[PATCH 8/9] score: Add _Objects_Release_for_get_isr_disable()
Thu Jun 6 13:41:32 UTC 2013
I don't understand the name of the function. What do you intend to say
with "Release_for_get_isr_disable"?
-Gedare
On Wed, Jun 5, 2013 at 11:22 AM, Sebastian Huber
> Provide SMP support.  The ISR disable/enable is not enough to ensure
> mutual exclusion for SMP configurations.
>  cpukit/posix/src/mutexlocksupp.c           |    1 +
>  cpukit/rtems/src/semobtain.c               |    2 ++
>  cpukit/score/inline/rtems/score/object.inl |   14 ++++++++++++++
>  cpukit/score/src/objectgetisr.c            |    6 ++++++
>  4 files changed, 23 insertions(+), 0 deletions(-)
> diff --git a/cpukit/posix/src/mutexlocksupp.c b/cpukit/posix/src/mutexlocksupp.c
> index 0a35e3c..5090c91 100644
> --- a/cpukit/posix/src/mutexlocksupp.c
> +++ b/cpukit/posix/src/mutexlocksupp.c
> @@ -59,6 +59,7 @@ int _POSIX_Mutex_Lock_support(
>          timeout,
>          level
> +      _Objects_Release_for_get_isr_disable( &the_mutex->Object );
>        return _POSIX_Mutex_Translate_core_mutex_return_code(
>          (CORE_mutex_Status) _Thread_Executing->Wait.return_code
> diff --git a/cpukit/rtems/src/semobtain.c b/cpukit/rtems/src/semobtain.c
> index 14ed515..bf8bab2 100644
> --- a/cpukit/rtems/src/semobtain.c
> +++ b/cpukit/rtems/src/semobtain.c
> @@ -60,6 +60,7 @@ rtems_status_code rtems_semaphore_obtain(
>            timeout,
>            level
> +        _Objects_Release_for_get_isr_disable( &the_semaphore->Object );
>          return _Semaphore_Translate_core_mutex_return_code(
>                    _Thread_Executing->Wait.return_code );
> @@ -72,6 +73,7 @@ rtems_status_code rtems_semaphore_obtain(
>          timeout,
>          level
>        return _Semaphore_Translate_core_semaphore_return_code(
> diff --git a/cpukit/score/inline/rtems/score/object.inl b/cpukit/score/inline/rtems/score/object.inl
> index efdb23d..26ae085 100644
> --- a/cpukit/score/inline/rtems/score/object.inl
> +++ b/cpukit/score/inline/rtems/score/object.inl
> @@ -375,4 +375,18 @@ RTEMS_INLINE_ROUTINE bool _Objects_Is_unlimited( uint32_t maximum )
>    ((Objects_Maximum) ((maximum) & ~OBJECTS_UNLIMITED_OBJECTS))
>  #endif
> + * @brief Releases an object obtained with _Objects_Get_isr_disable().
> +RTEMS_INLINE_ROUTINE void _Objects_Release_for_get_isr_disable(
> +  Objects_Control *the_object
> +  (void) the_object;
> +#if defined(RTEMS_SMP)
> +  _Thread_Enable_dispatch();
> +#endif
>  /* end of include file */
> diff --git a/cpukit/score/src/objectgetisr.c b/cpukit/score/src/objectgetisr.c
> index 9eeee3c..56f7471 100644
> --- a/cpukit/score/src/objectgetisr.c
> +++ b/cpukit/score/src/objectgetisr.c
> @@ -44,6 +44,9 @@ Objects_Control *_Objects_Get_isr_disable(
>    index = id - information->minimum_id + 1;
>    if ( information->maximum >= index ) {
> +    _Thread_Disable_dispatch();
> +#endif
>      _ISR_Disable( level );
>      if ( (the_object = information->local_table[ index ]) != NULL ) {
>        *location = OBJECTS_LOCAL;
> @@ -51,6 +54,9 @@ Objects_Control *_Objects_Get_isr_disable(
>        return the_object;
>      _ISR_Enable( level );
> +#endif
>      *location = OBJECTS_ERROR;
>      return NULL;
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
