[Patch 1/1] Fix formatting for default values in rtems/doc/conf.t
Wed Jun 12 15:59:34 UTC 2013
I am ok with this change. If someone can commit this,
I would appreciate it.
Eventually should there be a set of comments at the
top of this file documenting the valid options?
Or (even better) an asciidoc file in this directory with
instructions?
On 6/12/2013 10:31 AM, Rempel, Cynthia wrote:
> Hi,
> Attached is a patch for fixing the formatting of many of the default values in the documentation.  Applying this patch will make it easier for the Application Configuration GUI to parse out the default values.
> Please see:
> https://github.com/shubhamsomani/GUI/
> https://github.com/shubhamsomani/TUI/
> Time permitting, there will be another patch to follow in the next two-three weeks fixing the formatting of the ranges, but the default values patch will need to be committed before the ranges patch could be applied...
> Thanks,
> Cindy
