[PATCH 8/9] fsdsosfsname01: Ensure endian correctness
    Rempel, Cynthia
    cynt6007 at vandals.uidaho.edu
    Tue Jun  4 15:33:38 UTC 2013
Hi Ralf Kirchner,
Thanks for the clarification!
Yes, it sounds like we need to keep testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h...
With the comment
WARNING: Automatically generated by init.c if PRINT_DISK_IMAGE != 0 -- do not edit!
hopefully we would know how to regenerate the file if any changes in the underlying system are made.
Probably not useful for this application, but the network-demos have an application that generates a filesystem image...
http://git.rtems.org/network-demos/tree/http/Makefile
Thanks again for making the change to the comment!
Cindy
________________________________________
From: rtems-devel-bounces at rtems.org [rtems-devel-bounces at rtems.org] on behalf of Ralf Kirchner [ralf.kirchner at embedded-brains.de]
Sent: Tuesday, June 04, 2013 1:21 AM
To: rtems-devel at rtems.org
Subject: Re: [PATCH 8/9] fsdsosfsname01: Ensure endian correctness
Forgot an important point below.
Kind Regards
        Ralf Kirchner
Am 04.06.2013 10:08, schrieb Ralf Kirchner:
> Hi Cynthia,
> Please see my replies below.
> Kind Regards
>       Ralf Kirchner
> Am 03.06.2013 16:55, schrieb Rempel, Cynthia:
>>>> On 05/31/2013 03:42 PM, Ralf Kirchner wrote:
>>>>> diff --git a/testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h
>>>>> b/testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h
>>>>> + *  Declarations for C structure representing a disk image
>>>>> + *  WARNING: Automatically generated -- do not edit!
>>>>> +#ifndef IMAGE_BIN_LE_MULTIBYTE_H_
>>>>> +#define IMAGE_BIN_LE_MULTIBYTE_H_
>>>> AFAIU, this code qualifies is a hex dump of some binary, seemingly having been
>>>> generated by some seemingly unfree tool.
>>> It is generated from init.c if PRINT_DISK_IMAGE != 0.
>> Thanks Sebastian for the clarification :)
>> Could a rule in the Makefile.am be added to generate testsuites/fstests/fsdosfsname01/image_bin_le_multibyte.h and then not include the file in the repo?
>> If the file is needed for comparing a new build vs. the working build (for testing purposed), then it makes sense to keep image_bin_le_multibyte.h...
> The problem is that from within the test (running on a simulator like
> SIS) we do not have access to the file system of the PC on which the
> test gets executed. This is why the current handling is:
> If PRINT_DISK_IMAGE != 0, print the disk images to the console and from
> there copy them manually into the header files.
> It might be possible to activate this from the Makefile but due to the
> missing file system access it would still remain a semi-automatic
> process. This is why I did not take the time to investigate further into
> activating this from the Makefile.
Purpose of this images is to ensure that we are endian correct. Thus the
images get created ONLY on a little endian target. Then on the target to
be tested the test generates the same image in a RAM file system and
compares it against the saved images from the header files.
>> Could the line
>> be changed to
>> + *  WARNING: Automatically generated by init.c if PRINT_DISK_IMAGE != 0 -- do not edit!
> I already did that ;-)
>>>> => In this shape this code violates the RTEMS license and may not be applied to
>>>> RTEMS.
>>>> Please reimplement this by using free tools.
>>> So if I use notepad.exe on Windows to write RTEMS source code I violate the
>>> RTEMS license?
>> I suspect there was a little confusion on how the file was generated, but it appears Sebastian cleared that up quite well.
>> Cindy
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-devel mailing list
>> http://www.rtems.org/mailman/listinfo/rtems-devel
Embedded Brains GmbH
Ralf Kirchner          Dornierstr. 4
D-82178 Puchheim       Germany
email: ralf.kirchner at embedded-brains.de
Phone: +49-89-18 94 741-17
Fax:   +49-89-18 94 741-08
