[PATCH 2/9] rtems: Add interrupt locks
Mon Jun 10 13:11:50 UTC 2013
Interrupt locks are low-level lock to protect critical sections accessed
by threads and interrupt service routines.
 cpukit/rtems/include/rtems/rtems/intr.h |  135 +++++++++++++++++++++++++++++++
 testsuites/sptests/sp37/init.c          |   17 ++++
 2 files changed, 152 insertions(+), 0 deletions(-)
diff --git a/cpukit/rtems/include/rtems/rtems/intr.h b/cpukit/rtems/include/rtems/rtems/intr.h
index ea6dc6b..d687e46 100644
--- a/cpukit/rtems/include/rtems/rtems/intr.h
+++ b/cpukit/rtems/include/rtems/rtems/intr.h
@@ -26,6 +26,7 @@ extern "C" {
 #endif
 #include <rtems/score/isr.h>
+#include <rtems/score/smplock.h>
  *  @defgroup ClassicINTR Interrupts
@@ -134,6 +135,140 @@ rtems_status_code rtems_interrupt_catch(
 #define rtems_interrupt_clear( _interrupt_to_clear )
+ * @defgroup ClassicINTRLocks Interrupt Locks
+ * @ingroup ClassicINTR
+ * @brief Low-level lock to protect critical sections accessed by threads and
+ * interrupt service routines.
+ * This synchronization primitive is supported on SMP configurations.
+ * @brief Interrupt lock control.
+typedef struct {
+  #if defined( RTEMS_SMP )
+    SMP_lock_Control lock;
+  #endif
+} rtems_interrupt_lock;
+ * @brief Initializer for static initialization of interrupt locks.
+#if defined( RTEMS_SMP )
+  #define RTEMS_INTERRUPT_LOCK_INITIALIZER \
+    { SMP_LOCK_INITIALIZER }
+#else
+#endif
+ * @brief Initializes an interrupt lock.
+ * Concurrent initialization leads to unpredictable results.
+  #define rtems_interrupt_lock_initialize( _lock ) \
+    _SMP_lock_Initialize( &( _lock )->lock )
+#else
+    do { \
+      (void) _lock; \
+    } while (0)
+#endif
+ * @brief Acquires an interrupt lock.
+ * Interrupts will be disabled.  On SMP configurations this function acquires a
+ * SMP lock.
+ * This function can be used in thread and interrupt context.
+ * @see rtems_interrupt_lock_release().
+  #define rtems_interrupt_lock_acquire( _lock, _isr_cookie ) \
+    _SMP_lock_ISR_disable_and_acquire( &( _lock )->lock, _isr_cookie )
+#else
+    do { \
+      (void) _lock; \
+      rtems_interrupt_disable( _isr_cookie ); \
+    } while (0)
+#endif
+ * @brief Releases an interrupt lock.
+ * The interrupt status will be restored.  On SMP configurations this function
+ * releases a SMP lock.
+ * @see rtems_interrupt_lock_acquire().
+  #define rtems_interrupt_lock_release( _lock, _isr_cookie ) \
+    _SMP_lock_Release_and_ISR_enable( &( _lock )->lock, _isr_cookie )
+#else
+    do { \
+      (void) _lock; \
+      rtems_interrupt_enable( _isr_cookie ); \
+    } while (0)
+#endif
+ * @brief Acquires an interrupt lock in the corresponding interrupt service
+ * routine.
+ * The interrupt status will remain unchanged.  On SMP configurations this
+ * function acquires a SMP lock.
+ * In case the corresponding interrupt service routine can be interrupted by
+ * higher priority interrupts and these interrupts enter the critical section
+ * protected by this lock, then the result is unpredictable.
+ * @see rtems_interrupt_lock_release_isr().
+  #define rtems_interrupt_lock_acquire_isr( _lock ) \
+    _SMP_lock_Acquire( &( _lock )->lock )
+#else
+    do { \
+      (void) _lock; \
+    } while (0)
+#endif
+ * @brief Releases an interrupt lock in the corresponding interrupt service
+ * routine.
+ * function releases a SMP lock.
+ * @see rtems_interrupt_lock_acquire_isr().
+  #define rtems_interrupt_lock_release_isr( _lock ) \
+    _SMP_lock_Release( &( _lock )->lock )
+#else
+    do { \
+      (void) _lock; \
+    } while (0)
+#endif
 #ifdef __cplusplus
 #endif
diff --git a/testsuites/sptests/sp37/init.c b/testsuites/sptests/sp37/init.c
index 870316a..956c91d 100644
--- a/testsuites/sptests/sp37/init.c
+++ b/testsuites/sptests/sp37/init.c
@@ -43,6 +43,21 @@ rtems_timer_service_routine test_isr_in_progress(
 /* test bodies */
+static void test_interrupt_locks( void )
+  rtems_interrupt_lock lock = RTEMS_INTERRUPT_LOCK_INITIALIZER;
+  rtems_interrupt_level level;
+  rtems_interrupt_lock_initialize( &lock );
+  rtems_interrupt_lock_acquire( &lock, level );
+  rtems_interrupt_lock_release( &lock, level );
+  rtems_interrupt_lock_acquire_isr( &lock );
+  rtems_interrupt_lock_release_isr( &lock );
 void test_interrupt_inline(void)
@@ -318,6 +333,8 @@ rtems_task Init(
   check_isr_worked( "body", isr_in_progress_body );
+  test_interrupt_locks();
   puts( "*** END OF TEST 37 ***" );
   rtems_test_exit( 0 );
1.7.7
