[PATCH 2/9] fsdosfsname01: New test
Chris Johns
chrisj at rtems.org
Sun Jun 2 23:49:56 UTC 2013
Ralf Kirchner wrote:
> Test handling of file names and directory names according to Microsofts
> specification for the FAT file system. So far tested only for the
> default character set (code page 850).
Is the default character set the same as before in terms of functionality ?
+static void mount_device( const char *start_dir,
+ const rtems_dosfs_mount_options *mount_opts )
> + if ( NULL == opendir( start_dir ) ) {
This is not closed if the dir is present. Why not use a stat or just
mkdir and check the result ?
