[Patch 1/1] Fix formatting for default values in rtems/doc/conf.t
Rempel, Cynthia cynt6007 at vandals.uidaho.edu
Wed Jun 12 15:31:29 UTC 2013
Hi,
Attached is a patch for fixing the formatting of many of the default values in the documentation.  Applying this patch will make it easier for the Application Configuration GUI to parse out the default values.
Please see:
https://github.com/shubhamsomani/GUI/
https://github.com/shubhamsomani/TUI/
Time permitting, there will be another patch to follow in the next two-three weeks fixing the formatting of the ranges, but the default values patch will need to be committed before the ranges patch could be applied...
Thanks,
Cindy
Desc: conf_t_defaults.patch
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130612/3787a822/attachment.obj>
