[PATCH] configure: Documentation
Mon Jun 10 13:47:08 UTC 2013
This is an improvement.
On Mon, Jun 10, 2013 at 4:11 AM, Sebastian Huber
>  aclocal/enable-multiprocessing.m4        |    4 +++-
>  aclocal/enable-smp.m4                    |    3 ++-
>  c/src/aclocal/enable-multiprocessing.m4  |    5 ++++-
>  c/src/aclocal/enable-smp.m4              |    3 ++-
>  cpukit/aclocal/enable-multiprocessing.m4 |    5 ++++-
>  cpukit/aclocal/enable-smp.m4             |    3 ++-
>  6 files changed, 17 insertions(+), 6 deletions(-)
> diff --git a/aclocal/enable-multiprocessing.m4 b/aclocal/enable-multiprocessing.m4
> index 8707c9e..53fa8ff 100644
> --- a/aclocal/enable-multiprocessing.m4
> +++ b/aclocal/enable-multiprocessing.m4
> @@ -2,7 +2,9 @@ AC_DEFUN([RTEMS_ENABLE_MULTIPROCESSING],
>  AC_ARG_ENABLE(multiprocessing,
>  [AS_HELP_STRING([--enable-multiprocessing],
> -[enable multiprocessing interface])],
> +[enable multiprocessing interface; the multiprocessing interface is a
> +communication interface between different RTEMS instances and allows
> +synchronization of objects via message passing])],
>  [case "${enable_multiprocessing}" in
>    yes) ;;
>    no) ;;
> diff --git a/aclocal/enable-smp.m4 b/aclocal/enable-smp.m4
> index 0c29a06..590a7b1 100644
> --- a/aclocal/enable-smp.m4
> +++ b/aclocal/enable-smp.m4
> @@ -3,7 +3,8 @@ AC_DEFUN([RTEMS_ENABLE_SMP],
>  ## AC_BEFORE([$0], [RTEMS_CHECK_SMP])dnl
>  AC_ARG_ENABLE(smp,
> -[AS_HELP_STRING([--enable-smp],[enable smp interface])],
> +[AS_HELP_STRING([--enable-smp],[enable support for symmetric multiprocessing
> +(SMP)])],
>  [case "${enableval}" in
>    yes) case "${RTEMS_CPU}" in
>           arm|powerpc|sparc|i386) RTEMS_HAS_SMP=yes ;;
> diff --git a/c/src/aclocal/enable-multiprocessing.m4 b/c/src/aclocal/enable-multiprocessing.m4
> index 035292f..53fa8ff 100644
> --- a/c/src/aclocal/enable-multiprocessing.m4
> +++ b/c/src/aclocal/enable-multiprocessing.m4
> @@ -1,7 +1,10 @@
> -[AS_HELP_STRING(--enable-multiprocessing,enable multiprocessing interface)],
> +[AS_HELP_STRING([--enable-multiprocessing],
>    yes) ;;
>    no) ;;
> diff --git a/c/src/aclocal/enable-smp.m4 b/c/src/aclocal/enable-smp.m4
> --- a/c/src/aclocal/enable-smp.m4
> +++ b/c/src/aclocal/enable-smp.m4
>  AC_ARG_ENABLE(smp,
> +(SMP)])],
> diff --git a/cpukit/aclocal/enable-multiprocessing.m4 b/cpukit/aclocal/enable-multiprocessing.m4
> index 3b98a67..53fa8ff 100644
> --- a/cpukit/aclocal/enable-multiprocessing.m4
> +++ b/cpukit/aclocal/enable-multiprocessing.m4
> @@ -1,7 +1,10 @@
> -AS_HELP_STRING(--enable-multiprocessing,enable multiprocessing interface),
>    yes) ;;
>    no) ;;
> diff --git a/cpukit/aclocal/enable-smp.m4 b/cpukit/aclocal/enable-smp.m4
> --- a/cpukit/aclocal/enable-smp.m4
> +++ b/cpukit/aclocal/enable-smp.m4
>  AC_ARG_ENABLE(smp,
> +(SMP)])],
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
