[PATCH 10/12] scheduler: Simplify simple scheduler
Thu Jun 13 18:45:31 UTC 2013
On Thu, Jun 13, 2013 at 2:35 PM, Sebastian Huber
> On 13/06/13 20:21, Sebastian Huber wrote:
>> On 13/06/13 18:06, Gedare Bloom wrote:
>>> On Thu, Jun 13, 2013 at 12:01 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>>> On Wed, Jun 12, 2013 at 11:29 AM, Sebastian Huber
>>>>> Add and use _Scheduler_simple_Insert_as_first_order(),
>>>>> _Scheduler_simple_Insert_as_last_order(),
>>>>> _Scheduler_simple_Insert_as_first() and
>>>>> _Scheduler_simple_Insert_as_last().
>>>>>   .../score/inline/rtems/score/schedulersimple.inl   |   46
>>>>>   .../score/src/schedulersimplereadyqueueenqueue.c   |   21 +--------
>>>>>   .../src/schedulersimplereadyqueueenqueuefirst.c    |   26 +----------
>>>>>   3 files changed, 50 insertions(+), 43 deletions(-)
>>>>> diff --git a/cpukit/score/inline/rtems/score/schedulersimple.inl
>>>>> b/cpukit/score/inline/rtems/score/schedulersimple.inl
>>>>> index e67fc3c..1b58c85 100644
>>>>> --- a/cpukit/score/inline/rtems/score/schedulersimple.inl
>>>>> +++ b/cpukit/score/inline/rtems/score/schedulersimple.inl
>>>>> @@ -48,6 +48,52 @@ RTEMS_INLINE_ROUTINE void
>>>>> _Scheduler_simple_Ready_queue_requeue(
>>>>>     _Scheduler_simple_Ready_queue_enqueue( the_thread );
>>>>> +RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Insert_as_first_order(
>>>>> +  const Chain_Node *to_insert,
>>>>> +  const Chain_Node *next
>>>>> +  const Thread_Control *thread_to_insert = (const Thread_Control *)
>>>>> to_insert;
>>>>> +  const Thread_Control *thread_next = (const Thread_Control *) next;
>>>>> +  return thread_to_insert->current_priority <=
>>>>> thread_next->current_priority;
>>>>> +RTEMS_INLINE_ROUTINE bool _Scheduler_simple_Insert_as_last_order(
>>>>> to_insert;
>>>>> +RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert_as_first(
>>>>> +  Chain_Control *chain,
>>>>> +  Thread_Control *to_insert
>>>>> +  _Chain_Insert_ordered_unprotected(
>>>>> +    chain,
>>>>> +    &to_insert->Object.Node,
>>>>> +    _Scheduler_simple_Insert_as_first_order
>>>>> +RTEMS_INLINE_ROUTINE void _Scheduler_simple_Insert_as_last(
>>>>> +    chain,
>>>>> +    _Scheduler_simple_Insert_as_last_order
>>>> For these functions _Scheduler_simple_Insert_as_first() and
>>>> _Scheduler_simple_Insert_as_last() the name means they break priority
>>>> ties by FIFO and LIFO semantics? Before I read the code, I thought it
>>>> meant break ties by inserting to the first or last position of ties,
>>>> which is the opposite. I would prefer to have
>>>> _Scheduler_simple_Insert_as_fifo()/lifo() instead for added clarity.
>>> I guess saying fifo/lifo could be confusing also, since the insert is
>>> not fifo/lifo, just how priority ties are broken. So maybe
>>> _Scheduler_simple_Insert_priority_fifo()/lifo()?
>> Suppose we have 0 < 5_0 <= 5_1 < 10, then insert 5_2 as first will yield
>> 0 < 5_2 <= 5_0 <= 5_1 < 10
>> and insert 5_2 as last will yield
>> 0 < 5_0 <= 5_1 <= 5_2 < 10
>> I will use your suggestions.
> Now I think that the LIFO/FIFO talks to much about a particular use case.
> What about
> _Scheduler_simple_Insert_as_first_of_priority_group()
That would be acceptable if you prefer. It is usual to specify whether
ties are broken by lifo/fifo. A priority queue that breaks ties with
FIFO is called "stable".
