[PATCH 1/6] smp: Delete RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY
Sebastian Huber
Fri Jun 14 14:31:56 UTC 2013
The thread dispatch is a side-effect of interrupt processing, thus there
is no need to send an explicit message.
cpukit/score/include/rtems/score/smp.h | 7 ----
cpukit/score/src/smp.c | 58 +++++++++++++++----------------
2 files changed, 28 insertions(+), 37 deletions(-)
diff --git a/cpukit/score/include/rtems/score/smp.h b/cpukit/score/include/rtems/score/smp.h
index ea073ac..a015156 100644
--- a/cpukit/score/include/rtems/score/smp.h
+++ b/cpukit/score/include/rtems/score/smp.h
@@ -37,13 +37,6 @@ extern "C" {
* This defines the bit which indicates the interprocessor interrupt
* has been requested so that RTEMS will reschedule on this CPU
- * because the currently executing thread needs to be switched out.
-#define RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY 0x01
- * This defines the bit which indicates the interprocessor interrupt
- * has been requested so that RTEMS will reschedule on this CPU
* because the currently executing thread has been sent a signal.
#define RTEMS_BSP_SMP_SIGNAL_TO_SELF 0x02
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 3081062..fce9275 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -69,43 +69,41 @@ void rtems_smp_process_interrupt( void )
int self = bsp_smp_processor_id();
Per_CPU_Control *per_cpu = &_Per_CPU_Information[ self ];
- uint32_t message;
- ISR_Level level;
- _Per_CPU_Lock_acquire( per_cpu, level );
- message = per_cpu->message;
- per_cpu->message = 0;
- _Per_CPU_Lock_release( per_cpu, level );
+ if ( per_cpu->message != 0 ) {
+ uint32_t message;
+ ISR_Level level;
- #if defined(RTEMS_DEBUG)
- void *sp = __builtin_frame_address(0);
- if ( !(message & RTEMS_BSP_SMP_SHUTDOWN) ) {
- printk( "ISR on CPU %d -- (0x%02x) (0x%p)\n", self, message, sp );
- if ( message & RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY )
- printk( "context switch necessary\n" );
- if ( message & RTEMS_BSP_SMP_SIGNAL_TO_SELF )
- printk( "signal to self\n" );
- if ( message & RTEMS_BSP_SMP_SHUTDOWN )
- printk( "shutdown\n" );
+ _Per_CPU_Lock_acquire( per_cpu, level );
+ message = per_cpu->message;
+ per_cpu->message = 0;
+ _Per_CPU_Lock_release( per_cpu, level );
+ #if defined(RTEMS_DEBUG)
+ void *sp = __builtin_frame_address(0);
+ if ( !(message & RTEMS_BSP_SMP_SHUTDOWN) ) {
+ printk( "ISR on CPU %d -- (0x%02x) (0x%p)\n", self, message, sp );
+ if ( message & RTEMS_BSP_SMP_SIGNAL_TO_SELF )
+ printk( "signal to self\n" );
+ if ( message & RTEMS_BSP_SMP_SHUTDOWN )
+ printk( "shutdown\n" );
+ printk( "Dispatch level %d\n", _Thread_Dispatch_get_disable_level() );
- printk( "Dispatch level %d\n", _Thread_Dispatch_get_disable_level() );
- #endif
+ #endif
- if ( message & RTEMS_BSP_SMP_SHUTDOWN ) {
- _ISR_Disable_on_this_core( level );
+ if ( ( message & RTEMS_BSP_SMP_SHUTDOWN ) != 0 ) {
+ _ISR_Disable_on_this_core( level );
- while ( _Thread_Dispatch_decrement_disable_level() != 0 ) {
- /* Release completely */
+ _Thread_Dispatch_set_disable_level( 0 );
- _Per_CPU_Change_state( per_cpu, PER_CPU_STATE_SHUTDOWN );
+ _Per_CPU_Change_state( per_cpu, PER_CPU_STATE_SHUTDOWN );
- _CPU_Fatal_halt( self );
- /* does not continue past here */
+ _CPU_Fatal_halt( self );
+ /* does not continue past here */
@@ -179,7 +177,7 @@ void _SMP_Request_other_cores_to_dispatch( void )
&& per_cpu->state == PER_CPU_STATE_UP
&& per_cpu->dispatch_necessary
- _SMP_Send_message( cpu, RTEMS_BSP_SMP_CONTEXT_SWITCH_NECESSARY );
+ _SMP_Send_message( cpu, 0 );
1.7.7
