[PATCH 04/12] score: Add _Chain_Insert_ordered_unprotected()
Thu Jun 13 15:32:29 UTC 2013
Should we add "rtems_chain_insert_ordered()" to the public api?
On Wed, Jun 12, 2013 at 11:12 AM, Sebastian Huber
>  cpukit/score/inline/rtems/score/chain.inl |   41 +++++++++++++++++++++++++++++
>  testsuites/sptests/spchain/init.c         |   34 ++++++++++++++++++++++++
>  testsuites/sptests/spchain/spchain.doc    |    1 +
>  testsuites/sptests/spchain/spchain.scn    |    1 +
>  4 files changed, 77 insertions(+), 0 deletions(-)
> diff --git a/cpukit/score/inline/rtems/score/chain.inl b/cpukit/score/inline/rtems/score/chain.inl
> index 7290d6e..190eedf 100644
> --- a/cpukit/score/inline/rtems/score/chain.inl
> +++ b/cpukit/score/inline/rtems/score/chain.inl
> @@ -726,6 +726,47 @@ RTEMS_INLINE_ROUTINE bool _Chain_Get_with_empty_check_unprotected(
>    return is_empty_now;
> + * @brief Chain node order.
> + * @param[in] left The left node.
> + * @param[in] right The right node.
> + * @retval true According to the order the left node precedes the right node.
> + * @retval false Otherwise.
> +typedef bool ( *Chain_Node_order )(
> +  const Chain_Node *left,
> +  const Chain_Node *right
> + * @brief Inserts a node into the chain according to the order relation.
> + * After the operation the chain contains the node to insert and the order
> + * relation holds for all nodes from the head up to the inserted node.  Nodes
> + * after the inserted node are not moved.
> + * @param[in/out] chain The chain.
> + * @param[in/out] to_insert The node to insert.
> + * @param[in] order The order relation.
> +RTEMS_INLINE_ROUTINE void _Chain_Insert_ordered_unprotected(
> +  Chain_Control *chain,
> +  Chain_Node *to_insert,
> +  Chain_Node_order order
> +  const Chain_Node *tail = _Chain_Immutable_tail( chain );
> +  Chain_Node *next = _Chain_First( chain );
> +  while ( next != tail && !( *order )( to_insert, next ) ) {
> +    next = _Chain_Next( next );
> +  _Chain_Insert_unprotected( _Chain_Previous( next ), to_insert );
>  #endif
> diff --git a/testsuites/sptests/spchain/init.c b/testsuites/sptests/spchain/init.c
> index f8d54b0..72895b6 100644
> --- a/testsuites/sptests/spchain/init.c
> +++ b/testsuites/sptests/spchain/init.c
> @@ -218,6 +218,39 @@ static void test_chain_node_count(void)
> +static bool test_order( const Chain_Node *left, const Chain_Node *right )
> +  return left < right;
> +static void test_chain_insert_ordered( void )
> +  Chain_Control chain = CHAIN_INITIALIZER_EMPTY(chain);
> +  Chain_Node nodes[5];
> +  const Chain_Node *tail;
> +  const Chain_Node *node;
> +  size_t n = RTEMS_ARRAY_SIZE( nodes );
> +  size_t i = 0;
> +  puts( "INIT - Verify _Chain_Insert_ordered_unprotected" );
> +  _Chain_Insert_ordered_unprotected( &chain, &nodes[4], test_order );
> +  _Chain_Insert_ordered_unprotected( &chain, &nodes[2], test_order );
> +  _Chain_Insert_ordered_unprotected( &chain, &nodes[0], test_order );
> +  _Chain_Insert_ordered_unprotected( &chain, &nodes[3], test_order );
> +  _Chain_Insert_ordered_unprotected( &chain, &nodes[1], test_order );
> +  tail = _Chain_Immutable_tail( &chain );
> +  node = _Chain_Immutable_first( &chain );
> +  while ( node != tail && i < n ) {
> +    rtems_test_assert( node == &nodes[ i ] );
> +    ++i;
> +    node = _Chain_Immutable_next( node );
> +  rtems_test_assert( i == n );
>  rtems_task Init(
>    rtems_task_argument ignored
> @@ -260,6 +293,7 @@ rtems_task Init(
>    test_chain_control_layout();
>    test_chain_control_initializer();
>    test_chain_node_count();
> +  test_chain_insert_ordered();
>    puts( "*** END OF RTEMS CHAIN API TEST ***" );
>    rtems_test_exit(0);
> diff --git a/testsuites/sptests/spchain/spchain.doc b/testsuites/sptests/spchain/spchain.doc
> index 29c9d10..8cf8089 100644
> --- a/testsuites/sptests/spchain/spchain.doc
> +++ b/testsuites/sptests/spchain/spchain.doc
> @@ -24,6 +24,7 @@ directives:
>    rtems_chain_get_with_notification
>    rtems_chain_get_with_wait
>    rtems_chain_node_count_unprotected
>  concepts:
> diff --git a/testsuites/sptests/spchain/spchain.scn b/testsuites/sptests/spchain/spchain.scn
> index 9cf4d52..39f3795 100644
> --- a/testsuites/sptests/spchain/spchain.scn
> +++ b/testsuites/sptests/spchain/spchain.scn
> @@ -13,4 +13,5 @@ INIT - Verify rtems_chain_get_with_wait
>  INIT - Verify rtems_chain_control layout
>  INIT - Verify rtems_chain_control initializer
>  INIT - Verify rtems_chain_node_count_unprotected
> +INIT - Verify _Chain_Insert_ordered_unprotected
> 1.7.7
> rtems-devel mailing list
> rtems-devel at rtems.org
