[PATCH] RTEMS: Use strict DWARF-2 on ARM, PowerPC, SPARC
    Rempel, Cynthia
    cynt6007 at vandals.uidaho.edu
    Tue Jun 18 15:32:14 UTC 2013
Hi Sebastian,
Thanks for showing us this patch, and clarifying that it's solving a problem with using sparc-gdb!  How should we test it?
To verify we didn't break anything, should we just follow http://gcc.gnu.org/simtest-howto.html ?
>From the referenced email, I gather we could verify the debugging symbols didn't work without the patch in gdb-7.6 and did work with the patch in gdb-7.6.
I'm just wanting some clarity on the procedure, so we can document it in the git://git.rtems.org/rtems-tools.git
Thanks,
Cindy
>On 06/18/2013 02:10 PM, Ralf Corsepius wrote:
>> On 06/18/2013 01:58 PM, Sebastian Huber wrote:
>>> Some debuggers do not cope with the new DWARF3/4 debug format introduced
>>> with GCC 4.8.  Default to strict DWARF-2 on ARM, PowerPC and SPARC for
>>> now.
>>> This patch should be committed to GCC 4.8 and 4.9.
>> I am opposed to this patch, because
>> * GNU software should not care about the limitations of commerical stuff and
>> should only care about gdb.
>Actually GCC cares about commercial stuff, e.g. the VxWorks and Darwin ports
>use exactly the same mechanism.
>The SPARC version of GDB seems to have problems here also:
>http://www.rtems.org/pipermail/rtems-devel/2013-May/003188.html
>> * We should stay with the GCC's defaults and not diverge from these.
>In general this is true.
>> * Users, who are facing issues with commerical stuff can always manually pass
>> appropriate options to CC if they need it.
>This approach is not possible for the multilibs.
