[PATCH 7/9] score: Align _Objects_Get_isr_disable()
Wed Jun 5 15:22:05 UTC 2013
Align ISR disable/enable sequence in _Objects_Get_isr_disable() with
thread dispatch disable/enable sequence in _Objects_Get().
 cpukit/score/src/objectgetisr.c |    3 +--
 1 files changed, 1 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/src/objectgetisr.c b/cpukit/score/src/objectgetisr.c
index 4a281c2..9eeee3c 100644
--- a/cpukit/score/src/objectgetisr.c
+++ b/cpukit/score/src/objectgetisr.c
@@ -43,8 +43,8 @@ Objects_Control *_Objects_Get_isr_disable(
   index = id - information->minimum_id + 1;
-  _ISR_Disable( level );
   if ( information->maximum >= index ) {
+    _ISR_Disable( level );
     if ( (the_object = information->local_table[ index ]) != NULL ) {
       *location = OBJECTS_LOCAL;
       *level_p = level;
@@ -54,7 +54,6 @@ Objects_Control *_Objects_Get_isr_disable(
     *location = OBJECTS_ERROR;
     return NULL;
-  _ISR_Enable( level );
 #if defined(RTEMS_MULTIPROCESSING)
1.7.7
