[PATCH 4/5] score: Move nanoseconds since last tick support
Wed Jul 31 13:15:13 UTC 2013
Move the nanoseconds since last tick support from the Watchdog to the
TOD handler.  Now the TOD managment is encapsulated in the TOD_Control
structure.
 cpukit/rtems/include/rtems/rtems/clock.h        |    3 +-
 cpukit/rtems/src/clocksetnsecshandler.c         |   22 ++----------
 cpukit/score/Makefile.am                        |    4 +-
 cpukit/score/include/rtems/score/tod.h          |   41 +++++++++++++++++++++++
 cpukit/score/include/rtems/score/todimpl.h      |   16 ++++++++-
 cpukit/score/include/rtems/score/watchdog.h     |    9 -----
 cpukit/score/include/rtems/score/watchdogimpl.h |   16 ---------
 cpukit/score/preinstall.am                      |    4 ++
 cpukit/score/src/coretod.c                      |   18 +++++++---
 cpukit/score/src/coretodget.c                   |    4 +-
 cpukit/score/src/watchdognanoseconds.c          |   36 --------------------
 11 files changed, 82 insertions(+), 91 deletions(-)
 create mode 100644 cpukit/score/include/rtems/score/tod.h
 delete mode 100644 cpukit/score/src/watchdognanoseconds.c
diff --git a/cpukit/rtems/include/rtems/rtems/clock.h b/cpukit/rtems/include/rtems/rtems/clock.h
index 3c32ccd..ec8d8f8 100644
--- a/cpukit/rtems/include/rtems/rtems/clock.h
+++ b/cpukit/rtems/include/rtems/rtems/clock.h
@@ -31,6 +31,7 @@
 #define _RTEMS_RTEMS_CLOCK_H
+#include <rtems/score/tod.h>
@@ -68,7 +69,7 @@ typedef enum {
  *  Type for the nanoseconds since last tick BSP extension.
-typedef Watchdog_Nanoseconds_since_last_tick_routine
+typedef TOD_Nanoseconds_since_last_tick_routine
   rtems_nanoseconds_extension_routine;
diff --git a/cpukit/rtems/src/clocksetnsecshandler.c b/cpukit/rtems/src/clocksetnsecshandler.c
index 25c0ad7..5c50af1 100644
--- a/cpukit/rtems/src/clocksetnsecshandler.c
+++ b/cpukit/rtems/src/clocksetnsecshandler.c
@@ -18,26 +18,9 @@
 #include "config.h"
 #endif
-#include <rtems/system.h>
-#include <rtems/rtems/status.h>
 #include <rtems/rtems/clock.h>
-#include <rtems/score/isr.h>
-#include <rtems/score/thread.h>
-#include <rtems/score/watchdogimpl.h>
+#include <rtems/score/todimpl.h>
- *  rtems_clock_set_nanoseconds_extension
- *  This directive sets the BSP provided nanoseconds since last tick
- *  extension.
- *  Input parameters:
- *    routine - pointer to the extension routine
- *  Output parameters:
- *    RTEMS_SUCCESSFUL - if successful
- *    error code        - if unsuccessful
 rtems_status_code rtems_clock_set_nanoseconds_extension(
   rtems_nanoseconds_extension_routine routine
@@ -45,6 +28,7 @@ rtems_status_code rtems_clock_set_nanoseconds_extension(
   if ( !routine )
     return RTEMS_INVALID_ADDRESS;
-  _Watchdog_Nanoseconds_since_tick_handler = routine;
+  _TOD_Set_nanoseconds_since_last_tick_handler( routine );
   return RTEMS_SUCCESSFUL;
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 015b230..e300c3e 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -70,6 +70,7 @@ include_rtems_score_HEADERS += include/rtems/score/threadsync.h
 include_rtems_score_HEADERS += include/rtems/score/timespec.h
 include_rtems_score_HEADERS += include/rtems/score/timestamp.h
 include_rtems_score_HEADERS += include/rtems/score/timestamp64.h
+include_rtems_score_HEADERS += include/rtems/score/tod.h
 include_rtems_score_HEADERS += include/rtems/score/todimpl.h
 include_rtems_score_HEADERS += include/rtems/score/userext.h
 include_rtems_score_HEADERS += include/rtems/score/userextimpl.h
@@ -305,8 +306,7 @@ libscore_a_SOURCES += src/coretod.c src/coretodset.c src/coretodget.c \
 ## WATCHDOG_C_FILES
 libscore_a_SOURCES += src/watchdog.c src/watchdogadjust.c \
     src/watchdogadjusttochain.c src/watchdoginsert.c src/watchdogremove.c \
-    src/watchdogtickle.c src/watchdogreport.c src/watchdogreportchain.c \
-    src/watchdognanoseconds.c
+    src/watchdogtickle.c src/watchdogreport.c src/watchdogreportchain.c
 ## USEREXT_C_FILES
 libscore_a_SOURCES += src/userextaddset.c \
diff --git a/cpukit/score/include/rtems/score/tod.h b/cpukit/score/include/rtems/score/tod.h
new file mode 100644
index 0000000..57609b9
--- /dev/null
+++ b/cpukit/score/include/rtems/score/tod.h
@@ -0,0 +1,41 @@
+ * @file
+ * @ingroup ScoreTOD
+ * @brief Time of Day Handler API
+ *  COPYRIGHT (c) 1989-2009.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_SCORE_TOD_H
+#define _RTEMS_SCORE_TOD_H
+#include <rtems/score/basedefs.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @brief Returns the nanoseconds since the last clock tick.
+ * @return The nanoseconds since the last clock tick.
+typedef uint32_t ( *TOD_Nanoseconds_since_last_tick_routine )( void );
+#ifdef __cplusplus
+#endif
+#endif
+/* end of include file */
diff --git a/cpukit/score/include/rtems/score/todimpl.h b/cpukit/score/include/rtems/score/todimpl.h
index 0e2da2f..a7c3e5d 100644
--- a/cpukit/score/include/rtems/score/todimpl.h
+++ b/cpukit/score/include/rtems/score/todimpl.h
@@ -18,7 +18,7 @@
 #ifndef _RTEMS_SCORE_TODIMPL_H
 #define _RTEMS_SCORE_TODIMPL_H
-#include <rtems/score/basedefs.h>
 #include <rtems/score/timestamp.h>
 #include <sys/time.h>
@@ -149,6 +149,13 @@ typedef struct {
   uint32_t seconds_trigger;
+   * @brief The current nanoseconds since last tick handler.
+   * This field must not be NULL after initialization.
+  TOD_Nanoseconds_since_last_tick_routine nanoseconds_since_last_tick;
    *  @brief Indicates if the time of day is set.
    *  This is true if the application has set the current
@@ -300,6 +307,13 @@ RTEMS_INLINE_ROUTINE void _TOD_Get_timeval(
   _Timestamp_To_timeval( snapshot_as_timestamp_ptr, time );
+RTEMS_INLINE_ROUTINE void _TOD_Set_nanoseconds_since_last_tick_handler(
+  TOD_Nanoseconds_since_last_tick_routine routine
+  _TOD.nanoseconds_since_last_tick = routine;
 RTEMS_INLINE_ROUTINE bool _TOD_Is_set( void )
   return _TOD.is_set;
diff --git a/cpukit/score/include/rtems/score/watchdog.h b/cpukit/score/include/rtems/score/watchdog.h
index b67e5ca..bd218fd 100644
--- a/cpukit/score/include/rtems/score/watchdog.h
+++ b/cpukit/score/include/rtems/score/watchdog.h
@@ -64,15 +64,6 @@ typedef Watchdog_Service_routine ( *Watchdog_Service_routine_entry )(
- *  @brief Pointer to the BSP plugin to obtain the number
- *  of nanoseconds since the last clock tick.
- *  This type defines a pointer to the BSP plugin to obtain the number
-typedef uint32_t (*Watchdog_Nanoseconds_since_last_tick_routine)(void);
  *  @brief The constant for indefinite wait.
  *  This is the constant for indefinite wait.  It is actually an
diff --git a/cpukit/score/include/rtems/score/watchdogimpl.h b/cpukit/score/include/rtems/score/watchdogimpl.h
index 3085a44..faf68fa 100644
--- a/cpukit/score/include/rtems/score/watchdogimpl.h
+++ b/cpukit/score/include/rtems/score/watchdogimpl.h
@@ -93,15 +93,6 @@ SCORE_EXTERN volatile uint32_t    _Watchdog_Sync_count;
 SCORE_EXTERN volatile Watchdog_Interval _Watchdog_Ticks_since_boot;
- *  @brief The number of nanoseconds since the last clock tick.
- *  This is a pointer to the optional BSP plugin to obtain the number
-extern Watchdog_Nanoseconds_since_last_tick_routine
-  _Watchdog_Nanoseconds_since_tick_handler;
  *  @brief Watchdog chain which is managed at ticks.
  *  This is the watchdog chain which is managed at ticks.
@@ -245,13 +236,6 @@ void _Watchdog_Report_chain(
- * @brief Handler for default nanoseconds since last tick.
- * @retval 0 Always.
-uint32_t _Watchdog_Nanoseconds_since_tick_default_handler( void );
  * This routine initializes the specified watchdog.  The watchdog is
  * made inactive, the watchdog id and handler routine are set to the
  * specified values.
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index 6d0cb81..80fad5b 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -263,6 +263,10 @@ $(PROJECT_INCLUDE)/rtems/score/timestamp64.h: include/rtems/score/timestamp64.h
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/timestamp64.h
+$(PROJECT_INCLUDE)/rtems/score/tod.h: include/rtems/score/tod.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/tod.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/tod.h
 $(PROJECT_INCLUDE)/rtems/score/todimpl.h: include/rtems/score/todimpl.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/todimpl.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/todimpl.h
diff --git a/cpukit/score/src/coretod.c b/cpukit/score/src/coretod.c
index bcdfa39..3359d4e 100644
--- a/cpukit/score/src/coretod.c
+++ b/cpukit/score/src/coretod.c
@@ -20,14 +20,22 @@
+static uint32_t _TOD_Nanoseconds_since_tick_default_handler( void )
+  return 0;
 void _TOD_Handler_initialization(void)
-  /* POSIX format TOD (timespec) */
-  _Timestamp_Set( &_TOD.now, TOD_SECONDS_1970_THROUGH_1988, 0 );
+  TOD_Control *tod = &_TOD;
+  _Timestamp_Set( &tod->now, TOD_SECONDS_1970_THROUGH_1988, 0 );
+  _Timestamp_Set_to_zero( &tod->uptime );
-  /* Uptime (timespec) */
-  _Timestamp_Set_to_zero( &_TOD.uptime );
+  tod->nanoseconds_since_last_tick =
+    _TOD_Nanoseconds_since_tick_default_handler;
   /* TOD has not been set */
-  _TOD.is_set = false;
+  tod->is_set = false;
diff --git a/cpukit/score/src/coretodget.c b/cpukit/score/src/coretodget.c
index b45930a..50262fd 100644
--- a/cpukit/score/src/coretodget.c
+++ b/cpukit/score/src/coretodget.c
@@ -20,20 +20,20 @@
 #include <rtems/score/isrlevel.h>
 Timestamp_Control *_TOD_Get_with_nanoseconds(
   Timestamp_Control *snapshot,
   const Timestamp_Control *clock
   ISR_Level         level;
   Timestamp_Control offset;
   Timestamp_Control now;
   uint32_t          nanoseconds;
   _ISR_Disable( level );
-    nanoseconds = (*_Watchdog_Nanoseconds_since_tick_handler)();
+    nanoseconds = ( *tod->nanoseconds_since_last_tick )();
     now = *clock;
   _ISR_Enable( level );
diff --git a/cpukit/score/src/watchdognanoseconds.c b/cpukit/score/src/watchdognanoseconds.c
deleted file mode 100644
index 9c25239..0000000
--- a/cpukit/score/src/watchdognanoseconds.c
+++ /dev/null
@@ -1,36 +0,0 @@
- *  @file
- *  @brief Default Nanoseconds Since Last Tick Handler
- *  @ingroup ScoreWatchdog
- * Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Obere Lagerstr. 30
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.com/license/LICENSE.
-#if HAVE_CONFIG_H
-#include "config.h"
-#endif
-Watchdog_Nanoseconds_since_last_tick_routine
-    _Watchdog_Nanoseconds_since_tick_default_handler;
-  return 0;
1.7.7
