per_CPU_Control *per_cpu )
- * @brief Set of Pointers to Per CPU Core Information
- * This is an array of pointers to each CPU's per CPU data structure.
- * It should be simpler to retrieve this pointer in assembly language
- * that to calculate the array offset.
-extern Per_CPU_Control *_Per_CPU_Information_p[];
* @brief Initialize SMP Handler
* This method initialize the SMP Handler.
diff --git a/cpukit/score/src/percpu.c b/cpukit/score/src/percpu.c
index 5e1a917..b041b45 100644
--- a/cpukit/score/src/percpu.c
+++ b/cpukit/score/src/percpu.c
@@ -39,13 +39,10 @@
* Initialize per cpu pointer table
- _Per_CPU_Information_p[0] = _Per_CPU_Get_by_index( 0 );
for ( cpu = 1 ; cpu < max_cpus; ++cpu ) {
Per_CPU_Control *p = _Per_CPU_Get_by_index( cpu );
- _Per_CPU_Information_p[cpu] = p;
#if CPU_ALLOCATE_INTERRUPT_STACK == TRUE
size_t size = rtems_configuration_get_interrupt_stack_size();
@@ -101,5 +98,5 @@
* statically allocated per cpu structure. And the fields are initialized
* as individual elements just like it has always been done.
- Per_CPU_Control _Per_CPU_Information[1];
+ Per_CPU_Control_envelope _Per_CPU_Information[1];
#endif
1.7.7
